mtn328
I don't know if you've ever met situation like when you have a foreign app installed on your Fire TV Stick, but the network speed drives you crazy. Actually the problem doesn't lie in your network but depend a lot on the server of that app.
Because the app server is not in your country so you might fail to connect it. So you need VPN. I'll give you a vid tutorial on how to use VPN on Fire TV Stick.
If you have issues like that, you may as well try this.
