This guide will show you how to Keystone Correct Emotn N1 projector.
1. Go to
Settings with your remote.
2. Choose
Keystone.
3. Select
Auto. The screen will be automatically corrected.
4. Select
Manual, to adjust the four points and the size of the frame.
