What are the differences between white plastic curtain and white fiberglass projector screens
Xmint
What is the difference we see the usual white plastic curtain and white glass curtain? In addition to the differences in materials, what are the advantages and disadvantages? What scenarios are applicable?
The difference between white plastic curtain and white fiberglass curtain
White plastic curtain:
white plastic curtain can increase the projector effect by 1.1 times, the viewing angle is greater than 160 degrees, but in terms of material, it is the most common PVC, the workmanship is relatively rough, the surface has The texture is not as clear as the white glass fiber, but it is better than the white wall.
White glass fiber curtain: white glass fiber can increase the projection effect by 2.5 times, the viewing angle is greater than 160 degrees, hesitant white glass fiber is made of special effect high-definition material, so it does not need to be smoothed, and the natural stretch will be straight, In the case of large temperature difference and climate change, it can still be kept straight, and the bright color of the effect can increase the contrast and saturation. White glass fiber can also be protected against moisture, mildew, and cleaning, has a long service life, and has a relatively high cost performance.
Pros and Cons of white plastic & white glass fiber curtain
Compared with white plastic, although white glass fiber is more expensive, the color gain is better than white plastic, and it will not be dented.
White plastic
Advantages: gain 1.0, true color reproduction, washable, easy maintenance​
Disadvantages: when the temperature is low, it will be nested, but it does not affect the viewing of the​
summary. Summary: cost-effective, delicate fabric, suitable for high-brightness projectors​
usage: office, home , Bath, hotel, engineering project,​
white glass fiber
Advantages: gain 1.1, true color reproduction, cleanable, easy to maintain, woven with glass fiber, strong hardness​
Disadvantages: slightly expensive price​
Summary: In addition to the slightly expensive price, others are good​
usage: Office , Family, hotel, engineering project​
