BigZ
Many users are confused about how to choose a 4K TV, here's a comparison of 4 tv at the same price level. Samsung AU8000 VS. LG UP8000 VS. Samsung AU8000 VS. Sony X80J TV, you may check which one is more suitable for you.
I chose the size of 50" and 55", and the prices are at the same level.
model name | Samsung AU8000 50" | LG UP8000 55" | Samsung AU8000 55" | Sony X80J 50" |
price | $529.99 | $566.99 | $597.99 | $698.00 |
Size | 49.5" | 54.5" | 54.6" | 49.5" |
Display Technology | LCD | LCD | LCD | LCD |
Aspect Ratio | 16:09 | 16:09 | 16:09 | 16:09 |
Resolution | 3840 x 2160 | 3840 x 2160 | 3840 x 2160 | 3840 x 2160 |
Maximum Brightness | Not Applicable | Not Specified | Not Applicable | Not Specified |
Lighting System | Not Applicable | Backlit LED | Not Applicable | Backlit LED |
HDR Compatibility | HDR10, HDR10+, Hybrid Log Gamma | HDR10, Hybrid Log Gamma | HDR10, HDR10+, Hybrid Log Gamma | HDR10, Dolby Vision, Hybrid Log Gamma |
Video System | NTSC | NTSC | NTSC | NTSC |
TV Tuner | ATSC, Clear QAM | ATSC, Clear QAM | ATSC, Clear QAM | ATSC 3.0, Clear QAM |
Input Ports | 3 x HDMI Type A 1 x F-Type (RF Antenna) | 2 x HDMI Type A (Side) 1 x HDMI Type A (Rear) 1 x F-Type (RF Antenna) (Rear) | 3 x HDMI Type A 1 x F-Type (RF Antenna) | 4 x HDMI Type A (Side) 1 x F-Type (RF Antenna) 1 x 1/8" / 3.5 mm (Composite) (Side) |
Output Ports | 1 x TOSLINK Optical (Digital Audio) | 1 x TOSLINK Optical (Digital Audio) | 1 x TOSLINK Optical (Digital Audio) | 1 x TOSLINK Optical (Digital Audio) (Side) 1 x 1/8" / 3.5 mm (Headphone) (Side) |
Audio Return Channel (ARC) | Not Applicable | eARC | Not Applicable | ARC, eARC |
Wi-Fi | Wi-Fi 5 (802.11ac) | Wi-Fi 5 (802.11ac) | Wi-Fi 5 (802.11ac) | Wi-Fi 5 (802.11ac) |
Bluetooth | Bluetooth 4.2 (Keyboard) | Bluetooth 5.0 (Audio Output) | Bluetooth 4.2 (Keyboard) | Bluetooth 4.2 (Keyboard, Audio Output) |
USB Ports | 2 x USB 2.0 (Audio, Photo, Video) | 1 x USB 2.0 (Side) 1 x USB 2.0 (Rear) | 2 x USB 2.0 (Audio, Photo, Video) | 2 x USB (Version Unspecified) (Audio, Photo, Video) (Side) |
Power | 20 W | 20 W | 20 W | 20 W |
Virtual Assistant Support | Amazon Alexa, Google Assistant, Samsung Bixby | Amazon Alexa, Apple Siri, Google Assistant | Amazon Alexa, Google Assistant, Samsung Bixby | Google Assistant |
Wall Mounting | 200 x 200 mm | 300 x 300 mm | 200 x 200 mm | 200 x 200 mm |
Weight | 25.4 lb / 11.5 kg (Without Stand) 26.9 lb / 12.2 kg (With Stand) | 30.9 lb / 14 kg (Without Stand) 31.3 lb / 14.2 kg (With Stand) | 34.2 lb / 15.5 kg (Without Stand) 35.7 lb / 16.2 kg (With Stand) | 27.1 lb / 12.3 kg (Without Stand) |
Dimensions | 44 x 25.4 x 1" / 1118.3 x 644.5 x 25.7 mm (Without Stand) 44 x 27 x 8.9" / 1118.3 x 684.6 x 226.6 mm (With Stand) | 48.6 x 28.1 x 2.3" / 123.4 x 71.4 x 5.8 cm (Without Stand) 48.6 x 30.4 x 9.1" / 123.4 x 77.2 x 23.1 cm (With Stand) | 48.5 x 27.9 x 1" / 1232.1 x 708.8 x 25.7 mm (Without Stand) 48.5 x 29.9 x 8.9" / 1232.1 x 758.8 x 226.6 mm (With Stand) | 44.3 x 25.7 x 2.8" / 1126 x 653 x 70 mm (Without Stand) 44.3 x 28.3 x 11.3" / 1126 x 718 x 286 mm (With Stand) |
