HBO Max provides access to the full HBO library as well as exclusive Max Originals. It's The Streamable's Best Streaming Service of 2022. HBO Max can be downloaded and used on VIZIO Smart TVs, or cast to VIZIO Smart TVs via Apple AirPlay. Here are three ways to get HBO Max in VIZIO.
1. Turn on your Vizio smart TV, find the Vizio App Store on the home screen, open and navigate to the search bar.
2. Search for HBO Max, you will see the HBO Max icon, click the Add to Home button.
3. After the download is complete, the HBO Max app will be installed on your Vizio TV.
4. Then you can open the HBO Max app and log in, then you can watch your favorite movies in the HBO Max app.
If for some reason your VIZIO TV cannot download HBO Max through the above method, you can stream HBO Max from iPhone to VIZIO Smart TV via Airplay 2. Follow the steps below to complete this transfer.
1. First, connect your VIZIO TV and iPhone to the same WiFi.
2. Download and install the HBO Max app on your iOS device. Activate and sign up or log in to your HBO Max account.
3. Search for and play the movie or TV show you want to watch.
4. Tap the AirPlay icon and select VIZIO TV from the available devices.
5. The HBO Max content you played on your iPhone will then be cast to your VIZIO TV.
1. First, connect your Android phone and Vizio smart TV to the same WiFi network.
2. Download HBO Max from the Play Store on your Android smartphone, open and log into your HBO Max account.
3. Click the cast icon and select your VIZIO TV.
4. Select and play the movie you want, then it will play on the VIZIO TV.
You can install or cast the HBO Max app on your Vizio TV, and all three methods above will allow you to get HBO Max movies on your Vizio TV.
Vizio TV Forum
How to download HBO Max on Vizio Smart TV?
How to Watch HBO Max on VIZIO Smart TV Using Airplay
How to Cast HBO Max on VIZIO Smart TV Using Your Android Smartphone
Vizio TV Forum
