Hi all, apologies for my basic understanding but Ive tasked myself a small project to setup some stairwell lighting.
I have settled with the idea of some sort of LED strip in a defuser (if that's the correct term) running along the side of the stairs - perhaps both sides?
I want to use two motion sensors one at the top and one at the bottom that trigger when people step on the first tread and zip the lights go on - 60 seconds of inactivity (maybe more) and the lights go off again Speed Test https://vidmate.bid/ .
I initially looked at Ikea - considering that its quite cheap and would all work as is. But their sensor is quite large.
I want something that I can have under the step Or to the side that is small in size - are there any recommendations for this kind of thing.
Am I barking up the wrong tree with this idea in general?
Thank you for reading.
