Significant_Rate
- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
TheXGIMI MoGo 2 Prohas a compact design and weighs only 2.4 pounds, but it doesnt have an integrated battery, so you still need to plug it into an outlet. It can be charged through its USB-C port with an external power bank (not included with the unit) as long as it has a power output of 65W and above. It has full auto keystone correction, autofocus, intelligent screen alignment, and obstacle avoidance, so its very easy to set up.The projector has two integrated 8W speakers, so you wont need to worry about connecting it to a soundbar or audio system when bringing it with you. It doesnt have an adjustable stand in the box, but XGIMI sells a multi-angle stand for the MoGo and Halo series separately.This 1080p DLP projector uses an LED bulb as its light source, and its rated for up to 25,000 hours by the manufacturer, so you likely wont ever have to worry about replacing it.
Parameter | XGIMI MoGo 2 Pro |
Reference Price | $289.99 |
Recommended Uses | Indoor/Outdoor |
Highlight | • Brightness: 400 ISO lumens • Color Accuracy: D65 color temperature, 90% DCI-P3 color gamut • Smart Features: ISA 2.0, 3D ToF, CMOS, automatic keystone correction, autofocus • Portability: Less than 5 inches wide, lightweight • Sound: 2×8W speakers, Dolby Audio compatibility, enhanced bass • Operating System: Android TV 11.0 • Battery: Not included |
Screen Size | 50 Inches - 200 Inches |
Throw Distance | 5 Feet - 5.2 Meters |
Maximum Resolution | 3840 x 2160 pixels |
Brightness | 400 Lumen |
Display Type | DLP |
Viewing Experience | The XGIMI MoGo 2 Pro presents itself as a compact projector that excels in brightness uniformity, ensuring consistent lighting across the screen. However, its overall brightness is on the dim side, necessitating a dark environment for optimal viewing. The contrast performance is underwhelming, with less depth in blacks and a lack of vibrancy in whites, leading to a viewing experience that may come off as lackluster in low-light conditions. While the projector boasts a wide color gamut, it struggles with accurate blue tones and offers only an adequate representation of HDR content. Overall, the XGIMI MoGo 2 Pro is a decent option for those who prioritize uniform brightness but may disappoint in terms of contrast and color accuracy. |
Lamp Wattage | 3 Watts |
Wattage | 65 watts |
Connectivity Technology | Bluetooth |
Hardware Connectivity | USB Type C, USB 2.0 Type A, HDMI, Bluetooth 5 |
Compatible Devices | Laptop, Smartphone, Tablet, Gaming Console, Television, Speaker |
Other Features | Speakers, 3d Built-In, Internet Ready, 3d-Ready |
L x W x H | 6.33"L x 4.68"W x 4.25"H |
System Experience | Overall Impression: This projector offers a robust multimedia experience with its integration of Android TV 11.0 and full Chromecast capabilities, allowing seamless screen sharing from various devices. The inclusion of two 8W speakers enhances audio output, while Wi-Fi 5 and Bluetooth 5.0 connectivity provide versatile streaming options. The ability to passthrough multiple Dolby audio formats adds to its entertainment value. Additionally, the USB-C port for power delivery allows for flexible charging options, making it convenient for users on the go. Overall, this projector is well-equipped for a rich viewing experience. |
User Feedback
Pros• Excellent image quality with clear and vibrant colors
• Smooth 1080P resolution
• Useful functionalities like AUTO-FOCUS and AUTO-KEYSTONE
• Built-in Chromecast for easy streaming without additional devices
• Very quiet operation, quieter than most laptops
• Portable design ideal for outdoor use
• Built-in speaker system delivers clear and crisp audio
• Multi-screen display support for mirroring devices
Cons
• HDMI connection issues causing sound clipping with certain setups
• Not Netflix licensed; workaround app does not support streaming reliably
• Premium price point may not justify the current technical limitations
• No internal battery, requiring external power for extended use
Overall Impression
The Mogo 2 Pro projector offers an impressive combination of high-quality visuals, useful features, and portability, making it a strong contender in the portable projector market. While it does have some technical drawbacks, particularly concerning HDMI connections and streaming services, its premium build quality and excellent performance could make it a worthwhile investment, especially if purchased at a discount. Ideal for both casual movie watchers and serious gamers, the projector provides an immersive experience, albeit with some caveats that potential buyers should consider.
