How to watch 3D movies on Dangbei Mars Pro?
sai
3D movies tend to be dark, especially with 3D eyes, which look tired if you use a regular projector.
The VIVIDSTORM has a screen(gain 1.2) that improves the brightness of the projected screen.
Mabye you can try it.
ejeong89
I purchased Dangbei 3D glasses, but they do not receive any DLP signal from the Mars Pro :-( I tried lowering the brightness of the projector but had no luck.
Wescoast
hello, have you recharged the 3D glasses? for me it works very well. otherwise contacted Dangbei support.
ejeong89
I've fully charged it:-(. Is the distance between the projector and the screen important? My projector is 15 feet away from my screen.
Is Dangbei player (decode: Software and display filter: 3d side-by-side) the only app (and setting) that allows us to watch 3d sbs videos?
I should probably contact Dangbeit about this. Thanks
