XGIMI RS Pro2 Projector Review
Nadia
XGIMI RS Pro2 projector adopts gold color matching, a metal body frame, the metal suspension is attached to the body, and an electric sliding door is designed at the same time. Built-in preloading technology INUI, configuration MTK9669 processing chip, storage 4 plus 128GB, 4K resolution, brightness 2200 lumens.
In terms of appearance, XGIMI RS Pro2 adopts dawn gold color matching, metal body frame, metal suspension fitting on the body, metal fitting line feeling and soft fabric art fusion; At the same time, the electric sliding door is designed to not only protect the projection lens, but also make watching the film more ritualistic.
In terms of interfaces, it is respectively equipped with a power supply, dual USB, dual HDMI, LAN network cable, 3.5mm audio and optical fiber audio interfaces, and the interfaces are designed on the back bottom of the projector body, so that the life of the interface cable will not be affected by the heat dissipation vents on the back.
As for the system, the new lightweight, fast and more immersive INUI is built in. Through the pre-loading technology, the loading speed of the home page is improved to provide a more carefree operation experience.
Nadia
In terms of screen display, XGIMI RS Pro2 projector has a built-in 0.47dmd display chip with a resolution of 3840*2160dpi and supports the polar meter x-vue 2.0 picture quality engine with a brightness of 2200ANSI lumens. Color performance is more gorgeous, even in the light environment the color description is very accurate.
In terms of performance, it can support functions such as automatic trapezoidal correction, automatic screen entry and intelligent obstacle avoidance. Zooming animation in the process of trapezoidal correction to square makes the user experience smoother. It is paired with a 1.1x zoom lens and supports both optical and digital zoom.
