mufcroberts
Unboxing Experience
- 1.1.1 KHQ Mini Projector:
- 1.1.2 Ohdil Mini Projector:
- 1.1.3 AKIYO Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 KHQ Mini Projector:
- 1.3.2 Ohdil Mini Projector:
- 1.3.3 AKIYO Mini Projector:
- 1.4 Features
1.5
- 1.5.1 KHQ Mini Projector:
- 1.5.2 Ohdil Mini Projector:
- 1.5.3 AKIYO Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | KHQ Mini Projector | Ohdil Mini Projector | AKIYO Mini Projector |
Picture | |||
Reference Price | $54.99 | $59.99 | $55.99 |
Recommended Uses | Indoor/Outdoor | Office, Education, Home Cinema, Gaming, Business | Indoor/Outdoor |
Built-In Media | Power Cord, User Manual, HDMI Cable, Carrying Bag | 1 x Projector Manual, 1 x Hdmi Cable, 1 x Power Adapter, 1 x Smart Projector, 1 x Remote Control (Batteries not included) | Projector Stand |
Highlight | Brightness: 1080P Full HD Size: 5.6*3.8*2.3 inches Weight: 0.75 pounds Projection Size: 21 inch to 170 inch Projection Distance: 2.3 ft to 15.7 ft (best at 6.5 ft to 9.8 ft) Inputs: HDMI, USB, AV, audio interface Compatibility: Connects with TV stick, PS4/5, Chromecast, PC, laptop (adapter required for smartphones) Service: 7x24h After-Sales Service Usage Recommendation: Not for PPT/business presentations; designed for home theater use. | Size: 5.63 * 3.78 * 2.28 inches Weight: 0.75 pounds Power Options: DC power, mobile phone charger, car charger, Micro-USB (5V / 2A support) WiFi Connectivity: Yes, compatible with Android, iPhone, Windows Screen Mirroring: Yes, via Lightning/USB/Type-C to HDMI adapter (not included) Resolution: Supports 1920*1080P, Native 800*480 Screen Size: 22-170 inches Noise Reduction: 80% fan noise reduction Audio: Built-in stereo surround speakers Compatibility: HDMI, Audio, USB ports; supports Roku, Fire TV, gaming consoles, PCs, smartphones, laptops, DVD players, USB memory sticks Included Accessories: Smart projector, manual, remote control (batteries not included), power adapter | P2P Connection: Direct connection without WiFi needed, supports iOS/Android. WiFi and Bluetooth: 5G/2.4G dual-screen WiFi, max speed 9.6G bps, Bluetooth 5.2 (no smartphone connection). Resolution: Native 720P (1280x720), supports Full HD 1080P, 200 ANSI brightness, 2000:1 contrast ratio. Size and Portability: Dimensions: 5.35x4.33x2.28 in, weight: 420 grams, fits in pocket or bag. Keystone Correction and Zoom: ±50° electronic vertical keystone correction, 50% zoom function, projection size 32-120 in, optimal distance 3.28-9.84 ft. Connectivity: HDMI, USB, 3.5mm audio output, compatible with PC, Fire Stick, PS5. Warranty and Support: 2-year warranty, 24-hour service response available. |
Unboxing Experience
KHQ Mini Projector:
The projector has a compact and portable design that makes it easy to transport and set up in various locations. Its small size is a plus, as it doesn't take up much space, and its aesthetic is quite appealing, making it a cute addition to any room. Users have noted that it looks great and is handy, which adds to its charm as a consumer electronics item.Ohdil Mini Projector:
The Ohdil Mini Projector impresses with its compact and eye-catching design, particularly the cool yellow variant that stands out. It's lightweight and portable, making it easy to carry around and set up wherever needed. The projector's build quality is decent, primarily constructed from hard plastic, which gives it a durable feel despite its low price point. The packaging is also colorful and suitable for gifting, which adds to its appeal for those considering it as a present.AKIYO Mini Projector:
Upon first glance, the projector is impressively compact and lightweight, making it easy to transport and set up in various locations. Its design is simple yet sleek, and the inclusion of a tripod adds a nice touch for stability during use. The overall aesthetic blends well with modern tech setups, making it a suitable addition to any room, whether used for movie nights or presentations.Display
Screen Size | 40 Inches - 100 Inches | 22 Inches - 170 Inches | 32 Inches - 120 Inches |
Throw Distance | 2.3 Feet - 16 Feet | 3.3 Feet - 16 Feet | 0.6 Meters - 4 Meters |
Contrast Ratio | 1000:1 | 1000:1 Pixels | 5000:1 |
Maximum Resolution | 1920 x 1080 Pixels | 1920 x 1080 Pixels | 1920*1080 Pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1280 x 720 |
Brightness | - | 1000 Lumen | 5500 Lumen |
Display Type | LCD | LED | LCD |
Picture Enhancement | Full HD | 1080P Full HD enhancement technology | Not Specified |
Viewing Experience
KHQ Mini Projector:
The viewing experience is a mixed bag. While I enjoyed projecting large images on my wall, with some setups exceeding 110 inches, the resolution left something to be desired. The clarity was lacking, especially when displaying smaller text, leading to odd outlines. It works well for casual viewing, such as watching movies or shows, but trying to read anything displayed from my computer was nearly impossible. The brightness level was also a concern, as darker scenes were hard to see, which was disappointing.Ohdil Mini Projector:
The projection quality is decent for the price, producing clear images in a dark room. However, the brightness does not compare to more expensive models, making it less effective for outdoor use or in well-lit environments. When projected onto a wall or a screen, the Ohdil Mini Projector can create a large image, with sizes ranging from 37 to 170 inches. While the focus adjustment works well, the overall image sharpness may not meet the expectations of those looking for a premium viewing experience. The built-in audio is functional, though external speakers are recommended for a more immersive experience.AKIYO Mini Projector:
The viewing experience is quite satisfactory, especially in dimmer environments. The projector delivers a clear 1080P image that looks sharp, making movie nights enjoyable. However, I did notice some light artifacts, which are common in projectors within this price range. The sound quality was surprisingly decent for a built-in speaker, but I would recommend using external Bluetooth speakers for an enhanced audio experience, especially during action-packed films.Features
Other Features | 轻巧 | Built-In Speaker, Outdoor / Indoor Portable, Mini Projector for All Smartphone, Portable,Zoom 50%-100%, Wi-Fi ,HDMI ,Screen Mirroring ,Maximum 170" projection ,HD 1080P Supported | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi |
Video Encoding | AVC | AVC | AVC |
Lamp Wattage | 60 Watts | - | 3 Watts |
LightSource Life | 50000 Hours | - | 55000 Hours |
Controller Type | Button Control | iOS,Android | Button Control |
Control Method | Touch | Remote | App |
Connectivity Technology | HDMI | Wi-Fi, HDMI | Wireless |
Compatible Devices | Laptop, Gaming Console, Television, Tablet, Smartphone | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet |
Wattage | 2 watts | - | 38 Watt-hours |
Mount Type | Tabletop Mount | Floor Mount/Ceiling Mount/Tabletop Mount/Tripod Mount/Wall Mount | Tabletop Mount |
L x W x H | 5.6"L x 2.3"H | 5.63"L x 3.78"W x 2.28"H | 5.35"L x 4.33"W x 2.28"H |
KHQ Mini Projector:
Setting up the projector was a breeze for me. I was able to quickly connect my devices, including my Amazon Fire Stick and computer, using the included HDMI cables. The remote control made navigation seamless, and the instructions were straightforward, allowing me to get everything running without any hiccups. However, I did encounter a slight challenge when trying to connect my phone; I suspect I might not have followed the instructions accurately, as it requires a specific connector that doesn't come included.Ohdil Mini Projector:
Setting up the Ohdil Mini Projector was straightforward, though it did require a bit of trial and error to navigate the various settings. The basic instructions provided were not the most detailed, which could lead to some confusion for first-time users. However, for those familiar with projectors, the setup process is relatively easy, especially when using the included remote control for better navigation. The projector offers multiple connectivity options, including HDMI, USB, and wireless screen mirroring, which enhances its versatility.AKIYO Mini Projector:
Setting up the projector is remarkably straightforward. I found that connecting it to multiple devices, including my iPad, laptop, and smartphone, was a breeze. The HDMI connectivity with my devices worked seamlessly, and screen mirroring from my Android phone was also effective. The user manual, while not strictly necessary, provided helpful tips and ensured that I could maximize the projector's potential right from the start.Conclusion
KHQ Mini Projector:
Pros:• Compact and portable design
• Easy setup and connectivity with devices
• Great sound quality for its size
• Large projection size enhances viewing experience for casual use
• Good value for the price
• Low resolution leads to blurry images
• Dark scenes are difficult to see clearly
• Can get loud during use
• Limited options for adjusting brightness and contrast
Overall, I think this projector provides decent value for its price. While it has its limitations in terms of resolution and brightness, it excels in portability and ease of use. It's perfect for casual movie nights or presentations, especially if you're not overly concerned with achieving perfect picture quality. For anyone looking for an affordable and functional projector for home use, this could be a solid choice, but those seeking high-definition clarity might want to look elsewhere.
Pros:• Compact and lightweight design makes it highly portable.
• Easy setup with multiple connectivity options (HDMI, USB, Wi-Fi).
• Decent picture quality and sufficient brightness for dark environments.
• Includes a remote control for more convenient navigation.
• Affordable price point for a mini projector.
• Brightness may not be sufficient for outdoor or well-lit use.
• Built-in speakers are not very loud; external audio is recommended.
• Setup instructions could be more detailed for first-time users.
• Picture sharpness may disappoint those expecting high-end quality.
• A lack of adjustable feet or kickstands limits projection angles.
The Ohdil Mini Projector is a solid choice for those seeking an affordable, portable projection solution for casual viewing or small gatherings. While it may not deliver the brightness or sharpness of higher-end models, it serves its purpose well for indoor movie nights and presentations. Its compact size, ease of setup, and multiple connectivity options make it a versatile gadget for various scenarios. If you're looking for a budget-friendly option without high expectations for picture quality, this projector could be a great addition to your tech collection.
Pros:• Compact and lightweight design.
• Easy setup and connectivity with multiple devices.
• Clear 1080P image quality in dim lighting.
• Decent sound from built-in speakers.
• Includes a tripod for stability.
• Excellent customer service experience.
• Potential connectivity issues when streaming wirelessly.
• Occasional light artifacts in projection.
• Built-in speakers may not satisfy audiophiles.
• Some devices may require additional adapters for HDMI connections.
• Can get hot after prolonged use.
Overall, this mini projector offers impressive performance for its price and is perfect for casual viewing experiences. Its compact nature, ease of use, and solid image quality make it an excellent choice for movie nights or gaming sessions. While there are a few downsides, such as occasional connectivity issues and average built-in sound quality, the positives far outweigh the negatives. I wholeheartedly recommend this projector to anyone looking for an affordable and versatile projection solution.
