Shelby_Compare
Unboxing Experience
- 1.1.1 Yoton Mini Projector:
- 1.1.2 AKIYO Mini Projector:
- 1.1.3 PANSEBA Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Yoton Mini Projector:
- 1.3.2 AKIYO Mini Projector:
- 1.3.3 PANSEBA Mini Projector:
- 1.4 Features
1.5
- 1.5.1 Yoton Mini Projector:
- 1.5.2 AKIYO Mini Projector:
- 1.5.3 PANSEBA Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
| Parameter | Yoton Mini Projector | AKIYO Mini Projector | PANSEBA Mini Projector |
Picture | |||
Reference Price | $39.99 | $47.49 | $50.99 |
Recommended Uses | Home Cinema | Indoor/Outdoor | Home Cinema |
Built-In Media | Mini Projector Y3, User Manual, Remote Control, Power Cable, HDMI Cable | Projector Stand | User Manual, Power Cord, Projector Screen, Remote, HDMI Cable |
Highlight | Native Resolution: 1280x720 (720P) Full HD Support: 1080P Brightness: 120 ANSI lumens Dimensions: 13.72x10.92x5.84 cm Weight: 420 grams Projection Size: Up to 120 inches (optimal 30-100 inches) Optimal Projection Distance: 1.3 to 3 meters Keystone Correction: ±15° vertical Zoom Function: 50% zoom Connectivity Ports: HDMI, USB, audio Additional Features: Wired iOS connection, plug-and-play, no built-in WiFi or Bluetooth | Size: 5.35*4.33*2.28 in Weight: 420 grams Keystone Correction: ±50° electronic vertical Zoom Function: 50% zoom via remote Projection Screen Size: 32-120 in Optimal Projection Distance: 3.28-9.84 feet Connections: HDMI, USB, 3.5mm audio output Compatibility: PC, Fire Stick, PS5 WiFi Support: 5G/2.4G dual-screen WiFi Speed: Up to 9.6G bps Bluetooth Version: 5.2 Warranty: 2 years P2P Connection: Yes, no WiFi required | Brightness: 50% brighter than similar projectors Contrast Ratio: 8000:1 Resolution: Supported 1080p Screen Size: Up to 200 inches Bluetooth Version: 5.2 Speaker Type: Built-in HIFI speakers Noise Level: Low noise operation Lamp Life: 50,000 hours Input Compatibility: Laptops, smartphones, tablets, USB drives, X-Box HDMI Adapter Requirement: Required for phone/tablet connection (not included) MHL Support: Necessary for certain Android devices Mirrored Projectors Compatibility: Incompatible with Hulu (use TV Stick instead) |
Unboxing Experience
The Yoton Mini Projector has a compact design that is appealing for its portability. Its small size makes it easy to transport, and it fits well in various environments, whether in an RV or home setting. Despite its modest appearance, it manages to project a visually engaging image, which is quite impressive considering its size. While some users noted issues with dust accumulation on the lens, the overall aesthetic remains functional and user-friendly.AKIYO Mini Projector:
The AKIYO Mini Projector is surprisingly compact, roughly the size of a large watch box, making it portable and easy to store. Its design is sleek and unobtrusive, which is a plus when you want to mount it on the ceiling or set it up in a small space. It comes with a small tripod that adds stability during use, enhancing its practical appeal. Overall, the projector looks modern and fits well into various setups, whether for movie nights or creative projects like banner painting.PANSEBA Mini Projector:
The PANSEBA Mini Projector is impressively compact and lightweight, making it easy to transport and set up in various environments, whether indoors or outdoors. Its sleek design is user-friendly, with simple controls that can be operated via the included remote or directly on the device. The included projector screen, while functional, is somewhat thin, which can affect the projection quality against certain backgrounds. Overall, it maintains an attractive appearance that blends well in any setting, from home theaters to camping trips.Display
Screen Size | 30 Inches - 100 Inches | 32 Inches - 120 Inches | 32 Inches - 200 Inches |
Throw Distance | 1 Meters - 4 Meters | 0.6 Meters - 4 Meters | 2.65 Feet - 26.25 Feet |
Contrast Ratio | 5000:1 | 5000:1 | 8000:1 |
Maximum Resolution | 1920 x 1080 Pixels | 1920*1080 Pixels | 1980 x 1080 Pixels |
Native Resolution | 1280 x 720 | 1280 x 720 | 1920 x 1080 |
Brightness | 5500 Lumen | 5500 Lumen | 95 Lumen |
Display Type | LCD | LCD | LED |
Picture Enhancement | LCD 3.0 | Not Specified | High Contrast Ratio and Full HD Resolution |
Viewing Experience
The viewing experience varies based on expectations and conditions. The image quality is generally deemed acceptable for a budget projector, particularly in low-light environments. Users appreciate the ability to adjust brightness and color settings, although some have mentioned difficulties with focus, particularly when utilizing keystone correction. There are mixed reviews regarding sound quality, with some finding the built-in speaker insufficient for larger spaces, while others have successfully paired it with external audio sources for improved sound.AKIYO Mini Projector:
The viewing experience is quite impressive for a device in this price range. In dimmer environments, the picture quality is sharp and vibrant, supporting up to 1080P resolution. I appreciated the digital zoom feature, which allowed for easy adjustments to the image size without significant loss of clarity. Although the built-in speakers are decent, I found that connecting to a Bluetooth speaker greatly enhances the sound quality, especially for movie nights. Overall, the projector performs admirably under the right conditions.PANSEBA Mini Projector:
The image quality of the PANSEBA Mini Projector is surprisingly sharp, with Full HD 1080P resolution that delivers vibrant colors and decent brightness, particularly in dimly lit settings. Users report that it performs well even on larger projection surfaces, up to 200 inches. However, some have noted that achieving the best picture may require optimal lighting conditions and a suitable projection surface. The built-in audio is decent for casual use but connecting external speakers via Bluetooth or aux is recommended for enhanced sound quality, especially for movies and gaming experiences.Features
Other Features | LCD 3.0 Tech, High bright, Max support 1080P, Mini size, Speakers | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi | Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom |
Video Encoding | AVI/MP4/MKV/MOV/MPEG1/MPEG2/H.264/XVID | AVC | H.264 or MPEG-4 AVC |
Lamp Wattage | 3 Watts | 3 Watts | - |
LightSource Life | 6000 Hours | 55000 Hours | 50000 Hours |
Controller Type | Remote Control | Button Control | Remote Control |
Control Method | Remote | App | Remote |
Connectivity Technology | USB, HDMI | Wireless | Bluetooth, USB, HDMI, 3.5mm Jack |
Compatible Devices | iPhone, Fire TV Stick, PC, PS5, Android | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | TV Stick, Smartphone, USB, SD Card |
Wattage | 38 watts | 38 Watt-hours | 55 watts |
Mount Type | Ceiling/Tripod/Floor/Wall/Tabletop Mount | Tabletop Mount | Ceiling/Floor/Tabletop/Tripod/Wall Mount |
L x W x H | 5.4"L x 4.3"W x 2.3"H | 5.35"L x 4.33"W x 2.28"H | 7.28"L x 5.98"W x 2.95"H |
Setting up the Yoton Mini Projector is straightforward. Many users found it easy to connect, highlighting its compatibility with devices like the Amazon Fire Stick for streaming. However, some faced challenges when trying to connect various HDMI sources or when attempting to use screen mirroring, especially with specific phone models like Samsung. The lack of wireless connectivity options may be a drawback for some, although many found a wired setup to be effective once configured correctly.AKIYO Mini Projector:
Setting up the AKIYO Mini Projector is a straightforward process, and I found the included manual helpful for navigating initial configurations. The projector offers multiple orientation options for mirroring or ceiling mounting, which adds versatility. However, I did encounter some connectivity issues with newer devices that require USB-C adapters, particularly with my MacBook and Nintendo Switch. Using HDMI was seamless with older laptops and gaming consoles like my Xbox, leading to a generally positive setup experience.PANSEBA Mini Projector:
Setting up the PANSEBA Mini Projector is incredibly straightforward, taking just a few minutes to connect to devices like Roku, Firestick, laptops, or smartphones. The connectivity options are versatile, including HDMI, USB, and Bluetooth capabilities, allowing for seamless integration with various media sources. Many users appreciate how easy it is to navigate the built-in interface, making it accessible even for those who aren't tech-savvy. The projector's lightweight design adds to its portability, enabling quick relocations for different viewing experiences.Conclusion
Pros:• Compact and portable design.
• Easy setup and connectivity with devices like Fire Stick.
• Satisfactory image quality in low-light conditions.
• Affordable price point.
• Responsive customer service.
• Dust can accumulate on the lens, affecting image clarity.
• Limited focus capabilities, especially with keystone correction.
• Some users report HDMI connection issues.
• Built-in speaker may not suffice for larger areas.
• Occasional quality control issues reported, such as overheating.
The Yoton Mini Projector offers great value for its size and price, making it a suitable choice for casual use, such as movie nights or presentations. While it has its quirks, such as the need for a clean lens and potential connection issues, many users find it performs admirably for the intended purpose. It is particularly praised for its portability and ease of use, making it an excellent option for those seeking a compact projector without breaking the bank. Nonetheless, potential buyers should be aware of its limitations and manage their expectations accordingly.
• Decent picture quality in low-light settings
• Easy setup and versatile mounting options
• Supports HDMI and Bluetooth connectivity
• Excellent customer service
• Built-in speakers lack power
• Some devices may require adapters for connectivity
• Inconsistent performance with wireless streaming
• Occasional connectivity issues with newer devices
The AKIYO Mini Projector is an excellent choice for anyone seeking an affordable yet capable projection solution. It’s perfect for casual movie nights, gaming, or creative projects, making it a versatile addition to any home setup. Despite a few connectivity hiccups and modest sound output, the picture quality and ease of use make it a worthwhile investment. Plus, the responsive customer service adds to the overall positive experience. I would recommend it for those looking for an entry-level projector without breaking the bank.
Pros:• Easy to set up and use.
• Portable and lightweight design.
• Full HD 1080P resolution with vibrant picture quality.
• Versatile connectivity options including HDMI, USB, and Bluetooth.
• Good built-in speakers for small settings.
• Comes with a projector screen for enhanced viewing.
• The included screen can be thin and somewhat transparent.
• Brightness may struggle in well-lit environments.
• Some users experienced audio delay with Bluetooth connections.
• The built-in speaker may not be sufficient for larger spaces.
Overall, the PANSEBA Mini Projector offers exceptional value for its price, making it a great choice for movie nights, gaming, and presentations. Its combination of portability, ease of setup, and decent image quality makes it an attractive option for both home entertainment and outdoor use. While there are some limitations regarding brightness and sound, the advantages far outweigh the drawbacks, especially for casual users looking for an affordable projection solution. Highly recommended for anyone wanting a compact and effective projector!
