Amanda Brown
Active member
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | XGIMI Elfin Flip | XGIMI MoGo 2 Pro | XGIMI MoGo 3 Pro |
Picture | - | ||
Price | $399.99 | $349.99 | $449.99 |
Recommended Uses | Home Cinema | Home Cinema | Education, Outdoor, Home Cinema, Camping, Gaming, Business |
Highlight | Licensed Netflix: Pre-installed Netflix with remote control for easy content access. 1080P HD Clarity: 400 ISO lumens, full HD resolution, 113% Rec.709 color gamut for vivid colors. ISA Technology: Intelligent Screen Adaption with Auto Keystone Correction, Auto Focus, Obstacle Avoidance, Screen Alignment. Focus Options: Automatic and manual focus; remote control for adjustments. Compact Design: 2.5 inches thick, portable; built-in dual 3W speakers for quality sound. | Flexible Casting Combination: 120° adjustable stand, compact design, professional visual experience. Remarkable Lifelike Vision: 400 ISO lumens, D65 color temperature, 90% DCI-P3 color gamut. The Ultimate Portable Solution: Weighs 3.5 lb, fits in hand or bag, professional visual and sound experience. Intelligent Screen Adaption Technology: ISA 2.0, 3D ToF and CMOS, automatic keystone correction, autofocus. Non-stop Entertainment: Android TV 11.0, access to Netflix via customer support, versatile smart projector. | Bluetooth Connectivity: Automatic firmware updates enabled at startup Streaming Capabilities: Access to 10,000+ apps and 800+ free channels, including Google TV and Netflix Audio Quality: Dual 5-watt Harman Kardon speakers for loud, crisp sound Design and Functionality: 130° built-in stand, ISA 2.0 for auto-adjusted projection, metal slide rail for stability Image Quality: 450 ISO Lumens brightness, 90% DCI-P3 color gamut, 1080P resolution, screens up to 120 inches |
Screen Size | 80 Inches - 150 Inches | 40 Inches - 200 Inches | 40 Inches - 200 Inches |
Throw Distance | 10 - 10 Feet | 1 Meters - 6 Meters | 1.06 Meters - 5.3 Meters |
Contrast Ratio | - | - | 1000:1 or higher |
Display Resolution | 1920 x 1080 Pixels | 1920 x 1080 Pixels | 1920 x 1080 Pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1920 x 1080 |
Brightness | 400 Lumen | 400 Lumen | 450 Lumen |
Display Type | DLP | DLP | DLP |
Picture Quality Enhancement | - | HDR 10 | 4-point Keystone Correction( Vertical and Horizontal), ISA 2.0 uninterrupted auto focus, HDR 10, Intelligent Screen Alignment Intelligent Obstacle Avoidance, ISA 2.0 uninterrupted auto keystone |
Video Encoding | - | - | AVC |
Lamp Wattage | - | - | - |
Light Source Life | 25000 Hours | 25000 Hours | 25000 Hours |
Controller Type | - | Remote Control, Button Control | Remote Control |
Control Method | Remote, Touch | Remote, Touch | Remote, Touch |
Mount Type | Tabletop Mount | Tabletop Mount | Tabletop Mount |
Noteworthy Features | Built-In Speaker, Auto Obstacle Avoidance, HDR10, Game Mode Low Latency Down to 26.3ms (AK off), 400 ISO, High transmittance coated lens, XGIMI OS, Auto Screen Alignment, Auto Focus | Built-In Speaker, Auto Obstacle Avoidance, High Light Transmission Coated Lens, Intelligent Eye Protection, 4-point Keystone Correction( Vertical and Horizontal), ISA 2.0 uninterrupted Auto Keystone, Auto Screen Alignment, Auto Focus | Built-In Speaker, Built-In Netflix, Advanced Eye Protection, Intelligent Screen Alignment, Auto Focus in Seconds, Uninterrupted Auto Keystone Correction, Intelligent Obstacle Avoidance, Build-In Adjustable Stand, 450 ISO Lumens |
Connectivity
Connectivity Technology | Bluetooth, Wi-Fi, HDMI | Bluetooth, Wi-Fi, USB, HDMI | Bluetooth, USB |
Hardware Connectivity | USB, HDMI, Bluetooth 5, 802.11 ac/b/g/n | USB Type C, HDMI, USB 2.0 Type A, 3.5mm Audio, Bluetooth 5, 802.11 ac/b/g/n | USB Type C, Micro-HDMI, USB 2.0 |
Compatible Devices | - | Tablet | Laptop, Smartphone, Gaming Console |
Measurements
Dimensions L x W x H | 8.58"L x 2.52"W x 9.25"H | 7.56"L x 6.06"W x 5.2"H | 3.74"L x 3.74"W x 8.06"H |
Item Weight | 5.1 Pounds | 3.5 Pounds | 1.1 Kilograms |
Product | PROS AND CONS |
XGIMI Elfin Flip | Pros: • Extremely user-friendly and quick to set up • Stunning picture quality, especially vibrant colors for anime and animated content • Reliable auto-focus that works seamlessly • Compact, highly portable, and versatile—perfect for any room or ceiling projection • Quiet fan operation, so it doesn't distract from the experience • Effortless screen-sharing with phones and laptops • Creates a movie theater experience on flat surfaces Cons: • Not a lot of apps pre-installed • Fixed distance and screen size ratio may not suit larger rooms • Only one HDMI port available, which can be limiting for multiple devices • Warranty is only 1 year |
XGIMI MoGo 2 Pro | Pros: • Very good picture quality • Easy setup • Smart and intuitive interface • Compact design • Performs better than most similar products Cons: • Requires a dark room for optimal performance • Multiple passwords needed for Android TV access • Leaves a massive backlight around the video after autofocus • May need tech support for features like automatic calibration and keystone adjustment |
XGIMI MoGo 3 Pro | Pros • Excellent picture quality and brightness • Highly portable design • Built-in streaming services for convenience • Good battery life (approximately 2.5 hours) • Powerful built-in speaker with Harman Kardon audio • Smart tuning feature for easy setup • Great for family use and versatile entertainment options Cons • Bluetooth audio connection drops frequently • Lack of headphone jack complicates external speaker connections • Remote control can be laggy or unresponsive • Image quality diminishes in well-lit environments • No brightness adjustment option for different settings |
