Stefani
The biggest difference between smart TV and mobile devices lies in the interactive mode. Because of the viewing distance, smart TV cannot be controlled by touch screen, but by remote control. So what does a smart TV remote look like? What are the characteristics of each?
1. Eleven key remote control
The 11 keys of this remote control are: power, up, down, left, right, OK, home, back, menu, volume +, volume -. This remote control is undoubtedly a great improvement over the traditional one. The strip shape is ideal for holding in one hand, with fewer buttons and a sharp layout that allows users to use the remote without looking at it.
2. Old-fashioned remote control
This kind of remote is pretty big and don't support bluetooth. Sometimes I feel it has more buttons than a keyboard.
3. Voice Remote Control
More and more remote controls on the market now have voice capabilities, represented by the Roku TV remote. I believe there will be more remote controls to support voice in the future, because now the major manufacturers are focusing on artificial intelligence, voice assistants, intelligent ecosystems and so on
4. Sony Huis
At home, whether you also face such a problem: many remote controller east a west, whether it is to put or find is a troublesome thing. Besides, many remote controllers are the same length, and there are many ones that bump faces and bump shirts. At this time, you need a universal remote controller, such as the Sony Huis.
The design of Sony Huis is simple, pure white color, with the design style of Sony. This intelligent remote controller USES an e-ink screen. The e-ink electronic paper screen has very low power consumption and can maintain the display of the screen. Another advantage is that it's easy to read, e-ink looks more like printed text, it makes the eye easier. The Sony Huis is also programmable, which is why it controls all the smart devices in your home, which is what makes it so cool.
4. Sony Huis
