Hardon Williams
Unboxing Experience
- 1.1.1 PONER SAUND Mini Projector:
- 1.1.2 Alwtniet Smart Projector:
- 1.1.3 ear&ear Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 PONER SAUND Mini Projector:
- 1.3.2 Alwtniet Smart Projector:
- 1.3.3 ear&ear Mini Projector:
- 1.4 Features
1.5
- 1.5.1 PONER SAUND Mini Projector:
- 1.5.2 Alwtniet Smart Projector:
- 1.5.3 ear&ear Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | PONER SAUND Mini Projector | Alwtniet Smart Projector | ear&ear Mini Projector |
Picture | |||
Reference Price | $45.88 | $84.99 | $59.99 |
Recommended Uses | 家庭影院,教育,游戏 | Education, Home Cinema, Gaming, Business | Education, Home Cinema, Gaming, Business |
Built-In Media | remote control, GP16 Projector, Power Cable, HDMI Cable, 3 in 1 AV Cable | Adapter | User Manual, Power Cord, Remote |
Highlight | Wireless Connection: Multi-screen interaction, compatible with iOS and Android, no extra cables needed Resolution: 1280x720P native, supports 1920x1080P Brightness: 5500 lumens Contrast Ratio: 5500:1 Aspect Ratio: 16:9/4:3 Screen Size: 40” to 210” Projection Distance: 5ft to 15ft, recommended at 6.5ft Dimensions: 7.87*5.90*2.95 inches Weight: 2.5 lbs Built-in Speaker: Yes Connectivity Options: HDMI, USB, AV, headphone Customer Service: Lifetime customer service | Streaming Capability: Built-in TV OS with access to over 1,000,000 videos and licensed apps (Netflix, Prime Video, YouTube) Resolution: Native 1080P, 4K support Brightness: 320 ANSI lumens Contrast Ratio: 10,000:1 Image Alignment: Automatic vertical correction, 4-point keystone adjustment Connectivity: WiFi 6, Bluetooth 5.2, HDMI and USB ports Operating System: Whale OS with app download capability | Operating System: Android TV 13.0 Content Library: Over 500,000 movies and TV shows Graphics Processing Unit: Mali-G31 Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G and 5G networks Projection Angle: 180° rotational Auto Keystone Correction: Yes Resolution Support: 1080P/4K Brightness: 200 ANSI lumens Contrast Ratio: 1500:1 Surround Sound: 360-degree built-in system Noise Level: Below 25 dB Ports: HDMI, USB, audio ports Applications: Home theater, education, video conferencing, online teaching Cooling System: Highly efficient |
Unboxing Experience
Upon first glance, the Poner Saund Model M8 projector presents itself as an attractive and well-constructed device, slightly larger than my previous ViewSonic model. Its bulkier square frame and clean lines give it a modern look, and the four mounting screw locations make for a secure setup, despite the need to peel off rubberized pads to access them. Overall, it feels solid and well-made, suggesting durability for both indoor and outdoor use.Alwtniet Smart Projector:
The HY320 NTV projector has a sleek and modern design that fits well in any environment, be it a cozy living room or an outdoor setup. While it is slightly larger than some other models I've encountered, its lightweight build ensures it remains highly portable. The overall aesthetic is appealing and functional, making it a nice addition to my home entertainment system.ear&ear Mini Projector:
The HY300 PRO Portable Projector has a compact and stylish design that stands out in any setting. Its lightweight build makes it incredibly portable, allowing me to easily pack it for travel or outdoor movie nights. The projector's sleek appearance is complemented by a user-friendly interface, which is both intuitive and convenient, especially for quick setup and operation. Overall, it feels well-made and visually appealing.Display
Screen Size | 40 Inches - 100 Inches | 30 Inches - 150 Inches | 35 Inches - 130 Inches |
Throw Distance | 5 Feet - 15 Feet | 1 Meters - 4 Meters | 35 - 130 |
Contrast Ratio | 5500:1 | 10000:1 Pixels | 1500:1 |
Maximum Resolution | 1280 x 800 | 4096 x 2160 Pixels | 4096 x 2160 |
Native Resolution | 1280 x 800 | 1920 x 1080 | 1280 x 720 |
Brightness | 5500 Lumen | 320 Lumen | 200 Lumen |
Display Type | LCD | LCD | LED |
Viewing Experience
The viewing experience with this projector is quite impressive, especially in darker environments. The image quality is sharp, and I've successfully utilized it on a 100" screen without any noticeable loss in detail. However, when projecting onto a white garage wall at 200", the brightness and clarity diminish somewhat, likely due to the surface not being optimal for projection. There are some minor lag issues when using RCA connections, but switching to HDMI resolved this, and the built-in speakers are adequate for casual viewing.Alwtniet Smart Projector:
The viewing experience with the HY320 has been nothing short of fantastic. The 1080P resolution delivers sharp, clear images that are vibrant and full of life. Whether I’m watching movies indoors or outdoors, the brightness is more than adequate, even in darker settings. The sound quality is equally impressive, with rich audio that complements the visuals perfectly, making every movie night enjoyable.ear&ear Mini Projector:
My viewing experience with the HY300 PRO has been nothing short of impressive. The picture quality is fantastic, supporting both 4K and 1080P resolutions, which results in sharp and vibrant visuals even in moderately lit rooms. Whether watching movies, gaming, or giving presentations, the clarity and color reproduction have consistently exceeded my expectations. I’ve used it on a screen as large as 130 inches, and the image remains bright and detailed, making it suitable for various viewing scenarios.Features
Other Features | Wireless, Portable, Built In Wi Fi | Built-In Speaker, Native 1080P with 4K support, 320ANSI, Built-in Official APPS | Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player |
Video Encoding | 1080P | H.264, H.265 | AVC |
LightSource Life | 52000 Hours | 50000 Hours | - |
Controller Type | Remote Control | Remote Control | Remote Control |
Connectivity Technology | wireless(Wi-Fi)/wired, HDMI, USB, AV, TF | Bluetooth, Wi-Fi | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack |
Compatible Devices | ios system, android system | Laptop, Television, Smartphone, Speaker | Laptop, Tablet, Smartphone, Speaker |
Wattage | 60 watts | - | - |
Mount Type | table, tripod, ceiling (mount not included) | Tabletop Mount | Tabletop Mount |
L x W x H | 7.87"L x 5.9"W x 2.95"H | 8.66"L x 4.72"W x 6.69"H | - |
Setting up the Poner Saund Model M8 was relatively straightforward, though I encountered some initial confusion due to the lack of comprehensive instructions. The projector connects easily to a variety of devices via HDMI, and it allows for a direct connection to streaming devices like Roku. The menu system, while functional, feels somewhat clunky, and I had to navigate through a few settings to get everything configured to my liking. The option to adjust the X-Y zoom and keystone correction significantly aided in achieving a perfect image on my screen.Alwtniet Smart Projector:
Setting up this projector was a breeze. It connected effortlessly to WiFi and Bluetooth, allowing me to jump straight into streaming without any hassle. The built-in applications, especially Netflix, make accessing my favorite shows and movies incredibly convenient. Adjusting the screen size and focus is also straightforward, which enhances the overall user experience.ear&ear Mini Projector:
Setting up the HY300 PRO was a breeze. The 180° rotatable design is a standout feature that allows me to project images from various angles without hassle. The auto keystone correction works seamlessly, ensuring a perfectly aligned image, regardless of where I place the projector. Connecting to my devices is straightforward too—whether it’s via HDMI, USB, or wirelessly through the dual-band WiFi 6 and Bluetooth 5.2, everything connected quickly and efficiently. The Android 13 system means I can access my favorite streaming apps directly without needing additional devices, enhancing the convenience factor.Conclusion
Pros:• Solid build quality and attractive design
• Easy setup with multiple connection options
• Excellent image quality in low-light conditions
• Adjustable zoom and keystone correction
• Clunky menu navigation
• Some lag with RCA connections
• Built-in speakers may require external amplification for outdoor use
• Brightness drops in well-lit environments
Overall, I've been pleasantly surprised by the performance of the Poner Saund Model M8 projector, especially considering its budget-friendly price. It has proven to be a capable device for both indoor and outdoor movie nights, offering a decent picture quality and sound for casual use. While there are a few quirks and limitations, such as the need for external speakers in noisy environments and the clunky menu, the positives far outweigh the negatives. I feel confident recommending this projector to anyone looking for an economical solution for larger-than-life viewing experiences.
Pros:• Excellent picture quality with 1080P resolution
• Bright and vivid colors
• Built-in apps including Netflix
• Easy setup and connectivity
• Good audio quality
• Limited app selection
• May freeze when navigating apps at times
• Requires a dark room for optimal performance
Overall, I am thoroughly impressed with the HY320 NTV projector. It offers great value for its price, especially for someone on a budget like myself. The combination of ease of use, excellent picture and sound quality, and portability makes it an ideal choice for anyone looking to elevate their home entertainment experience. I highly recommend it for movie lovers, gamers, or anyone who enjoys streaming content seamlessly.
Pros:• Excellent image quality with 4K and 1080P support
• Fast and stable connectivity with Wi-Fi 6 and Bluetooth 5.2
• User-friendly setup with auto keystone correction
• Versatile projection angles with 180° rotation
• Performance is best in darker environments; brightness may suffer in daylight
• Built-in speaker is decent but not powerful; external speakers recommended for enhanced audio
I am thoroughly satisfied with my purchase of the HY300 PRO Portable Projector. It offers exceptional value for its price, delivering high-quality visuals and a seamless streaming experience, making it a fantastic option for home entertainment or outdoor movie nights. The combination of portability and powerful features makes it a versatile choice for anyone looking for a reliable projector. I highly recommend it to anyone seeking an affordable yet high-performing option in the projector market.
