- 1 Why Your Fire TV Remote Might Need Re-Pairing
- 2 Method 1: How to Pair a Fire TV Remote During Initial Setup
- 3 Method 2: Pair a Replacement Fire TV Remote from Settings
- 4 Method 3: How to Pair a Fire TV Remote Without the Old Remote
- 5 Fire TV Remote Not Pairing? Troubleshooting Tips
- 6 How to Pair a Second Fire TV Remote (For Multiple Users)
- 7 How to Use Fire TV Without a Remote (Temporary Solution)
- 8 Can You Pair a Third-Party Remote with Fire TV?
- 9 FAQ: Pairing Fire TV Remote
- 10 Final Thoughts
- 11 Related Reading
If you're wondering how to pair a Fire TV remote, whether it's new, replaced, or simply disconnected, this complete guide walks you through everything you need to know. Whether you’re using a Fire TV Stick, Fire TV Cube, or Fire TV Edition Smart TV, these step-by-step methods will help you re-pair your remote in minutes.
Before we jump into the solutions, here are the most common situations that require you to pair your Fire TV remote:
Understanding the reason helps you choose the correct pairing method.
If you're unboxing a brand-new Fire TV Stick or Fire TV Cube, follow these steps:
Steps:
Tip: Stay within 10 feet of your Fire TV device and ensure there’s no obstruction between them.
Already using Fire TV but bought a new remote? Follow this method if you still have access to the screen via your current remote or the Fire TV app.
Instructions:
This method works for both first-party Amazon remotes and some third-party compatible models.
Lost your original remote? No worries—you can still pair a new one using the Amazon Fire TV app.
What You Need:
Steps:
If your Fire TV remote won't connect, try these common fixes:
Still stuck? Visit Settings > Controllers & Bluetooth Devices to remove old remotes and start fresh.
Want to give another person remote access?
You can pair up to seven remotes to a single Fire TV.
This is useful for shared households or gaming setups.
Lost your remote and waiting for a replacement? Here’s what to do:
Note: Your Fire TV and phone must be on the same Wi-Fi network for this to work.
Yes, Fire TV supports many Bluetooth remotes and universal remotes. To pair:
If the remote is paired successfully, pressing the Home button will return you to the Fire TV main screen, and a message may appear confirming pairing.
Fire TV doesn’t allow “unpairing” directly, but you can remove a remote: Go to Settings > Amazon Fire TV Remotes, select the one you want to remove, and follow on-screen steps.
Try changing the batteries, resetting the remote, updating your Fire TV software, or moving other electronic devices that might cause Bluetooth interference.
Whether you're setting up a new device, replacing a lost controller, or just troubleshooting connection issues, learning how to pair a Fire TV remote is straightforward with the right steps. With these proven methods—ranging from physical pairing to app-based solutions—you can easily reconnect and enjoy your streaming experience without interruption.
If you found this guide helpful, share it with others who might be struggling with their Fire TV remote. Still have questions? Drop them below, and we’ll help troubleshoot.
How to Connect Firestick Remote to TV
How to Connect Firestick Remote to TV? Easy Steps
- You’ve purchased a replacement Fire TV remote
- Your original remote stopped responding
- You’ve reset your Fire TV device to factory settings
- You're setting up a second remote for easier access
- You've recently changed batteries or experienced a disconnection
Steps:
- Plug your Fire TV Stick or Cube into your TV’s HDMI port.
- Connect the power adapter and turn on the TV.
- Insert new AAA batteries into the remote.
- Wait — the remote should pair automatically.
- If it doesn’t:
- Press and hold the Home button for 10 seconds.
- When successful, a message will appear: “Your remote is now connected.”
Instructions:
- Go to Settings > Controllers & Bluetooth Devices > Amazon Fire TV Remotes > Add New Remote
- Press and hold the Home button on your new remote for 10 seconds.
- The new remote should appear in the list.
- Use your old remote to select it and confirm pairing.
What You Need:
- A smartphone (iOS or Android)
- The Amazon Fire TV app
- Access to the same Wi-Fi network as your Fire TV device
Steps:
- Download the Fire TV app from the App Store or Google Play.
- Connect your phone to the same Wi-Fi network as the Fire TV.
- Open the app and select your Fire TV device.
- Use the virtual remote in the app to go to:
Settings > Controllers & Bluetooth Devices > Amazon Fire TV Remotes > Add New Remote - On your new remote, hold the Home button for 10 seconds.
- Select the new remote from the list using the app interface.
- Replace the batteries (use fresh, high-quality AAA)
- Power cycle your Fire TV:
Unplug it from power > Wait 30 seconds > Plug it back in - Reset the Fire TV remote:
- Press Left + Menu + Back for 10 seconds (for Alexa Voice Remotes)
- Try pairing via the Fire TV app
- Remove any potential Bluetooth interference (microwaves, metal objects, etc.)
- On your Fire TV, go to:
Settings > Controllers & Bluetooth Devices > Amazon Fire TV Remotes > Add New Remote - Hold the Home button on the new remote for 10 seconds.
- Once detected, confirm pairing.
- Download the Amazon Fire TV app
- Use your smartphone as a fully functional remote (directional pad, Alexa, playback)
- Works over Wi-Fi, not Bluetooth
- Navigate to
Settings > Controllers & Bluetooth Devices > Other Bluetooth Devices - Enable pairing mode on the third-party device
- Select the device name from the list and confirm
How do I know if my Fire TV remote is paired?
How do I unpair a Fire TV remote?
My Fire TV remote keeps disconnecting. What should I do?
Final Thoughts
Related Reading
How to Reset Firestick Without Remote?How to Connect Firestick Remote to TV
