LouiseWinner
PS4 should be paid attention to when using, because not everyone has a worry-free channel to repair. The following points need to pay more attention.
1. Do not hot-plug the HD cable, turn it off before operating, otherwise static electricity may cause damage. You can't hot-plug the power cord, and you won't be able to pull it out in most cases, so there is nothing to say.
2. The handle must be charged with the original charging cable plugged into the machine. Do not use other cables and charging heads, especially never use a power bank to charge the handle. Some people use a power bank to charge the handle. The handle is actually very delicate, and the unstable condition during charging will cause more damage to it.
3. It is best to leave a distance of 12 to 15cm or longer behind the machine, and do not stick the wall too close to the back of the machine for heat circulation.
4. During operation, the ps4 host should be placed horizontally, not upright like in the promo or advertising picture, I forgot the specific adverse effects
5. There is no need to add any extra radiator to the machine. There is a usb-powered radiator on the Internet, which is plugged into the back of the ps4, and a small fan assists heat dissipation. This is actually not obvious, and the introduction of external forced heat dissipation will speed up the machine The drying speed of the silicone grease inside
6. After using the laptop for a period of time, someone will go to find a repairer to dust it. Therefore, if possible, you or find someone to disassemble the machine for maintenance once a year, mainly with some silicone grease. But this step is not necessary, my machine has not been maintained for three years
7. Put a rocker cap on the rocker of the handle. The ps rocker feels good, but it may crack if it runs for a long time.
