Barend Ray
Active member
Unboxing Experience
- 1.1.1 Magcubic Mini Projector:
- 1.1.2 ear&ear Mini Projector:
- 1.1.3 PONER SAUND Mini Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 Magcubic Mini Projector:
- 1.3.2 ear&ear Mini Projector:
- 1.3.3 PONER SAUND Mini Projector:
- 1.4 Features
1.5
- 1.5.1 Magcubic Mini Projector:
- 1.5.2 ear&ear Mini Projector:
- 1.5.3 PONER SAUND Mini Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | Magcubic Mini Projector | ear&ear Mini Projector | PONER SAUND Mini Projector |
Picture | |||
Reference Price | $86.99 | $59.99 | $45.88 |
Recommended Uses | Education, Movie Night | Education, Home Cinema, Gaming, Business | 家庭影院,教育,游戏 |
Built-In Media | User Manual, Remote, Adapter | User Manual, Power Cord, Remote | remote control, GP16 Projector, Power Cable, HDMI Cable, 3 in 1 AV Cable |
Highlight | System Update: Manual update to latest version recommended Built-in Apps: Access to 1,000,000 videos without external TV stick Remote Control: Air Mouse remote with traditional and pointer control, voice command support Resolution: Native 720P with 4K support Brightness: 200 ANSI lumens, 10000:1 contrast ratio Use Cases: Suitable for casual use in bedroom, outdoor, or living room Design Features: Portable with ceiling mount, table placement, tripod installation, 180-degree rotation | Smart Projector: Android TV 13.0, built-in app ecosystem, access to streaming services (N-F, Prime Video, YouTube), over 500,000 movies/TV shows. Projection Flexibility: 180° rotational projection (wall, ceiling, floor), suitable for home theater, leisure, education, video conferencing. Image Adjustment: Auto keystone correction, manual focus adjustment. Sound System: 360-degree surround sound. Video Resolution: Supports 1080P/4K, advanced LED technology, 200 ANSI lumens brightness, 1500:1 contrast ratio. Connectivity: WiFi 6, Bluetooth 5.0, compatible with 2.4G and 5G networks. Noise Level: Below 25 dB. Ports: HDMI, USB, audio ports for external device connectivity. | Wireless Connection: Multi-screen interaction with iOS and Android compatibility, no extra cables needed. Resolution: 1280x720P native (1920x1080P supported). Brightness: 5500 lumens. Contrast Ratio: 5500:1. Aspect Ratio: 16:9 / 4:3. Screen Size: 40” to 210”. Projection Distance: 5ft to 15ft (recommended 6.5ft). Dimensions: 7.87 x 5.90 x 2.95 inches. Weight: 2.5 lbs. Built-in Speaker: Yes, delivers clear sound. Connectivity Options: HDMI, USB, AV, headphone. Customer Service: Lifetime customer service provided. |
Unboxing Experience
The projector has a sleek and lightweight design that makes it highly portable, which is a plus for those who may want to take it on trips or move it around the house. Its size is manageable, and the construction feels adequate for casual use. While it may not win any awards for aesthetics, it certainly looks functional and fits well in most home environments, making it a suitable choice for family movie nights or casual gaming sessions.ear&ear Mini Projector:
The HY300 PRO Portable Projector boasts a compact and stylish design that is both appealing and functional. Its lightweight build makes it highly portable, fitting easily into a bag for travel or outdoor movie nights. The overall aesthetic reflects modernity, which aligns well with its advanced features, making it an attractive addition to any entertainment setup.PONER SAUND Mini Projector:
The Poner Saund Model M8 projector boasts a solid and attractive design, larger than my previous ViewSonic model. The projector has a bulky, square frame that feels durable and well-made. I appreciate that it features four mounting screw locations, which allows for a more secure ceiling installation than my previous model. However, I had to remove rubberized pads to access the mounting points, which could be an oversight in design. Overall, it has a professional look, particularly when set up with a screen in a darkened room.Display
Screen Size | 40 Inches - 150 Inches | 35 Inches - 130 Inches | 40 Inches - 100 Inches |
Throw Distance | 0.9 Meters - 4 Meters | 35 - 130 | 5 Feet - 15 Feet |
Contrast Ratio | 10000:1 | 1500:1 | 5500:1 |
Maximum Resolution | 1980 x 1080 Pixels | 4096 x 2160 | 1280 x 800 |
Native Resolution | 1280 x 720 | 1280 x 720 | 1280 x 800 |
Brightness | 8000 Lumen | 200 Lumen | 5500 Lumen |
Display Type | LCD | LED | LCD |
Viewing Experience
The viewing experience is decent, particularly given the price point. The video quality is commendable, and I found that despite projecting at the lowest setting, it filled up a significant portion of my bedroom wall. However, the picture quality could be sharper, especially around the edges, and the brightness level is somewhat lacking, making it necessary to watch in a darkened room. I did encounter some lag while phone mirroring, which detracted from the experience, as the video and audio sometimes fell out of sync.ear&ear Mini Projector:
The viewing experience with the HY300 PRO is exceptional, supporting 4K and 1080P resolutions that deliver sharp, vibrant visuals even in moderately lit environments. Whether I’m watching movies, streaming content, or playing games, the clarity and color reproduction are impressive. The projector performs admirably on screens ranging from 35" to 130", making it versatile for both intimate settings and larger gatherings. The built-in sound is decent, but pairing with external speakers elevates the audio experience further.PONER SAUND Mini Projector:
Once set up, the viewing experience was quite satisfying. The image quality was crisp, especially in darker environments, and I was able to project a large image on my 100" screen from a distance of about 12 feet. However, brightness does drop off when projecting onto a white wall at larger sizes, which is something to consider if you plan on using it outdoors during the day. The X-Y zoom adjustment and 4-point keystone correction made it easy to achieve a well-framed picture, although the settings menu felt a bit clunky at times.• Pros:
- Crisp image quality in low-light conditions.
- Easy installation with both HDMI and legacy connections.
- Good brightness and contrast adjustments available.
• Cons:
- Clunky menu system.
- Brightness drops significantly in well-lit rooms.
- Limited Bluetooth support for audio connections.
Other Features | Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi | Portable, Auto Screen Alignment, Digital Keystone Correction, Built-In Wi-Fi, Built-In Media Player | Wireless, Portable, Built In Wi Fi |
Video Encoding | AVC | AVC | 1080P |
LightSource Life | 20000 Hours | - | 52000 Hours |
Controller Type | Remote Control, Voice Control | Remote Control | Remote Control |
Connectivity Technology | Bluetooth, Wi-Fi, USB, HDMI | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | wireless(Wi-Fi)/wired, HDMI, USB, AV, TF |
Compatible Devices | Laptop, Gaming Console, Smartphone | Laptop, Tablet, Smartphone, Speaker | ios system, android system |
Wattage | - | - | 60 watts |
Mount Type | Tabletop Mount | Tabletop Mount | table, tripod, ceiling (mount not included) |
L x W x H | 12"L x 6"W x 10"H | - | 7.87"L x 5.9"W x 2.95"H |
Setting up this projector was a breeze. It runs on Android, and I had it up and running in no time. The keystone correction feature works remarkably well, allowing for a straight and even picture even when projecting at a sideways angle. I appreciated the ease of navigating the menu, although there were some hiccups when trying to connect to various Bluetooth devices. While the setup process was mostly seamless, the need for a Bluetooth mouse to navigate certain apps like Netflix was an unexpected inconvenience.ear&ear Mini Projector:
Setting up the projector is incredibly straightforward, thanks to its intuitive controls and user-friendly interface. It connects effortlessly to a variety of devices via HDMI, USB, and its robust Wi-Fi 6 and Bluetooth 5.2 capabilities. The built-in Android 13 system allows for direct access to streaming apps, eliminating the need for additional devices. Additionally, the auto keystone correction and 180° rotatable design simplify the positioning and alignment of the image, making it accessible for anyone, regardless of tech-savviness.PONER SAUND Mini Projector:
Setting up the Poner Saund M8 was straightforward, and I was impressed with how quickly I could get it running. The projector offers both legacy connections and HDMI, which allowed me to connect my ROKU box easily. However, the manual is somewhat sparse, and finding specific features took a bit of trial and error. While I initially had some difficulty with setting up the sound and connecting wirelessly, I was ultimately able to navigate through the settings with relative ease. The projector does not support Bluetooth, which I found a bit limiting in terms of connecting to audio devices.Conclusion
Pros:• Excellent video quality for the price.
• Easy to set up and navigate.
• Portable and lightweight design.
• Decent keystone correction feature.
• Good size for indoor use.
• Sound quality is subpar; requires external speaker for better audio.
• Bluetooth connectivity can be finicky.
• Lag during phone mirroring and issues with streaming apps.
• Brightness and sharpness could be improved.
• Limited functionality with pre-installed apps.
Overall, I find this projector to be a solid option for those on a budget looking for a decent home entertainment device. While it has its shortcomings—particularly in sound quality and app functionality—the video quality and ease of setup make it a worthwhile investment for family movie nights or casual use. I would recommend it, especially for those who can connect external speakers and are prepared to navigate some of its quirks. Despite the drawbacks, it has met my expectations and provided enjoyable viewing experiences for both myself and my family.
Pros:• Excellent image quality with 4K and 1080P support.
• Fast connectivity with Wi-Fi 6 and Bluetooth 5.2.
• Highly portable and lightweight.
• User-friendly setup with auto keystone correction.
• 180° rotation for flexible viewing angles.
• Best performance in darker rooms; daylight can affect brightness.
• Built-in speaker is adequate but not sufficient for immersive sound.
Overall, the HY300 PRO Portable Projector is a stellar choice for anyone seeking a portable, high-quality projector without breaking the bank. Its combination of impressive picture quality, seamless connectivity, and ease of use makes it perfect for home entertainment, gaming, and outdoor movie nights. I wholeheartedly recommend it to anyone in the market for a reliable and versatile projector.
Pros:I appreciate the projector's ability to handle various input options, including HDMI for my ROKU and legacy video inputs for older devices. The built-in speakers are surprisingly adequate for day-to-day use, though I prefer connecting to a soundbar for a better audio experience. The projector also comes with a decent screen, enhancing the viewing experience during movie nights. The fan noise is minimal compared to my previous unit, which is a big plus.
One downside I've encountered is the lack of Dolby support when streaming, which necessitates adjusting audio settings on my devices. There’s also some noticeable lag when using certain inputs, affecting the lip-sync with external audio systems. Additionally, the projector's brightness can be underwhelming in bright environments, requiring a dark room for optimal viewing, which may limit its versatility for outdoor use during the day.
Overall, I’m quite happy with the Poner Saund Model M8 projector. It has exceeded my expectations in terms of image quality and ease of setup for a budget projector. While it has its shortcomings, particularly with brightness and some audio connectivity issues, it still offers great value for the price. The crisp image quality, especially in dark settings, makes it a great option for family movie nights or casual streaming. I’d recommend this projector to anyone looking for a cost-effective way to enjoy a larger screen experience, keeping in mind its limitations.
