Danieladbidh
Use a projection screen in an outdoor setting, but there are several factors you should consider before doing so:
Brightness: Outdoor settings are generally brighter than indoor settings, and as a result, you need a brighter projector and screen to achieve optimal visibility. It's best to choose a screen and projector with a high lumen rating.
(VIVIDSTORM ALR Screen and Dangbei projector)
Weather Resistance: Outdoor projection screens should be designed to withstand weather conditions such as wind, rain, and sunlight. Look for screens that are made from weather-resistant materials, such as PVC or vinyl.
Viewing Distance: Outdoor screens are typically viewed from a greater distance than indoor screens. Consider the size of your audience and the distance they will be sitting from the screen when selecting a screen size.
Screen Material: The material of your screen is important as it will affect the picture quality. Screens made from PVC, vinyl or fabric material with a high gain and contrast ratio are best for outdoor settings.
Placement: Placement of the screen is important for optimal viewing experience. The screen should be positioned in a location that allows for easy viewing and minimizes any obstacles such as trees, buildings, or other structures.
Power source: Outdoor screens require a power source, so ensure you have access to an outlet or generator to power the projector.
Ambient Light: Outdoor screens are subject to more ambient light than indoor screens, so choose a location with less light pollution or wait until it is dark outside.
