- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
TheXGIMI HORIZON Pro 4kprojector isnt designed to be portable, as you need to plug it into an outlet, but its still somewhat lightweight. This unit does have full auto keystone correction with intelligent screen alignment and obstacle avoidance, so it detects if there are objects in the frame and adjusts it correspondingly. It also has autofocus, so you dont need to do manual image corrections on this projector, making it easy to set up. It has two 8W Harmon/Kardon speakers, so you wont need to worry about connecting it to a soundbar if you move it.This DLP projector uses an LED bulb as its light source, and its rated for up to 30,000 hours by the manufacturer, so you likely wont ever have to worry about replacing it. It doesnt do true 4k as it uses pixel shifting to create a higher resolution image. This offers better quality than 1080p but doesnt look as good as native 4k.
Parameter | XGIMI Horizon Pro |
Reference Price | $999.99 |
Built-In Media | Projector Lens Cover, HDMI Cable, LAN Cable, Speakers, Remote Control |
Highlight | • Resolution: 3840 x 2160 (True 4K) • Brightness: 1500 ISO Lumens • Audio: Dual 8W Harman Kardon speakers, DTS-HD, DTS Studio Sound, Dolby Digital compatibility • Screen Adaption Technology: ±40 Degrees Auto Keystone Correction, Auto Screen Alignment, Auto Focus, Obstacle Avoidance • Image Engine: X-VUE 2.0, 60Hz MEMC, HDR10 x HLG, AI Brightness Adjustment • Operating System: Android TV 10.0 • Apps: 5000+ Google Play apps, Chromecast built-in • Voice Control: Google Assistant • Note: Does not support Netflix app |
Screen Size | 40 Inches - 200 Inches |
Throw Distance | 33.33 Feet - 27 Feet |
Contrast Ratio | 10000:1 |
Brightness | 1500 Lumen |
Display Type | DLP |
Picture Enhancement | X-VUE 2.0 Image Engine, MEMC |
Viewing Experience | The XGIMI HORIZON offers a solid performance with adequate peak brightness, making it suitable for dark room viewing, though it struggles in well-lit environments. Its brightness uniformity is commendable, ensuring a consistent image across the projection. While the native contrast is passable, blacks tend to appear raised, which is more noticeable in brighter scenes, but this is acceptable in darker settings. Additionally, the projector boasts a wide color gamut, effectively covering the Rec. 709 color space for SDR content, despite some inaccuracies in blue tones. Overall, the XGIMI HORIZON provides a satisfactory viewing experience, particularly in low-light conditions. |
Video Encoding | [Multiple Common Formats] |
Controller Type | Remote Control, Voice Control |
Control Method | Remote, Touch |
Lamp Wattage | 8 Watts |
Wattage | 250 watts |
Connectivity Technology | Bluetooth, Wi-Fi, USB, HDMI |
Hardware Connectivity | USB, HDMI, Headphone, 802.11 ac/b/g/n, Bluetooth 5 |
Compatible Devices | Television, Laptop, Smartphone, Tablet |
Other Features | Built-In Speaker, Auto Obstacle Avoidance, Auto Screen Alignment, Auto Focus, HDR10, HLG, Low Blue Light Certified By TÜV Rheinland, Auto Keystone Correction(±40° Vertical and Horizontal), Intelligent Screen Alignment |
L x W x H | 8.58"L x 8.18"W x 5.35"H |
System Experience | The projector offers a versatile and user-friendly experience with its Android TV smart interface, making it easy to access streaming services and content. The built-in Chromecast and AirScreen features enhance its casting capabilities, allowing for seamless sharing from various devices. The inclusion of two 8W Harman/Kardon speakers ensures a quality audio experience, complementing the visual output. With two HDMI ports, including one that supports eARC, as well as Bluetooth 5.0 and Wi-Fi connectivity, the projector provides ample options for connecting external devices and streaming content wirelessly. Overall, it presents a well-rounded package suitable for both entertainment and convenience. |
User Feedback
Pros:• Excellent brightness that performs well even in ambient light
• Improved comfort for kids' eyes during long screen time
• High video quality that resembles a movie theater experience
• Good audio quality without needing external speakers
• Easy setup and automatic tuning features
• Portable and convenient for different uses
• None explicitly mentioned, but potential limitations in very bright environments not directly addressed
The XGIMI Horizontal Pro projector stands out as an exceptional choice for families, particularly for kids' online learning and entertainment. Its impressive brightness and video quality, combined with ease of use, make it a valuable tool for reducing eye strain and enhancing the viewing experience. Highly recommended for those seeking a reliable projector.
