KeyGood5298
Unboxing Experience
- 1.1.1 KHQ Mini Projector:
- 1.1.2 Ohdil Mini Projector:
- 1.1.3 AKIYO Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 KHQ Mini Projector:
- 1.3.2 Ohdil Mini Projector:
- 1.3.3 AKIYO Mini Projector:
- 1.4 Features
1.5
- 1.5.1 KHQ Mini Projector:
- 1.5.2 Ohdil Mini Projector:
- 1.5.3 AKIYO Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | KHQ Mini Projector | Ohdil Mini Projector | AKIYO Mini Projector |
Picture | |||
Reference Price | $54.99 | $59.99 | $55.99 |
Recommended Uses | Indoor/Outdoor | Office, Education, Home Cinema, Gaming, Business | Indoor/Outdoor |
Built-In Media | Power Cord, User Manual, HDMI Cable, Carrying Bag | 1 x Projector Manual, 1 x Hdmi Cable, 1 x Power Adapter, 1 x Smart Projector, 1 x Remote Control (Batteries not included) | Projector Stand |
Highlight | Higher Brightness: 1080P Full HD enhancement technology for home theater viewing Size and Weight: Compact dimensions 5.6*3.8*2.3 inches, 0.75 pounds Projection Features: Built-in stereo speakers, adjustable focus, projection size 21 inch to 170 inch, projection distance 2.3 ft to 15.7 ft (best at 6.5 ft to 9.8 ft) Compatibility: HDMI, USB, AV input, audio interface; compatible with TV stick, PS4/5, Chromecast, PC, laptop; requires additional adapter for smartphone connection (not included) Customer Support: 7x24h after-sales service; not recommended for PPT and business presentations | Size: 5.63 * 3.78 * 2.28 inches Weight: 0.75 pounds Power Options: DC power, mobile phone charger, car charger, Micro-USB (5V / 2A) Connectivity: WiFi, supports Android/iPhone/Windows Projection Resolution: 1920*1080P (supports 1080P full HD) Native Resolution: 800*480 Screen Size Range: 22-170 inches Noise Reduction: 80% fan noise reduction Audio: Built-in stereo surround speakers Ports: HDMI, Audio, USB Compatibility: Roku sticks, Fire TV sticks, gaming consoles, PCs, smartphones, laptops, DVD players, USB memory sticks Included Accessories: Smart projector, projector manual, remote control (batteries not included), power adapter | P2P Direct Connection: No WiFi required for iOS/Android screen casting WiFi & Bluetooth: Supports 5G/2.4G WiFi, Bluetooth 5.2 (no smartphone connection) Resolution: Native 720P (1280*720), supports Full HD 1080P Brightness & Contrast: 200 ANSI brightness, 2000:1 contrast ratio Size & Weight: Dimensions: 5.35*4.33*2.28 in, Weight: 420 grams Keystone Correction: ±50° electronic vertical keystone correction Zoom Function: 50% zoom capability Projection Size & Distance: Supports 32-120 in screen size, optimal distance 3.28-9.84 feet Connectivity: HDMI, USB, 3.5mm audio output jack Warranty: 2-year warranty with 24H support available |
Unboxing Experience
KHQ Mini Projector:
When I first unpacked the projector, I was pleasantly surprised by its compact size and cute design. It looks small and portable, making it easy to carry from room to room or even outdoors. The overall aesthetic is appealing, as it doesn't take up much space and can easily fit into a backpack or on a shelf without being obtrusive. This makes it an attractive option for those seeking a functional yet visually pleasing device.Ohdil Mini Projector:
The Ohdil Mini Projector boasts a striking design that immediately catches the eye, especially in its vibrant yellow color. Its compact size, measuring just 5-5/8” wide, 2-1/4” high, and 3-3/4” deep, makes it incredibly portable—perfect for those who want to take it on the go. The hard plastic exterior feels durable, which is reassuring given its lightweight nature. However, some users have noted minor defects in the finish, which could detract from its overall aesthetic appeal.AKIYO Mini Projector:
The projector's compact design is a standout feature, making it an excellent option for both indoor and outdoor use. It’s lightweight, which adds to its portability, and the included tripod provides stability for various setups. The aesthetics are simple yet functional, allowing it to blend seamlessly into any environment without being an eyesore.Display
Screen Size | 40 Inches - 100 Inches | 22 Inches - 170 Inches | 32 Inches - 120 Inches |
Throw Distance | 2.3 Feet - 16 Feet | 3.3 Feet - 16 Feet | 0.6 Meters - 4 Meters |
Contrast Ratio | 1000:1 | 1000:1 Pixels | 5000:1 |
Maximum Resolution | 1920 x 1080 Pixels | 1920 x 1080 Pixels | 1920*1080 Pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1280 x 720 |
Brightness | - | 1000 Lumen | 5500 Lumen |
Display Type | LCD | LED | LCD |
Picture Enhancement | Full HD | 1080P Full HD enhancement technology | Not Specified |
Viewing Experience
KHQ Mini Projector:
The viewing experience can be quite enjoyable, especially for movie nights or casual use. I was able to project onto a wall with a screen size of over 110 inches, which made for a fun home theater feel. However, I did notice some drawbacks, such as the resolution being lower than I expected, leading to fuzzy text in some cases. While it works well for watching shows or movies, attempting to display my computer screen was a different story, as it was nearly illegible. It performs best in dim lighting conditions, and I found it challenging to see darker scenes clearly.• **Pros**:
- Compact and portable design
- Easy setup and connectivity
- Good sound quality for its size
- Impressive screen size for casual viewing
• **Cons**:
- Low resolution (not true 1080p)
- Blurry text and images for detailed displays
- Limited brightness and poor performance in well-lit environments
- Fan noise can be distracting
The projector delivers a decent viewing experience, especially in a dark room where the picture quality shines. The claimed 1080P resolution is noticeable, though not as sharp or vibrant as more expensive models. Users have reported that the brightness is lacking for outdoor use, requiring a very dark environment for optimal viewing. The ability to manually adjust focus is a plus, but overall, the image quality might leave some users wanting more, particularly in terms of brightness and clarity.AKIYO Mini Projector:
The viewing experience is generally positive, with impressive picture quality, especially in dimly lit settings. Users noted that the 1080P output is sharp and clear, although some reported light artifacts typical of projectors within this price range. While the sound quality from the built-in speakers is adequate for casual viewing, many users opted for external Bluetooth speakers to enhance their audio experience.Features
Other Features | 轻巧 | Built-In Speaker, Outdoor / Indoor Portable, Mini Projector for All Smartphone, Portable,Zoom 50%-100%, Wi-Fi ,HDMI ,Screen Mirroring ,Maximum 170" projection ,HD 1080P Supported | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi |
Video Encoding | AVC | AVC | AVC |
Lamp Wattage | 60 Watts | - | 3 Watts |
LightSource Life | 50000 Hours | - | 55000 Hours |
Controller Type | Button Control | iOS,Android | Button Control |
Control Method | Touch | Remote | App |
Connectivity Technology | HDMI | Wi-Fi, HDMI | Wireless |
Compatible Devices | Laptop, Gaming Console, Television, Tablet, Smartphone | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet |
Wattage | 2 watts | - | 38 Watt-hours |
Mount Type | Tabletop Mount | Floor Mount/Ceiling Mount/Tabletop Mount/Tripod Mount/Wall Mount | Tabletop Mount |
L x W x H | 5.6"L x 2.3"H | 5.63"L x 3.78"W x 2.28"H | 5.35"L x 4.33"W x 2.28"H |
KHQ Mini Projector:
Setting up the projector was a breeze. I was able to connect it to my Amazon Fire Stick in no time, and the remote made navigating through the settings incredibly simple. It comes with all the necessary cables and connectors, which is a huge plus, and I found it straightforward to hook up my computer and other devices. However, I did struggle a bit when attempting to connect my phone, as I wasn't sure if I was using the right method or if I needed an additional adapter. Overall, the initial setup was smooth, but some instructions could have been clearer for phone connectivity.Ohdil Mini Projector:
Setting up the Ohdil Mini Projector is relatively straightforward, though it does require some trial and error with the basic instructions provided. While it’s not overly complicated, I found that it took a bit of experimentation to navigate the settings effectively. The included remote control is essential for accessing the projector's full functionality, as the on-device controls are limited. Connecting to various devices is mainly hassle-free, particularly through HDMI, although wireless connectivity can be finicky.AKIYO Mini Projector:
Setting up the projector is remarkably straightforward. Many users appreciated the ease of connecting their devices via HDMI or utilizing wireless features like screen mirroring. The manual, while not always necessary, offers valuable insights that can enhance the user experience. However, some users encountered issues with compatibility when using certain external drives and had to ensure they were formatted correctly for the projector to read them.Conclusion
KHQ Mini Projector:
Overall Impression:After using this projector for a while, I can confidently say it offers good value for the price. It may not compete with high-end projectors, but it serves its purpose well for casual viewing, making it a great choice for family movie nights, gaming, or even projecting art. It's lightweight and easy to transport, which is a significant advantage. Despite its limitations in resolution and brightness, I appreciate its functionality and affordability, making it a worthwhile addition to my home entertainment setup.
Pros:• Compact and lightweight, making it easy to carry.
• Good image quality for indoor use in low-light conditions.
• Supports multiple connection options, including HDMI and USB.
• Wi-Fi connectivity allows for easy streaming from smart devices.
• Comes with a remote control for better usability.
• Dimmer than expected, requiring dark settings for optimal performance.
• Built-in audio is not loud enough for larger spaces.
• Setup can be a bit tricky and may require time to get right.
• Lack of adjustable feet or kickstands limits projection angles.
The Ohdil Mini Projector presents a solid entry point for those looking for an affordable and portable projection solution. While it may not compete with higher-end projectors in terms of brightness and clarity, it offers a decent experience for casual movie nights or presentations, particularly in darker settings. For its price point, it delivers a fair amount of functionality and convenience, making it a worthwhile investment for casual users or as a gift for kids. However, if you’re seeking a premium viewing experience or planning to use it outdoors frequently, you might want to consider investing in a more powerful model.
Pros:• Great picture quality, especially in low light.
• Compact and portable design.
• Easy setup and compatibility with various devices.
• Good customer service experience noted by many users.
• Included tripod adds convenience and stability.
• Occasional issues with video playback from certain devices.
• Built-in speakers lack power; external speakers recommended.
• Some users experienced overheating or connectivity issues.
• Inconsistent performance with wireless streaming.
Overall, this projector offers a solid performance for its price point, making it an excellent choice for casual movie nights or gaming. While there are known issues regarding sound quality and connectivity, the positives—such as its portability, ease of use, and customer service—make it a worthy investment for those seeking an affordable alternative to traditional televisions. Many users find it to be a fun and versatile device, ideal for both personal enjoyment and shared experiences with family and friends.
