PANSEBA vs KHQ vs Yoton: Which Mini Projector is Right for Outdoor Viewing?
joe603
PANSEBA Mini Projector​
KHQ Mini Projector​
Yoton Mini Projector​
$59.99​
$54.99​
$39.99​
Home Cinema​
Indoor/Outdoor​
Home Cinema​
User Manual, Power Cord, Projector Screen, Remote, HDMI Cable​
Power Cord, User Manual, HDMI Cable, Carrying Bag​
Mini Projector Y3, User Manual, Remote Control, Power Cable, HDMI Cable​
Bluetooth Version: 5.2
Speaker Type: HIFI
Screen Size: Up to 200 inches
Brightness: 50% brighter than similar projectors
Contrast Ratio: 8000:1
Resolution: 1080p
Image Clarity: 50% clearer than similar projectors
Noise Level: Low
Lamp Life: 50,000 hours
Device Compatibility: Laptops, smartphones, tablets, USB drives, X-Box
Connection Requirement for Phones: HDMI adapter cable (not included)
iOS Connection: Official Lightning to HDMI adapter required (not included)
Android Connection: MHL support needed or use Chrome-cast if not MHL compatible.
Brightness: 1080P Full HD
Weight: 0.75 pounds
Projection Size: 21 inch to 170 inch
Projection Distance: 2.3 ft to 15.7 ft (best at 6.5 ft to 9.8 ft)
Speakers: Built-in stereo speakers
Inputs: HDMI, USB, AV input, audio interface
Compatibility: Connects with TV stick, PS4/5, Chromecast, PC, laptop (smartphone requires additional adapter)
Service: 7x24h after-sales service
Usage Note: Not recommended for PPT and business presentations
Native Resolution: 1280x720 (720P)
Supported Resolution: Full HD 1080P
Brightness: 120 ANSI lumens
Dimensions: 13.72 x 10.92 x 5.84 cm
Weight: 420 grams
Max Projection Size: 120 inches
Recommended Projection Size: 30 to 100 inches
Optimal Projection Distance: 1.3 to 3 meters
Keystone Correction: ±15°
Zoom Function: 50%
Connectivity Ports: HDMI, USB, audio
Special Features: Wired iOS direct connection, plug-and-play functionality
WiFi/Bluetooth: Not supported
Unboxing Experience​
PANSEBA Mini Projector:​
Upon receiving the mini projector, I was pleasantly surprised by its compact and sleek design. Its lightweight structure makes it incredibly portable, perfect for moving between rooms or taking outdoors for movie nights. The aesthetic is modern and user-friendly, with intuitive controls conveniently located on the top of the device. Overall, it gives off a professional vibe that belies its affordable price point.
KHQ Mini Projector:​
Upon receiving the projector, I was pleasantly surprised by its compact and cute design. It's small enough to easily transport, making it a great choice for various settings, whether for movie nights at home or presentations. The overall aesthetic is appealing, with a modern look that fits well in any environment. The lightweight nature adds to its portability, allowing me to move it around effortlessly.
Yoton Mini Projector:​
The projector's compact size is a significant highlight, making it an excellent choice for those with limited space or for use in an RV. Its small, unobtrusive design allows it to blend seamlessly into various settings, from a cozy home entertainment area to an art classroom. While the overall aesthetic may not be luxurious, it fulfills the role of a functional gadget well, and its portability is a definite advantage.
KHQ Mini Projector​
32 Inches - 200 Inches​
40 Inches - 100 Inches​
30 Inches - 100 Inches​
2.65 Feet - 26.25 Feet​
2.3 Feet - 16 Feet​
1 Meters - 4 Meters​
8000:1​
1000:1​
5000:1​
1980 x 1080 Pixels​
1920 x 1080 Pixels​
1920 x 1080 Pixels​
1280 x 720​
95 Lumen​
5500 Lumen​
LED​
High Contrast Ratio and Full HD Resolution​
Full HD​
LCD 3.0​
The viewing experience has been nothing short of impressive. The projector boasts a native 1080p resolution that delivers sharp, vibrant images, even in moderately lit environments. Watching movies on a 120-inch screen was particularly enjoyable, as the colors popped and the clarity was excellent. While the built-in speaker is decent for casual use, I found that connecting external speakers greatly enhanced the audio experience, making it feel more cinematic. Overall, the projector provides a solid performance for both movies and presentations.
The viewing experience varies based on the content and the distance from the wall. While I enjoyed projecting movies, the resolution was a letdown, especially for smaller text in commercials. It excels when used for casual viewing, like showing old sitcoms or family videos, but I found it less impressive for detailed work, particularly with my computer screen. The projector works best in darker settings, but the picture can still appear too dark or fuzzy at times, which detracts from the overall experience.
The viewing experience is decent, particularly in low-light conditions. The image quality is satisfactory for basic needs, like watching home videos or projecting images for art projects. While I did notice some blurriness and focusing issues at the edges of the screen, the brightness is commendable, even in slightly lit rooms. However, the projector struggles in well-lit environments, necessitating a fully dark room for optimal viewing. The sound quality, while adequate, could benefit from being louder, especially when viewed from a distance.
KHQ Mini Projector​
Built-In Speaker, Portable, Digital Keystone Correction, Lightweight, 50%-100% Zoom​
轻巧​
LCD 3.0 Tech, High bright, Max support 1080P, Mini size, Speakers​
H.264 or MPEG-4 AVC​
AVC​
AVI/MP4/MKV/MOV/MPEG1/MPEG2/H.264/XVID​
60 Watts​
3 Watts​
50000 Hours​
50000 Hours​
6000 Hours​
Button Control​
Touch​
HDMI
USB, HDMI
TV Stick, Smartphone, USB, SD Card​
iPhone, Fire TV Stick, PC, PS5, Android​
55 watts​
2 watts​
38 watts​
Mount Type​
Ceiling/Floor/Tabletop/Tripod/Wall Mount​
Tabletop Mount​
Ceiling/Tripod/Floor/Wall/Tabletop Mount​
7.28"L x 5.98"W x 2.95"H​
5.6"L x 2.3"H​
5.4"L x 4.3"W x 2.3"H​
Setting up this projector was a breeze. I was able to swap it out with my old projector and have it running in under three minutes. The included quick start guide is straightforward and easy to follow, making the initial setup hassle-free. The projector seamlessly connects to devices via HDMI, USB, and even micro SD, allowing for versatile compatibility with streaming devices like Roku and Firestick. Adjusting the zoom and focus was simple and efficient, ensuring that I could quickly get the perfect picture without any fuss.
Setting up the projector was a breeze. I was able to connect it to my Amazon Fire Stick and my computer using HDMI without any hassle, thanks to the included remote that made navigation straightforward. The device came securely packaged with everything I needed right out of the box. Although I struggled a bit to connect my phone initially, I later found that following the instructions made the process easier. It does lack Bluetooth connectivity, but the wired options are functional and efficient.
Setting up the projector was relatively straightforward, though there were some initial challenges, especially when trying to connect certain devices like my Samsung phone. However, once I figured out the required connections and adjustments, the setup became hassle-free. The ability to connect with devices like the FireStick simplified the streaming process, allowing for a versatile viewing experience. I appreciated the optical keystone correction feature, which helped in adjusting the image alignment with ease, although it did require some trial and error.
• Easy to set up and use
• Excellent picture quality with vibrant colors
• Lightweight and portable for various settings
• Versatile connectivity options (HDMI, USB, micro SD)
• Two-way Bluetooth functionality for enhanced audio
• Built-in speakers could be better; external speakers recommended
• The included screen is somewhat thin and can be transparent
• Limited adjustment options for picture size and angle
• Slight latency in audio when using Bluetooth
In conclusion, this mini projector has exceeded my expectations and proves to be an excellent value for the price. It’s perfect for movie nights, gaming, and even presentations, offering a bright and clear picture alongside decent sound. Though there are minor drawbacks, such as the built-in speaker and limited adjustment features, the overall performance and ease of use make it a fantastic investment for anyone looking for a portable projection solution. I highly recommend it to anyone seeking an affordable and high-quality projector for home entertainment or outdoor fun.
• Compact and portable design
• Easy setup and connection with HDMI
• Good sound quality for a small device
• Affordable price point
• Functions well for casual viewing and family activities
• Low resolution leads to a fuzzy picture
• Limited options for adjusting brightness and color settings
• Can be too dark for night scenes
• Fan is quite loud during operation
• May disconnect from HDMI occasionally
For the price, this projector offers decent value and is a fun addition to my home entertainment setup. While it has its flaws, such as limited resolution and brightness issues, it still delivers a satisfactory experience for casual movie nights and presentations. I appreciate its portability and ease of use, making it suitable for various occasions, from family gatherings to solo movie marathons. Overall, it has been a worthwhile purchase that I plan to use frequently, as long as my expectations are aligned with its capabilities.
• Easy setup and connection options
• Decent image quality for the price
• Bright projection in low-light conditions
• Good customer service experience
• Limited performance in well-lit environments
• Blurriness at the edges of the image
• Sound quality is quieter than expected
• Occasional connection issues with specific devices
• Dust accumulation affecting image clarity
Overall, this projector represents a solid value for its price, especially considering its portability and ease of use. While it certainly has its flaws, such as blurriness at the edges and quieter audio, it delivers adequate performance for casual viewing and art-related tasks. I find it particularly useful for my needs, and despite some quirks, I appreciate its functionality and the positive customer service experience. For those on a budget seeking a compact projector for basic uses, this could be a worthwhile investment.
PlayStationPepe
The PANSEBA Mini Projector is super easy to set up! The quick start guide is just a page with clear pics and instructions. Totally recommend it!
PlayStationPepe
The KHQ Mini Projector is awesome for the price, but I just wish the lens lever was in a better spot. It would be nice to set it up in different ways for my projects!
eat_a_burrito
KHQ Mini Projector:
The good: pretty clear, small and easy to set up.
The bad: super dark no matter what, the image slants to the left, and it's too light so it shifts around a lot. Seriously, it's way too dark, especially for night scenes. Total letdown.
Trollatopoulous
Yoton Mini Projector is decent but could use some work. I had issues with the HDMI connections—took a bit to fix. Plus, Netflix doesn’t work on it, which is a bummer. So, I'm giving it 3 stars.
Yoton Mini Projector is a steal at this price! Hooked up my Firestick easily. Works best in complete darkness, but when you go big, the focus is all messed up—clear at the top and blurry at the bottom. No brightness adjustment either. Almost returned it, but for $50, it gets the job done!
AwesomenessDjD
I’m a big fan of the Yoton Mini Projector! It gives me a huge portable screen anywhere I am. Super bright and clear focus, plus it’s totally worth the money!
