i did it, but the memory shows as 1 mb No support then ?
manu81cba New member Nov 23, 2022 #21 gecemelek said: i did it, but the memory shows as 1 mb Click to expand... No support then ?
gecemelek New member Nov 24, 2022 #22 İ font know manu81cba said: No support then ? Click to expand... ı dont know
gecemelek New member Dec 5, 2022 #23 when I return to the factory settings, everything is fine, everything is stable
manu81cba New member Dec 5, 2022 #24 gecemelek said: when I return to the factory settings, everything is fine, everything is stable Click to expand... but what firmware use and model you projector?
saddo New member Dec 7, 2022 #25 gecemelek said: 공장 설정으로 돌아가면 모든 것이 정상이고 모든 것이 안정적입니다. Click to expand... Did you successfully update X3PRO to English version? And if I initialize it later, is it the Chinese version? Or is it an English version?
gecemelek New member Dec 22, 2022 #26 saddo said: Did you successfully update X3PRO to English version? And if I initialize it later, is it the Chinese version? Or is it an English version? Click to expand... Yes ,English version
W wheelee Active member Jan 2, 2023 #27 ^ can you share the Steps you did to make the Chinese version to English version?
