Which screen material is better work for Epson CH-TZ1000 projector?
The following four projection screen material are from VIVIDSTORM, namely Obsidian Long-Throw Ambient Light Rejecting screen, 3D Obsidian Long-Throw Ambient Light Rejecting screen, Cinema White screen and Pearlescent Cinema White Plus screen. Using Epson CH-TZ1000 projector, which one do you think is better?
Tomy
Epson CH-TZ1000, its brightness is 2700lumen,Obsidian Long-Throw Ambient Light Rejecting screen is enough for your projector
ameliaalsa
The Bauhn LED projector Review may even be worth considering if you’re searching for a reasonably priced LED projector. A 1500:1 contrast ratio, full HD resolution, and a lamp life of up to 30,000 hours are just a few of the outstanding characteristics of this adaptable projector. Fine Projector will be examined in more detail in this evaluation to determine whether it is cost-effective.read more
