No default focus
vasya_petrovich
Hello, guys.
I'm using TV Box T95, with Android 10.
When Emotn UI launcher loading first time, there is no focus on button. I have to press down arrow on my rc two times, and after that ui switching to app menu and appears focus.
I think it is a some bug in launcher.
Will you try to solve it?
FishZ
Hello, guys.
Does this happen every time you open it?
vasya_petrovich
What focus do you mean?
I'm talking about focus on a first button. When I turning on my tv box it's loading Android OS and after that Emotn UI launcher. When launcher is loaded I should see a default focus on a first button (example attached).
Appholic
I heard that the developers will fix this issue in the next update.
grayline23
I'm running into this problem. When I hit the 'home' button the launcher puts focus on the last item I selected instead of putting focus on the first item in the apps. bar.
Running the current version from the website. Any suggestions?
Onn 4k Google device - 2023
