Alwtniet Smart Projector vs Magcubic Mini Projector vs Salange Smart Projector: Which Offers Better Built-in Apps?
mufcroberts
Alwtniet Smart Projector​
Magcubic Mini Projector​
Salange Smart Projector​
$199.99​
$86.99​
$179.99​
Education, Movie Night​
Indoor/Outdoor​
Adapter​
User Manual, Remote, Adapter​
User Manual, Mini Projector with Stand, Power Cord, Remote Control​
Resolution: Native 1080P
Brightness: 700 ANSI
Screen Size: Up to 200 inches
Offset Technology: 75% auto offset
Throw Ratio: 0.6:1
Focus Adjustment: Electric Focus
Keystone Correction: Vertical Auto Keystone Correction
Audio: Dual speakers with stereo sound and surround effects
Smart Features: Built-in Smart TV OS with access to 1,000,000 videos
Supported Apps: Netflix, Prime Video, YouTube
System Update: Manual update required for optimal performance
Built-in Apps: Access to 1,000,000 videos, no external TV stick needed
Remote Control: Air Mouse remote with traditional and mouse functionality, voice command support
Resolution: Native 720P with 4K support
Brightness: 200 ANSI lumens, 10000:1 contrast ratio
Usage Scenarios: Suitable for casual viewing in various settings (bedroom, outdoor, living room)
Design: Versatile and portable; options for ceiling mounting, table placement, tripod installation, 180-degree rotation
Resolution: Native 1080P, 4K support
HDR Support: HDR10
Operating System: Android 13 NTV
Preloaded Apps: Netflix, Prime Video, YouTube
Connectivity: HDMI, USB, 3.5mm audio port, WiFi 6, Bluetooth 5.2
Mounting Options: Ceiling, tabletop, tripod, wall
Stand: 180° tool-free adjustable
Use Cases: Movies, gaming, outdoor use, parties
Audio: Two-way Bluetooth (audio only)
Additional Features: App store access, compact design
Unboxing Experience​
Alwtniet Smart Projector:​
The projector exudes a solid and well-built feel, which instantly gives off a sense of durability. Its design is sleek and modern, making it a great addition to any media room or office space. I was pleasantly surprised by its compact form factor, which doesn’t compromise on performance. The overall aesthetic is appealing, and it fits comfortably into different environments without looking out of place.
Magcubic Mini Projector:​
The projector has a sleek design that is lightweight and portable, making it easy to transport for various uses, whether at home or on the go. I appreciate the compact size, which allows it to fit comfortably in my living space without taking up too much room. The projection size is impressive, easily filling most of my bedroom wall even when set to the lowest setting. However, the placement of the power supply could be better, as it’s located near the arm, although this didn't pose any significant issues during use.
Salange Smart Projector:​
As soon as I laid eyes on this projector, I was impressed by its sleek and compact design. It looks modern and stylish, making it a great addition to any room or outdoor setup. The build quality feels solid, and the rotating stand adds a unique touch that enhances its versatility. It's not just a functional device; it also has an aesthetic appeal that complements my entertainment space wonderfully.
40 Inches - 150 Inches​
40 Inches - 300 Inches​
0.55 - 2.1​
0.9 Meters - 4 Meters​
1 Meters - 7 Meters​
10000:1​
7680×4320​
1980 x 1080 Pixels​
3840x2160 Pixels​
1280 x 720​
8000 Lumen​
LED​
HDR 10​
The brightness of this projector is impressive, especially when projecting onto a large screen from a short distance. The image is clear, and while it claims to support offset adjustments, I found no settings available for that purpose. Although I enjoyed the visual quality, I noticed that it falls short of true 1080p, exhibiting a picture quality more akin to 720p. The sound is decent enough for standalone use, but when paired with a soundbar, it elevates the viewing experience to a more immersive level.
The viewing experience is overall satisfactory, especially given the price. The video quality is commendable, producing a decent picture that is easily viewable in a darkened room. However, I did notice that the video could appear a bit dim, especially in darker scenes, which detracted from some movies. While the projector does well indoors with artificial lighting, natural light can significantly affect visibility. I found myself needing to use a Bluetooth mouse for navigating some apps like Netflix, which was less than ideal and somewhat cumbersome.
The viewing experience is nothing short of stunning. With crisp 1080P resolution and support for 4K content, the picture quality is vibrant and full of life. Colors pop, and the deep contrast really enhances both movies and gaming. I love how versatile it is, allowing for projection on various surfaces, including walls and ceilings. It truly transforms any space into a mini-theater, making movie nights an absolute joy.
• **Pros**:
- Stunning picture quality with 1080P and 4K support
- Built-in Android 13 with access to major streaming platforms
- Easy setup with electric focus and auto keystone correction
- Versatile 180° rotating stand for different projection angles
- Compact design suitable for indoor and outdoor use
- Dual-band WiFi and Bluetooth 5.2 for easy connectivity
• **Cons**:
- App performance is disappointing
- Some issues with picture quality in certain scenarios
Built-In Speaker​
Air Mouse Control, Portable, Bluetooth, Voice Control, Built-In Wi-Fi​
Official licensed Netflix, Prime Video, and YouTube etc, 180 ° Rotating Desktop Projector Stand, Electric Focus/Auto Keystone Correction, 4D/4P keystone and Zoom 100%-50%, Smart Android 13.0 NTV, 1080P Native 4K Support, 5G/2.4G WiFi+Two-Way Bluetooth 5.2​
AVC​
MPEG1/MPEG2/MPEG4/H.263/H.264/AVS/VC6/MJPEG/RV30/RV40/HEVC​
20000 Hours​
40000 Hours​
Wi-Fi​
Bluetooth, Wi-Fi, USB, HDMI
Bluetooth, Powerline, Wi-Fi, IR​
70 watts​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Ceiling Mount/Table Mount/Wall Mount/Tripod Mount​
12"L x 6"W x 10"H​
7.68"L x 7.68"W x 3.54"H​
Setting up this projector was a breeze; I simply plugged it in and performed a system upgrade for first-time use. The built-in Wi-Fi made connecting to popular apps like YouTube, Disney+, and Netflix incredibly easy, eliminating the need for cumbersome HDMI cables. The intuitive interface allows for quick navigation, and once connected to Wi-Fi, the projector seamlessly integrates with various streaming services, making it ideal for family movie nights.
Setting up the projector was straightforward, which I found refreshing. I was able to get it running in no time, and the Android onboard made navigating the menus easy. However, I did face some challenges with connecting to streaming apps like Netflix, Hulu, and HBO, as they often wouldn’t sign in or play. It took some trial and error to pair Bluetooth devices, but once I figured it out, the process became simpler. The keystone correction feature is excellent, allowing me to achieve a straight, even picture even when projecting at a sideways angle.
I couldn’t be happier with the setup process. Right out of the box, it was incredibly straightforward thanks to the electric focus and auto keystone correction. I had everything up and running in no time. The built-in Android 13 system is a major plus, allowing me to access Netflix, Prime Video, and YouTube without needing any additional streaming devices. The dual-band WiFi and Bluetooth 5.2 connectivity make pairing with other devices seamless, turning this projector into an all-in-one entertainment hub.
• Easy setup with built-in apps
• Solid build quality and design
• Impressive brightness for large screens
• Good sound quality, especially with a soundbar
• Responsive and fluid user interface
• Lacks true 1080p quality
• Poor customer service and lack of support documentation
• Requires a pitch-dark environment for optimal viewing
• Netflix app issues and limited manual focus options
• No settings for offset adjustments or 4:3 support
Overall, this projector impressed me with its ease of use and solid performance in a home theater setting. While it does have its drawbacks, such as the lack of true 1080p quality and some customer support issues, the price point makes it a compelling option for anyone looking for a budget-friendly projector. The vibrant colors and sharp image quality enhance the viewing experience, making it a great choice for movie nights or presentations. I would recommend this projector to those who prioritize ease of setup and solid performance, but it may not satisfy users looking for top-tier specifications.
• Good video quality for the price
• Easy setup process
• Impressive projection size
• Great for indoor use in low light
• Lag when mirroring from a phone
• Sound quality is subpar without external speakers
• Streaming apps often have connectivity issues
• Limited brightness and sharpness in certain conditions
• Remote navigation can be unresponsive
In conclusion, I believe this projector offers excellent value for the price, providing a solid option for casual movie nights or kids' entertainment. Despite some notable drawbacks, such as the sound quality and issues with streaming apps, it meets my expectations for a budget-friendly projector. I do hope for improvements in those areas, but for now, it serves its purpose well, especially with the option to connect to external speakers for better audio. I feel satisfied with my purchase and look forward to further testing its durability and performance.
Overall, this projector is an incredible value for the price. It checks all the boxes for anyone looking to enhance their home theater experience, enjoy gaming, or host outdoor movie nights. Despite some minor drawbacks with the app and occasional picture quality issues, the convenience and performance make it highly recommendable. I genuinely believe this projector is a perfect source of entertainment, whether for cozy nights at home or fun gatherings with friends outside.
The Alwtniet Smart Projector is awesome! Perfect for movie nights at home, work presentations, or outdoor fun. The picture is crystal clear, colors pop, and it's super user-friendly. Plus, it won't break the bank—way better deal than other brands. Totally recommend it!
Charger196904
Alwtniet Smart Projector isn’t an ultra short throw projector. It throws a screen smaller than 40 inches from more than 3 feet away.
The Salange Smart Projector is awesome for outdoor movie nights or chilling at home! It’s super easy to set up, gives clear picture and sound, and connects to all your favorite streaming services without a hitch. Perfect for some fun!
