Amanda Brown
Active member
- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The XGIMI Elfin has a compact design and weighs only 2.2 pounds, but it doesnt have an integrated battery, so you still need to plug it into an outlet. It has full Auto Keystone correction and autofocus, so its easy to set up. The projector has two integrated speakers, so you won't need to worry about connecting it to a soundbar or audio system when bringing it with you.This 1080p DLP projector uses an LED bulb as its light source, and it is rated for up to 25,000 hours by the manufacturer, so you likely wont ever have to worry about replacing it. As its a 1080p projector, it's limited to a 1080p @ 60Hz resolution.
Parameter | XGIMI Elfin |
Reference Price | $299.99 |
Built-In Media | User Manual, Projector*1, Power Cord, Warranty Card, Remote |
Highlight | • Resolution: 1080P HD • Brightness: 400 ISO lumens • Color Gamut: 113% Rec.709 • Streaming Service: Licensed Netflix pre-installed • Stand Type: All-in-One, flexible viewing angles • Auto Adjust Features: Intelligent Screen Adaption (ISA), Auto Keystone Correction, Auto Focus, Intelligent Obstacle Avoidance, Intelligent Screen Alignment • Design: Compact and slim (2.5 inches thick) • Audio: Built-in dual 3W speakers • Portability: Effortlessly portable for indoor/outdoor use |
Screen Size | 80 Inches - 150 Inches |
Throw Distance | 10 - 10 Feet |
Brightness | 400 Lumen |
Display Type | DLP |
Viewing Experience | The XGIMI Elfin is a projector that performs best in darker environments, as it has a dim brightness level that requires lights to be turned off for optimal viewing. It features excellent brightness uniformity, ensuring consistent brightness across the screen. While the contrast ratio is acceptable, it struggles in dark settings where blacks appear elevated. The projector boasts a wide color gamut, covering nearly all of the Rec. 709 color space for SDR content, although it exhibits inaccuracies in blues and pinks. It also handles the broader Rec. 2020 color space reasonably well. Overall, the XGIMI Elfin delivers a decent performance, particularly in controlled lighting conditions, but has limitations in contrast and color accuracy. |
LightSource Life | 25000 Hours |
Control Method | Remote, Touch |
Wattage | 65 watts |
Connectivity Technology | Bluetooth, Wi-Fi, HDMI |
Hardware Connectivity | USB, HDMI, Bluetooth 5, 802.11 ac/b/g/n |
Other Features | Built-In Speaker, Auto Obstacle Avoidance, HDR10, Game Mode Low Latency Down to 26.3ms (AK off), 400 ISO, High transmittance coated lens, XGIMI OS, Auto Screen Alignment, Auto Focus |
L x W x H | 8.58"L x 2.52"W x 9.25"H |
System Experience | Overall Impression: This projector offers a user-friendly experience with its Android TV smart OS and full casting support, allowing for easy screen sharing from mobile devices. However, the inability to access Netflix may limit its appeal for those seeking comprehensive streaming options. The inclusion of two built-in 3W Harman Kardon speakers enhances audio quality, while Bluetooth 5.0/BLE support adds versatility for connecting external devices. Overall, it is a capable projector with useful features, but the absence of Netflix could be a significant drawback for some users. |
User Feedback
Pros:• Excellent image quality, surpassing expectations
• Lightweight and easily portable for versatile use
• Bluetooth compatibility for surround sound integration
• Auto keystone and focus features work effectively
• Great value for the price, especially during sales
• Creates a cinematic experience with large screen projection
• Inability to stream Netflix directly, although workarounds exist
• Limited warranty period of only 1 year
• Remote control lacks backlighting
• Few options for color and picture settings
• Slightly overpriced tripod
The Xgimi projector stands out as an impressive choice for those seeking a portable and high-quality viewing experience. It excels in image quality and versatility, making it suitable for various settings. While there are minor drawbacks, such as limited streaming options and remote functionality, the overall value and performance make it a strong contender in the projector market. Highly recommended for casual and movie enthusiasts alike.
