XGIMI MoGo 2 Pro vs MoGo 2 vs MoGo 3 Pro: Which Portable Projector is the Right Choice for You?
windstri85
XGIMI MoGo 2 Pro​
XGIMI MoGo 2​
XGIMI MoGo 3 Pro​
Price​
$349.99
$249.99
$449.99
Home Cinema​
Home Cinema​
Education, Outdoor, Home Cinema, Camping, Gaming, Business​
Flexible Casting Combination: 120° adjustable stand, compact design for professional visual experience.
Remarkable Lifelike Vision: 400 ISO lumens, D65 color temperature, 90% DCI-P3 color gamut for vibrant colors.
The Ultimate Portable Solution: Weighs 3.5 lb, multi-angle stand, ideal for easy transport and setup.
Intelligent Screen Adaption Technology: ISA 2.0, 3D ToF and CMOS for automatic keystone correction and autofocus.
Non-stop Entertainment: Runs Android TV 11.0, supports Netflix access via customer support.​
Immersive Visual Experience: 400 ISO lumens, DLP technology, Integrated D65 color temperature, realistic colors.
Long Lifespan with Easy Setup: 25,000-hour lamp life, XGIMI's Intelligent Screen Adaptation Technology, easy setup.
Compact Design: Weighs 1.1kg, less than 5 inches wide, portable for various settings.
Professional Sound to Enjoy: Built-in 2×8W speakers, Dolby Audio compatibility, powerful bass.
Endless Entertainment Options: Upgraded Android TV 11.0, 5000+ apps, Netflix access requires customer support.​
Audio: Dual 5-watt Harman Kardon speakers
Light Mode: Ambient Light Mode for pulsating effects
Projection: 130° built-in stand, ISA 2.0 for automatic alignment
Stability: Metal slide rail for lens protection and stability
Streaming: Access to Google TV, Netflix, 10,000+ apps, and 800+ free channels
Image Quality: 450 ISO Lumens brightness, 90% DCI-P3 color gamut, 1080P resolution
Screen Size: Up to 120 inches
Bluetooth Connectivity: Automatic firmware updates enabled at startup​
Side-by-Side Comparison​
XGIMI MoGo 2 Pro​
XGIMI MoGo 2​
XGIMI MoGo 3 Pro​
40 Inches - 200 Inches​
30 Inch Ounces - 200 Inches​
1 Meters - 6 Meters​
N/A - 3 Meters​
1.06 Meters - 5.3 Meters​
1000:1 or higher​
Display Resolution​
1920 x 1080 Pixels​
1280 x 720​
1920 x 1080 Pixels​
1280 x 720​
400 Lumen​
400 Lumen​
450 Lumen​
DLP​
DLP​
DLP​
Picture Quality Enhancement​
HDR 10​
DLP and Wide Color Gamut​
4-point Keystone Correction( Vertical and Horizontal), ISA 2.0 uninterrupted auto focus, HDR 10, Intelligent Screen Alignment Intelligent Obstacle Avoidance, ISA 2.0 uninterrupted auto keystone​
XGIMI MoGo 2 Pro​
XGIMI MoGo 2​
XGIMI MoGo 3 Pro​
AVC​
AVC​
8 Watts​
Light Source Life​
25000 Hours​
30000 Hours​
25000 Hours​
Button Control​
Remote, Touch​
Remote, Touch​
Mount Type​
Tabletop Mount​
Tabletop Mount​
Tabletop Mount​
Noteworthy Features​
Built-In Speaker, Auto Obstacle Avoidance, High Light Transmission Coated Lens, Intelligent Eye Protection, 4-point Keystone Correction( Vertical and Horizontal), ISA 2.0 uninterrupted Auto Keystone, Auto Screen Alignment, Auto Focus​
Speakers, 3d Built-In, Internet Ready, 3d-Ready​
Built-In Speaker, Built-In Netflix, Advanced Eye Protection, Intelligent Screen Alignment, Auto Focus in Seconds, Uninterrupted Auto Keystone Correction, Intelligent Obstacle Avoidance, Build-In Adjustable Stand, 450 ISO Lumens​
Connectivity​
XGIMI MoGo 2 Pro​
XGIMI MoGo 2​
XGIMI MoGo 3 Pro​
Bluetooth, Wi-Fi, USB, HDMI​
Wireless​
Bluetooth, USB​
Hardware Connectivity​
USB Type C, HDMI, USB 2.0 Type A, 3.5mm Audio, Bluetooth 5, 802.11 ac/b/g/n​
USB Type C, USB 2.0 Type A, 3.5mm Audio, Bluetooth 5​
USB Type C, Micro-HDMI, USB 2.0​
Tablet​
Laptop, Smartphone, Gaming Console​
Measurements​
XGIMI MoGo 2 Pro​
XGIMI MoGo 2​
XGIMI MoGo 3 Pro​
Dimensions L x W x H​
7.56"L x 6.06"W x 5.2"H​
5"L x 4"W x 6"H​
3.74"L x 3.74"W x 8.06"H​
Item Weight​
3.5 Pounds​
2.4 Pounds​
1.1 Kilograms​
Product
PROS AND CONS​
XGIMI MoGo 2 Pro​
• Works better than most
• Super cool and easy to set up
• Compact design
• Very good picture quality
• Smart and intuitive interface
• Requires a dark room for optimal picture quality
• Involves multiple passwords for Android TV access
• Leaves a massive backlight around the video after auto focus
• May need technical support for automatic calibration and keystone adjustments
XGIMI MoGo 2​
Pros
• Excellent portability for various settings
• Impressive picture quality, especially in dark environments
• Easy setup and intuitive user interface
• Auto-focus and auto-keystone features for hassle-free adjustments
• Adequate sound quality without external speakers
• Compatible with Bluetooth for audio options
• Good battery efficiency with extended usage on portable chargers
Cons
• Sound quality does not compare to high-end sound systems
• May not perform as well in bright environments
• Android setup may be less straightforward for Apple users
• Limited high-definition capabilities compared to more expensive models
XGIMI MoGo 3 Pro​
• Super sharp picture quality with 1080p full HD resolution
• Powerful built-in speaker for immersive sound
• Portable design allows easy movement between rooms
• Smart features with built-in streaming services
• Automatic tuning for easy setup and usage
• Versatile connectivity options including HDMI and USB-C
• Great performance in both indoor and outdoor settings
• 'Magic window' mode is enjoyable for kids
• Good value for the price
• No brightness adjustment feature for different environments
