Xiaomi Full-color Laser Cinema Projector, Is it good?
BigZ
  1. 1 1. Specs
  2. 2 2. Highlights
Xiaomi Full-color Laser Cinema projector is an ultra-short-throw projector released by Xiaomi Home, with a product size of 402x2685x85mm, net weight of 5.8kg, light source technology panchromatic laser light source, standard resolution of 1920x1080.
1. Specs​
  • Product name: Xiaomi XMJGYY01YS
  • Product Code:100035779534
  • The gross weight of goods:8.02kg
  • Product origin: China
  • Video interface: HDMI 2.1
  • Display technology: LCOS
  • Standard resolution: 1080P
  • Power type: power supply
  • MEMC: Support MEMC
  • Display chip size: Other
  • Color: White
2. Highlights​
1. LCOS, 1400 ANSI Lumen.
2. Adopt a wide color gamut light source, presenting rich colors.
3. RGB tricolor laser light source direct projection imaging, higher brightness, more vivid colors.
4. Authoritative certification, lower blue light through the SGS low blue light certification.
5. Ultra-short throw length lens design significantly reduces the projection distance.
6. Dual certification by DTS and Dolby, bringing high fidelity and high dynamic acoustic performance across the full frequency range.
7. Multi-dimensional dynamic noise reduction technology, auxiliary MEMC motion compensation
For the Xiaomi Full-color Laser Cinema Projector Review
Jacinthe95
The illumination is insufficient. With clearly labeled menus, simple navigation options, and helpful prompts along the way, the Linebet App https://lnbtbet.com/app/ makes it seamless for users to navigate through the different sections, access their account details, and explore the diverse range of betting options available.
berrisonkaden
The Xiaomi Full-color Laser Cinema Projector has received positive reviews for its impressive features, including its vibrant full-color laser projection and high-resolution display. Users have praised its brightness, clarity, and immersive viewing experience. However, like any product, its suitability depends on individual preferences and needs resultados del tris. It's a good idea to read detailed reviews and compare it with other projectors to determine if it meets your requirements.
