Wielio Projector vs WiMiUS Mini Projector vs HOMPOW Projector: Which Offers a Better Home Cinema Experience?
Barend Ray
Active member
Wielio Projector​
WiMiUS Mini projector​
HOMPOW Projector​
$99.99​
$129.99​
$69.99​
Indoor​
Home Cinema​
Home Cinema​
Projector​
1* HDMI Cable, 1* Lens Cover, 1* S27 WiFi Bluetooth Mini Projector, 1* Power Cord, 1* Remote Control​
User Manual, Remote Control, Power Cable, HDMI cable, Lens Wipe​
Smart OS: Built-in smart Android OS with access to apps like YouTube, Netflix, Prime Video.
Connectivity: 5G/2.4G Dual-Band WiFi, Bluetooth 5.1 for easy device connection.
Resolution: Native 1080P Full HD, supports 4K.
Image Quality: Enhanced contrast and color accuracy for sharp visuals.
Keystone Correction: 4-point adjustment with ±30° range, zoom from 50% to 100%.
Projection Size: Projects images from 40 inches to 240 inches.
Portability: 120° rotatable stand for flexible installation.
Warranty: Up to 2 years warranty, 30-day return policy for quality issues.
Customer Support: 24-hour online support for user assistance.
Interfaces: HDMI, USB, 3.5mm audio port
Wireless Connectivity: 2.4G/5G Dual Band WiFi, Bluetooth 5.2
Screen Mirroring: Miracast, Airplay, wired screen mirroring
Resolution: 1080P supported
Contrast Ratio: 15000:1
Keystone Correction: Auto vertical keystone correction
Design: 270° built-in stand, custom mold, 1/4'' screw hole for mounting
Projection Size: 40~200 inches
Throw Distance: 2.8ft to 14ft
Aspect Ratios: 4:3, 16:9
Additional Features: Online Update (OTA), Auto Sleep mode, Brightness & Color Temperature Adjustment
Support: 24/7 after-sales support, 2-year Money Back guarantee, 3-year Repair, Lifetime Technical Support
Note: Not battery-powered, requires power during use; limitations on wireless mirroring of streaming services.
Resolution: 1920x1080 (Native Full HD)
Brightness: Higher brightness
Contrast Ratio: 10000:1
Audio: Built-in HiFi stereo speakers, Bluetooth 5.1
Screen Size: 50-300 inches
Projection Distance: 5.41-18.4 feet
Aspect Ratio: 4:3 / 16:9
Zoom Function: 50-100%
Keystone Correction: 15°
Compatibility: HDMI, AV, USB, 3.5mm headphone interface
Lamp Life: 50000 hours
Warranty: 2 years
Technical Support: Lifetime professional support
Unboxing Experience​
Wielio Projector:​
The compact design of this projector makes it incredibly portable, which is a major plus for my various setup needs. It doesn’t take up much space, yet it still manages to exude a solid build quality that gives me confidence in its durability. While it may not come with a screen, the aesthetic is simple and functional, allowing it to blend seamlessly into different environments, whether I'm using it indoors or outdoors.
WiMiUS Mini projector:​
The WiMiUS S27 Mini Projector has an appealing, compact design that makes it look modern and unobtrusive. Its lightweight build allows for easy portability, which is a significant advantage when considering usage across different locations, be it for movie nights indoors or outdoor gatherings. The 270° adjustable stand not only adds to its aesthetic but also enhances functionality, allowing for versatile positioning without the need for bulky mounts or tripods.
HOMPOW Projector:​
The projector sports a sleek and compact design, making it easy to fit into various spaces without looking out of place. Its appearance is modern and minimalistic, which is a plus for those who prefer a more streamlined look in their home theater setup. The build quality feels decent for the price, with hard plastic materials that maintain a lightweight feel while not compromising on sturdiness. Overall, it looks like a well-thought-out product that fits into the aesthetics of a tech-savvy environment.
Wielio Projector​
HOMPOW Projector​
40 Inches - 200 Inches​
1 - 3.8​
3.6 - 17.7 Feet​
5.41 Feet - 18.4 Feet​
15000:1​
10000:1​
1080P Pixels​
1920 x 1080 Pixels​
1920 x 1080 Pixels​
1280 x 720​
9500 Lumen​
Wielio Projector:​
The viewing experience has been absolutely impressive. The image quality is sharp and bright, even in moderately lit rooms, which is a huge plus for movie nights and presentations alike. The colors are vivid, adding a cinematic feel to everything from family films to gaming sessions. Streaming via WiFi was seamless, eliminating the hassle of tangled cables, and the ability to adjust the picture size made it adaptable for different viewing setups. However, while the picture clarity is commendable, I did notice that text clarity can sometimes fall short, particularly with crispness on the edges.
My viewing experience with the WiMiUS S27 has been exceptional, especially considering its price. The 1080P resolution and a contrast ratio of 15000:1 deliver sharp images and vibrant colors, creating an engaging movie-watching experience. Whether I'm using it in a dark room or during the day, the picture quality remains impressive, though the brightness is optimal in darker conditions. The ability to project onto various surfaces, including ceilings, has added a fun twist to movie nights, making it enjoyable for both adults and kids alike.
HOMPOW Projector:​
The picture quality is surprisingly good for the price point, offering clear and vibrant images, especially when projected onto a white wall. I did note that brightness can struggle in well-lit environments, but that’s a common issue with budget projectors. Sound quality is decent for an in-built speaker, though it lacks bass depth—pairing it with external speakers significantly enhances the cinematic experience. While the focus can be tricky when projecting at an angle, using a tripod can mitigate this issue. For casual viewing, it performs admirably, but it may not meet the standards for professional presentations or detailed artwork.
Wielio Projector​
HOMPOW Projector​
smart projector with wifi and bluetooth, projector with wifi and bluetooth, mini projector, projector, 1080P projector​
Portable, Lightweight, ①After-sales: [email protected], Built-In Wi-Fi, Built-In Handle​
Native 1080P Full HD resolution with 4K support, 100%-50% zoom, Built-in dual hi-fi speakers, Brighter, 9500lux, clearer picture quality, With auto sleep timer​
H.265​
MPEG1/MPEG2/H.263/H.264/AVS/VC1/MJPEG/RV30/RV40/HEVC​
24 Watts​
50000 Hours​
50000 Hours​
Ethernet​
Wired/Wireless/Bluetooth/WiFi/HDMI/USB/3.5Audio​
HDMI
Laptop, Television, Smartphone​
Laptop, TV stick, PC, XBOX, Smartphone​
200 watts​
60 watts​
Mount Type​
Ceiling Mount​
Table Mount/Wall Mount/Ceiling Mount​
Tabletop Mount​
3"L x 5"W x 6"H​
4.6"L x 3.9"W x 7.9"H​
8.35"L x 6.77"W x 3.15"H​
Wielio Projector:​
Setting up the projector was remarkably straightforward. I appreciated the plug-and-play functionality that required minimal adjustments, which made the initial experience hassle-free. The inclusion of multiple connection options, such as HDMI, USB, and AV, allowed me to easily hook up devices like my Fire Stick and gaming consoles. The remote control is well-designed and user-friendly, making it easy to navigate through settings. Moreover, the auto keystone feature was an excellent addition for quickly achieving the perfect projection.
Setting up the WiMiUS S27 was a breeze, characterized by a user-friendly interface and straightforward instructions. The initial connection process was quick, with options to connect via HDMI or wirelessly through Bluetooth and WiFi. Although there were minor hiccups with Bluetooth connections for external speakers, the overall ease of installation and the auto keystone correction feature significantly reduced the hassle of aligning the projection, making it a convenient choice for anyone new to projectors.
HOMPOW Projector:​
I found the setup process to be incredibly straightforward. Within minutes, I was able to get it connected and ready to stream my favorite shows. The inclusion of multiple input options, such as HDMI and USB ports, facilitates ease of use with various devices. However, I did notice that the power cord is relatively short, which might require an extension cord for optimal placement. Additionally, the lack of native mounting options is a slight drawback, though I resolved it by using a tripod. Overall, the system is user-friendly, perfect for anyone not particularly tech-savvy.
Wielio Projector:​
• Excellent image quality with sharp details
• Bright and vibrant colors, even in moderately lit rooms
• Easy setup with multiple connection options
• Compact and portable design
• User-friendly remote control
• Built-in speakers could be improved; external speakers are recommended
• Some users experienced overheating issues
• Auto-focus feature may not be reliable for all units
• Occasional issues with text clarity
Overall, I find this projector to be a fantastic option for anyone seeking a budget-friendly yet high-quality device. Its performance strikes a balance between impressive image quality and user-friendliness, making it suitable for various applications—be it family movie nights, outdoor gatherings, or business presentations. While there are minor drawbacks, such as sound quality and occasional focus issues, the overall value for the price is hard to beat. I highly recommend this projector for its versatility and performance, and I look forward to seeing how it holds up over time.
• Short throw design allows for large projections in small spaces.
• True 1080P resolution with vibrant image quality.
• User-friendly setup with auto keystone correction.
• Versatile connectivity options including WiFi and Bluetooth.
• Lightweight and portable, ideal for various settings.
• Built-in speakers are decent but not powerful enough for larger spaces.
• Some users reported issues with Bluetooth connectivity and lag.
• Limitations on direct streaming from certain apps due to copyright restrictions.
Overall, the WiMiUS S27 Mini Projector has exceeded my expectations with its combination of quality, portability, and affordability. It stands out as a reliable choice for anyone seeking a projector that delivers a great viewing experience without the hefty price tag often associated with high-end models. While it has some minor drawbacks, especially regarding its sound quality, the projector's features and performance make it a fantastic investment for home entertainment or outdoor movie nights. I would highly recommend the WiMiUS S27 to anyone in the market for a versatile and user-friendly projector.
HOMPOW Projector:​
• Easy to set up and use
• Good sound quality from built-in speakers, with external speakers providing even better audio
• Great picture quality for its price
• Excellent customer service
• Runs a bit hot, raising concerns about long-term durability
• Lacks native mounting options and focus can be tricky at angles
• Power cord is short, may need an extension
• Does not stream from mobile devices
• Limited connectivity options for modern encodings
Overall, I would rate this projector as a solid 9 out of 10. It’s an excellent value for anyone looking for an affordable way to create a home theater experience without breaking the bank. While it has its shortcomings, particularly regarding heat management and mobile connectivity, it delivers on its promises of functionality and quality. Whether you're a college student or just someone looking to enjoy movies without the hassle of a large TV, this projector is a fantastic option. I would highly recommend it to anyone in the market for a budget-friendly projector.
The Wielio Projector is super compact and a breeze to set up! You get awesome picture quality for the price. The built-in sound is just okay, but it pairs well with external speakers. Plus, it has multiple connections and is super easy to use!
Hellopi314
Wielio Projector is a steal! For its size and price, it gives a super clear and big picture from a decent distance. Just make sure the room's dark by covering the windows. I was surprised by how good it is for the price. Totally recommend it for family movie nights or events—10/10!
I got the WiMiUS Mini projector for my daughter, and it’s awesome for the price! Super happy it has Bluetooth and Wi-Fi. It works best with a Firestick connected through HDMI so she can watch whatever she wants, no limits!
yodathekid
I just tried out the HOMPOW projector for the first time to make sure it’s good since it’s a Christmas gift. The picture quality is amazing and the image is huge! Can’t wait to use it for real!
