Adney
On the afternoon of August 25, Formovie officially held the "Unlimited imagination" new product release conference, and Formovie R1 ultra short-focus laser projector officially appeared. It is understood that the product is a new category of projection products, using ultra-short focus design and reference laser light source, to solve the projection product distance and the picture can not have both.
According to the press conference, Formovie R1 ultra short-focus laser projector is equipped with ALPD display technology, has 1600ANSI lumen brightness, and supports a projection of 50-200 inch screen size. With a contrast ratio of 3000:1, you can see more dark details.
The product is equipped with MTK MT9669 chip and has 3GB+16GB memory storage space. In terms of picture quality, it is equipped with 1080P full HD resolution, 4K decoding, 110% Rec.709 color gamut, and MEMC motion compensation. In sound quality, Formovie R1 laser projector has built-in two 10W high power speakers, and it supports DOLBY+DTS dual decoding authentication.
