Barend Ray
Active member
- 1 First Impressions
- 2 Introduce
- 3 System
- 4 Display
- 5 Audio
- 6 Features
- 7 Connectivity
- 8 User Feedback
First Impressions
The Westinghouse 32" Roku TV boasts a sleek and compact design, making it an appealing addition to various spaces such as kitchens, craft rooms, and campers. Its edgeless screen design is visually pleasing, and its relatively small size allows it to fit seamlessly into tight spots. The overall aesthetic is modern and functional, which many users have appreciated for its unobtrusive presence in their homes.Introduce
Parameter | Westinghouse Roku TV 24 Inch TV |
Reference Price | $124.99 |
Model Year | 2023 |
Specific Uses | Home Viewing |
Built-In Media | Smart TV, Roku |
Highlight | High Definition Roku TV – your streaming experience has never been easier. Our 24 inch flat screen TV brings you a clearer, more detailed picture, with 720p progressive scan frame rates that deliver less flicker and better fast motion action. Roku TV, America’s #1 Streaming platform – Cord Cutters can stream 350+ free live TV channels, 1,000’s of Streaming Apps, hit Movies & TV, Music, and Premium channels. Access one of the broadest selections of streaming apps like Netflix, Prime Video, MAX, Apple TV+, Disney+, ESPN+, Hulu, Fox Sports, YouTube TV, Pluto TV, Peacock, NFL for entertainment your way. A Perfect Fit for your Smart Home – Pair your Roku LED TV to Find and Play entertainment, control streaming, turn on the TV and more with Siri, Alexa or Hey Google. Compatible with Amazon Alexa, Google Assistant-enabled, and Apple HomeKit devices. Cast Your Content & Entertainment – Sync videos, music, or photos from your device to your TV using the free Roku Mobile App or Apple AirPlay2. Connectivity is King – Packed with 3 x HDMI, 1 x Composite Video, 1 x Optical Digital Audio inputs for maximum flexibility. A full array of inputs to connect your cable box, game console, streaming stick, sound bar, DVD/Blu-ray player or a digital antenna for local channels. |
System
Operating System | Roku OS |
Internet Applications | Paramount+, Discovery+, HBO Max, Peacock, Disney +, Apple TV +, Netflix, Prime Video, Google Play, SHOWTIME, PBS, YouTube, CNN, Pandora, Spotify, Peloton, Sling TV, Hulu, Pluto TV, CBS All Access, Bravo, NBC Sports, MLB, NFL, NHL, NBA and more! Access your cable box, use an HDTV antenna, or start streaming with 500,000+ movies and TV episodes available across thousands of free or paid channels. |
Remote Control | Wi-Fi Direct |
System Experience | Setting up this TV was a breeze for most users, often taking just a few minutes from unboxing to being ready to watch. The assembly of the legs and connecting to cable was straightforward, and the Roku operating system made navigating through channels and apps intuitive. Many found the process to be plug-and-play, enhancing the overall user experience, especially for those who may not be tech-savvy. |
Aspect Ratio | 16:9 |
Display Technology | LED |
Screen Finish | Flat |
Has Color Screen | Yes |
Resolution | 720p |
Refresh Rate | 60 Hz |
Viewing Angle | 170 Degrees |
HDR Format | HDR10 |
Backlight Technology | LED |
Backlight Setting | LED |
Motion Enhancement | [Basic] |
Viewing Experience | The picture quality has received mixed reviews; while many users found it to be clear and bright, some noted that it doesn't reach full HD standards. However, others have successfully paired it with a high-end Roku stick for improved visuals. The clarity and brightness of the screen, along with vibrant colors, have been appreciated, especially in smaller rooms like kitchens or trailers, where the TV is often placed. |
Audio
Audio Channels | 2.0 |
Surround Sound | Dolby Audio |
Audio Output | Digital |
Audio Input | Optical, HDMI |
Speaker Description | A pair of built-in 5W speakers |
Speaker Output Power | 5 Watts |
Audio Experience | The audio quality of this television is generally considered satisfactory, particularly given its size; however, some users mentioned that the sound can be a bit thin. For users who desire a richer audio experience, pairing the TV with a soundbar is a common solution. Overall, the sound quality is deemed adequate for casual viewing, especially in smaller spaces. |
Video Encoding | AVC |
Screen Mirroring | Miracast |
Tuner Type | ATSC |
Voltage | 120 Volts (DC) |
Power Consumption | 40 Watts |
Other Features | Flat |
Mount Standard | 100 x 100 mm |
D x W x H | 6.3"D x 21.6"W x 14.5"H |
Motion & Gaming | The TV's capabilities for gaming have not been extensively detailed in the reviews, but its easy setup and remote functionality suggest it can serve well for basic gaming needs. Users have appreciated the simplicity of connecting other devices like Blu-ray players, indicating that it should perform adequately for casual gaming experiences. |
Connectivity
Connectivity Technology | Wireless |
Bluetooth Version | 4.2 |
Wireless Technology | Wi-Fi |
Usb Ports | 1 |
USB2.0 Ports | 1 |
USB3.0 Ports | 1 |
HDMI Ports | 3 |
Connector Type | HDMI |
Signal Format | digital |
Hardware Interface | Component Video, HDMI, Headphone, USB 2.0 |
Compatibility | The TV is equipped with the Roku platform, providing access to various streaming channels and apps. Users found the built-in features beneficial, especially for watching local news and series. However, some noted that navigating through the movie options could be cumbersome, as scrolling for information was their primary method of finding content. |
User Feedback
Pros:• Easy to set up and use
• Sleek and compact design
• Good picture quality for its size
• Built-in Roku platform with various apps
• Satisfactory sound quality for casual viewing
• Picture quality may not be HD
• Audio can be thin without additional speakers
• Limited navigation features for movie browsing
• Screen reflection issues in bright rooms
• Complicated customer support experience
The Westinghouse 32" Roku TV is a solid choice for those seeking an affordable, compact smart TV for smaller spaces. While it excels in ease of use and setup, and offers a decent viewing experience, potential buyers should keep in mind the limitations regarding picture resolution and sound quality. For casual viewing and basic streaming needs, this TV is a reliable option that many users have found satisfactory.
