Unboxing Experience
- 1.1.1 ARTSEA Mini Projector:
- 1.1.2 AKIYO Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 ARTSEA Mini Projector:
- 1.3.2 AKIYO Mini Projector:
- 1.4 Features
1.5
- 1.5.1 ARTSEA Mini Projector:
- 1.5.2 AKIYO Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | ARTSEA Mini Projector | AKIYO Mini Projector |
Reference Price | $39.99 | $65.99 |
Recommended Uses | Education, Home Cinema, Gaming, Business | Indoor/Outdoor |
Built-In Media | User Manual, Power Cord, Projector Lens Cover, Remote, HDMI Cable | Projector Stand |
Highlight | Device Compatibility: iPhone/Android casting, requires Type C to HD cable or 3 in 1 HD cable adapter (not included), must support Multi-screen/wireless display. Dimensions: 6.6 x 4.7 x 2.5 inches Weight: Approximately 2 pounds Projection Size: 30 to 200 inches Projection Distance: 2.7ft to 18ft Bulb Lifespan: Up to 55,000 hours Noise Reduction: Fan noise reduced by 80% Audio: Built-in stereo speakers, supports external speakers Connectivity: HDMI, 3.5mm audio, USB interfaces Portability: Compact design for easy transport Content Restrictions: Apps like Netflix, Prime Video, Hulu require TV Stick or Roku Support: 3 years factory support Recommended Use: Home theater experience, not ideal for PPT or business presentations. | Native Resolution: 1280*720P Supported Resolution: Full HD 1080P Brightness: 200 ANSI Contrast Ratio: 2000:1 Size: 5.35*4.33*2.28 in Weight: 420 grams Keystone Correction: ±50° electronic Zoom Function: 50% Projection Screen Size: 32-120 in Optimal Projection Distance: 3.28-9.84 feet Connection Type: P2P Direct Connection (no WiFi required) Input Interfaces: HDMI, USB, 3.5mm audio output Warranty: 2 years Tech Support: 24H service response |
Unboxing Experience
The ARTSEA Mini Projector is impressively compact and visually appealing, making it a charming addition to any space. Its lightweight design makes it effortlessly portable, allowing me to easily transport it for various events, whether it’s a backyard movie night or a business presentation. The projector's aesthetic is simple yet functional, fitting well into both casual and professional environments.AKIYO Mini Projector:
The AKIYO Mini Projector has a compact design that surprises me with its small size, roughly equivalent to that of a large watch box. Unboxing it revealed a surprisingly lightweight device that looks more substantial in the promotional images. It comes with a small tripod, which adds to its versatility for different placement options, whether on a table or mounted on the ceiling. The aesthetic is simple and functional, making it suitable for both home and portable use.Display
Screen Size | 20 Inches - 200 Inches | 32 Inches - 120 Inches |
Throw Distance | 2.7 Feet - 18 Feet | 0.6 Meters - 4 Meters |
Contrast Ratio | Standard | 5000:1 |
Maximum Resolution | 1280 x 720 Pixels | 1920*1080 Pixels |
Native Resolution | 1280 x 720 | 1280 x 720 |
Brightness | - | 5500 Lumen |
Display Type | LCD | LCD |
Picture Enhancement | - | Not Specified |
Viewing Experience
The viewing experience exceeded my expectations, especially given the price point. The picture quality is surprisingly sharp and vivid, even in less-than-ideal lighting conditions. I enjoyed watching movies and playing games on a large scale, with images that brought every detail to life. The internal speaker provided satisfactory sound quality, though I found external Bluetooth speakers had a noticeable lag, which detracted slightly from the overall experience. Nonetheless, the projector performed admirably for casual viewing, especially during movie nights with family and friends.• **Pros**:
- Outstanding picture quality for the price
- Portable and lightweight design
- Easy setup and seamless connectivity
- Great for both indoor and outdoor use
• **Cons**:
- No keystone correction available
- Bluetooth audio can lag
- Limited compatibility with major streaming services
The viewing experience has been quite enjoyable, especially in dim conditions where the projector shines. With the lights off, the brightness is impressive for its price point, producing a clear picture quality that rivals some higher-end models. I found that the image clarity remained satisfactory when screen mirroring from my tablet or phone, although I did notice some light artifacts typical of entry-level projectors. For the best results, a direct HDMI connection proved to be the most reliable method, eliminating any lag I experienced with wireless streaming.Features
Other Features | Built-In Speaker, Dust-Proof, Portable, Lightweight | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi |
Video Encoding | AVC | AVC |
Lamp Wattage | - | 3 Watts |
LightSource Life | 5.5E+4 Hours | 55000 Hours |
Controller Type | - | Button Control |
Control Method | - | App |
Connectivity Technology | HDMI | Wireless |
Compatible Devices | Laptop, Gaming Console, Tablet, Smartphone | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet |
Wattage | - | 38 Watt-hours |
Mount Type | Floor Mount/Ceiling Mount/Floor Mount/Tabletop Mount/Tripod Mount/Wall Mount | Tabletop Mount |
L x W x H | 6"L x 4"W x 2"H | 5.35"L x 4.33"W x 2.28"H |
Setting up the ARTSEA Mini Projector was a breeze, thanks to its intuitive controls and straightforward connectivity options. I had no trouble connecting it to my laptop via HDMI, and the Bluetooth feature, while a bit misleading, still added convenience for audio connections. The manual focus ring and electronic zoom allowed for quick adjustments, ensuring I could achieve a clear image with minimal effort. However, the absence of keystone correction can be a drawback, requiring precise placement for optimal viewing.AKIYO Mini Projector:
Setting up the projector was generally straightforward, requiring minimal effort to connect my devices. I appreciated the included manual, which I skimmed through to ensure I didn’t miss any features. The projector offers various connection options, including HDMI, USB, and Bluetooth, which allows for a seamless experience when linking to laptops, smartphones, and gaming consoles. However, I encountered some challenges when trying to connect certain newer devices, particularly those that only support USB-C, leading to some hiccups in connectivity.Conclusion
Overall Impression:Overall, the ARTSEA Mini Projector is a fantastic value for anyone seeking an affordable, portable projector. Despite a few limitations, such as the lack of keystone correction and streaming app compatibility, it truly shines in delivering a quality viewing experience without breaking the bank. Its combination of user-friendly design, portability, and impressive picture quality makes it a standout choice for movie enthusiasts and casual users alike. I wholeheartedly recommend this projector to anyone looking to elevate their entertainment setup, as it provides a delightful experience at an unbeatable price.
Pros:• Great projection quality using HDMI
• Compact and portable design
• Easy setup and connectivity options
• Good picture quality in low-light conditions
• Decent sound quality when connected to Bluetooth speakers
• Includes a tripod for versatile placement
• Built-in speakers lack power
• Potential connectivity issues with newer devices
• Bluetooth audio can experience lag
• May require specific video file formats for USB playback
• Not suitable for bright environments
Overall, the AKIYO Mini Projector has proven to be a solid investment for casual movie nights and gaming sessions. While it doesn’t compete with high-end projectors, it offers excellent value for its price, especially for those who require portability and versatility. Despite a few minor drawbacks, such as sound quality and the need for specific connections, I find it to be a worthwhile addition to my entertainment setup, particularly for its ease of use and impressive image quality in the right conditions.
