Unboxing Experience
- 1.1.1 Adorezyp Mini Projector:
- 1.1.2 AKIYO Mini Projector:
- 1.1.3 antmap Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Adorezyp Mini Projector:
- 1.3.2 AKIYO Mini Projector:
- 1.3.3 antmap Mini Projector:
- 1.4 Features
1.5
- 1.5.1 Adorezyp Mini Projector:
- 1.5.2 AKIYO Mini Projector:
- 1.5.3 antmap Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | Adorezyp Mini Projector | AKIYO Mini Projector | antmap Mini Projector |
Picture | |||
Reference Price | $52.99 | $49.99 | $59.49 |
Recommended Uses | Movies, Mobile Content, Cartoons | Indoor/Outdoor | Education, Home Cinema, Gaming, Business |
Built-In Media | Projector, User Manual, Usb Cable | Projector Stand | User Manual, Power Cord, Remote, HDMI Cable |
Highlight | Resolution: HD1080P Projection Angle: 180° rotatable Usage: Portable mobile home theater Recommended Screen Size: 60 inches Audio: Built-in Hi-Fi speakers, BT 5.0 support Bluetooth Limitations: No smartphone/laptop connection for projection Portability: Small and convenient for carrying Ideal Use Cases: Movies, TV shows, photo slideshows, video games Not Recommended For: PPT or business presentations | Connectivity: P2P direct connection, 5G/2.4G dual-screen WiFi, Bluetooth 5.2 (not for smartphones) Resolution: Native 720P (1280*720), supports Full HD 1080P Brightness & Contrast: 200 ANSI lumens, 2000:1 contrast ratio Size & Weight: 5.35*4.33*2.28 in, 420 grams Keystone Correction: ±50° electronic vertical keystone, ±20° side scroll wheel support Zoom: 50% zoom function Projection Size & Distance: Supports 32-120 in screen size, optimal distance 3.28-9.84 feet Input Interfaces: HDMI, USB, 3.5mm audio output jack Warranty & Support: 2-year warranty, 24H service response available | Resolution: 1920*1080P Brightness: Excellent Contrast Ratio: High dynamic Audio: Built-in 3W stereo speakers, Bluetooth 5.1 WiFi Connectivity: 2.4G and 5G dual WiFi Projection Size: 35-200 inches Projection Distance: 3.3-17 ft Keystone Correction: 17° Ports: USB, HDMI, micro USB, earphone, power input Compatibility: Amazon Fire TV, USB, DVD player, laptops, iOS/Android devices, headphones, external speakers, PS4 Use Case: Indoor & outdoor, streaming services like Prime Video, Netflix |
Unboxing Experience
The mini projector boasts a compact and portable design, making it an attractive choice for those who value convenience. Its lightweight build allows for easy transportation, whether it’s moved from room to room or taken outdoors. The overall appearance is sleek, and it fits well in various settings, from a child’s bedroom to a backyard movie night. However, the size also hints at its limitations, as it feels more like a toy than a professional-grade projector.AKIYO Mini Projector:
Upon first glance, this mini projector strikes me as a compact and unassuming device, perfect for casual use. Its small size makes it easy to place almost anywhere, whether on a table or mounted to the ceiling. The design is straightforward, and it doesn’t draw too much attention, allowing it to blend seamlessly into different environments. The included tripod is a thoughtful addition, providing stability during use. Overall, the projector has a practical aesthetic that aligns well with its budget-friendly pricing.antmap Mini Projector:
The projector has a compact and modern design, resembling a medium-sized book, which makes it highly portable and easy to store. Its sleek appearance fits well in various settings, whether it's on a shelf, a tripod, or the headboard of a bed. Despite some functionality issues with remote controls or setup, the overall aesthetic is pleasing, contributing to a minimalist look that doesn't clutter your space.Display
Screen Size | 20 Inches - 120 Inches | 32 Inches - 120 Inches | 50 Inches - 200 Inches |
Throw Distance | 3 Feet - 10 Feet | 0.6 Meters - 4 Meters | 3.28 Feet - 17.06 Feet |
Contrast Ratio | 1000.0:1 | 5000:1 | High |
Maximum Resolution | 1080P support | 1920*1080 Pixels | 1920 x 1080 Pixels |
Native Resolution | 1920 x 1080 | 1280 x 720 | 1280 x 720 |
Brightness | 100.0 lumens | 5500 Lumen | - |
Picture Enhancement | Hd 1080p | Not Specified | - |
Viewing Experience
The viewing experience can vary greatly depending on the environment and expectations. While the 180° rotation feature and auto keystone correction are impressive, ensuring a straight and clear image, the actual picture quality is where things fall short. Many users noted that the resolution appears closer to 640x480 rather than the advertised 1280x720, leading to pixelation and a less immersive experience, especially on larger screens. However, in dimly lit spaces, the video quality can be satisfactory for casual viewing.AKIYO Mini Projector:
The viewing experience has been pleasantly surprising for a projector in this price range. When the lights are off, the image is bright and clear, producing a decent picture quality that is quite impressive for a $45 device. I found it particularly effective for watching movies and gaming in dimly lit rooms. While there are some light artifacts and occasional lag when streaming wirelessly, using a direct HDMI connection significantly enhances stability and reduces interruptions. The digital zoom feature is a nice touch, allowing for adjustments without compromising image quality.antmap Mini Projector:
The picture quality is often highlighted as a standout feature, with many users praising the brightness and clarity, particularly in low-light conditions. The 400 ANSI lumens allow for decent visibility even with some ambient light, although the projector excels in darker environments. Users reported satisfaction with the image sharpness, especially when using DVDs or Blu-ray discs. However, the viewing experience can vary depending on the setup, with some users needing to adjust the projector's position for optimal focus and angle.Features
Other Features | Portable, Hd Support, Mini Size | 1080P Supported, 50% Zoom, ±50° Electronic Keystone Correction, Tripod Included, 5G WiFi | Built-In Speaker, Portable, Two-way Bluetooth 5.2, Built-In Cooling System, WiFi Connection |
Video Encoding | AVC | AVC | H.264 or H.265 |
Lamp Wattage | 10 Watts | 3 Watts | - |
LightSource Life | 30000 Hours | 55000 Hours | 30000 Hours |
Controller Type | Remote | Button Control | Button Control |
Control Method | Remote | App | Remote, Touch |
Connectivity Technology | USB, HDMI | Wireless | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack |
Compatible Devices | Laptop, Usb Devices, Speaker | Television, Gaming Console, Speaker, Laptop, Smartphone, Tablet | Laptop, Gaming Console, Tablet, Smartphone, Speaker |
Wattage | 15 watts | 38 Watt-hours | - |
Mount Type | Tabletop Mount | Tabletop Mount | Tabletop Mount |
L x W x H | - | 5.35"L x 4.33"W x 2.28"H | 6.81"L x 5.47"W x 2.76"H |
Setting up this mini projector is a breeze, as it is user-friendly and intuitive. I was able to start streaming content within minutes, which is a huge plus for spontaneous movie nights. The connectivity options, including Bluetooth and Wi-Fi, make it easy to link my devices for seamless viewing. However, the placement of the HDMI input on the back can be inconvenient, especially when angling the projector for ceiling displays. Additionally, some users found the instructions lacking, which can be frustrating when troubleshooting.AKIYO Mini Projector:
Setting up the projector was relatively simple, even for someone who isn’t tech-savvy. I appreciated that it came with a manual, which I found helpful despite already being familiar with the device. The projector easily connects to various devices, including laptops and smartphones, using HDMI or screen mirroring. However, I did encounter minor issues with specific devices, particularly with newer MacBooks and gaming consoles like the Switch. Once I figured out the right connections, getting it to work with my devices was straightforward, making it convenient for spontaneous movie nights.antmap Mini Projector:
Setting up the projector is generally straightforward, as many users noted the ease with which they were able to connect devices, especially with HDMI. The built-in WiFi and Bluetooth features add significant convenience, allowing for wireless streaming from phones and tablets. However, some users experienced difficulties with screen mirroring, particularly with Apple devices, which could be frustrating. The detailed instructions provided in the handbook are helpful, although some found the interface to be less intuitive.Conclusion
Pros:- Compact and portable design ideal for various settings.
- Easy setup with Bluetooth and Wi-Fi connectivity.
- 180° rotation and auto keystone correction for flexible viewing angles.
- Sufficient sound for small to medium-sized rooms.
- Picture quality is subpar, often pixelated and lacking brightness.
- HDMI input placement is inconvenient for certain setups.
- Limited functionality when it comes to advanced features; more suited for casual use.
This mini projector is a mixed bag. It excels in portability and is perfect for casual use, especially for kids or outdoor movie nights. However, those seeking high-quality resolution or a robust projector experience may be disappointed. It serves well as a budget-friendly option for occasional viewing, but if you're looking for something more reliable and high-tech, investing in a more advanced model might be worth considering.
Pros:• Great projection quality using HDMI
• Good picture quality for screen mirroring from mobile devices
• Easy setup and operation
• Compact and portable design
• Customer service is responsive and helpful
• Bluetooth connectivity for external speakers
• Inbuilt speakers lack power, requiring external speakers for better sound
• Occasional connectivity issues with newer devices
• Light artifacts present, especially in bright conditions
• Bluetooth audio lag cannot be adjusted
• Can get hot during prolonged use
In conclusion, this projector has exceeded my expectations considering its low cost. It offers solid performance, user-friendly setup, and decent picture quality that makes it a great choice for casual use, such as movie nights or gaming sessions. While it does have its limitations, particularly regarding sound and connectivity with newer devices, the pros far outweigh the cons. For anyone seeking an affordable and versatile projector, I wholeheartedly recommend this device. It's proven to be a hit in my household, and the value for money is exceptional.
Pros:• Bright and clear image quality, especially in low light.
• Compact and portable design.
• Built-in WiFi and Bluetooth for easy connectivity.
• User-friendly interface and setup instructions.
• Good value for the price.
• Limited performance in bright environments.
• Some difficulties with screen mirroring.
• Sound quality could be improved; external speakers recommended.
• Occasional connection issues with devices.
• Some users experienced overheating and other minor technical issues.
Overall, this projector offers great value for its price, combining decent image quality with the convenience of portability. While it may not meet the needs of users looking for premium performance in bright settings or with complex streaming setups, it excels as a budget-friendly option for casual viewing, movie nights, and even presentations. For those who prioritize ease of use and portability, this projector is a solid choice worth considering.
