Westinghouse 32 Inch Flat Screen TV Review: A Budget-Friendly 720p Option Worth Considering?
ApaHualpa
First Impressions​
The Westinghouse 32” Roku TV boasts a sleek and compact design, making it an ideal fit for small spaces such as kitchens, craft rooms, or RVs. Its edgeless screen design adds a modern touch, while the overall aesthetic is clean and unobtrusive, allowing it to blend seamlessly into various environments. Users appreciate its size as it is one of the largest options available among smaller TVs, making it a practical choice for those seeking a smart television without the bulk.
Westinghouse 32 Inch TV TV​
$139.99​
Model Year​
2023​
Specific Uses​
Home Viewing​
Smart TV, Roku​
Highlight
High Definition Roku TV – your streaming experience has never been easier. Our 32 inch flat screen TV brings you a clearer, more detailed picture, with 720p progressive scan frame rates that deliver less flicker and better fast motion action.
Roku TV, America’s #1 Streaming platform – Cord Cutters can stream 350+ free live TV channels, 1,000’s of Streaming Apps, hit Movies & TV, Music, and Premium channels. Access one of the broadest selections of streaming apps like Netflix, Prime Video, MAX, Apple TV+, Disney+, ESPN+, Hulu, Fox Sports, YouTube TV, Pluto TV, Peacock, NFL for entertainment your way.
A Perfect Fit for your Smart Home – Pair your Roku LED TV to Find and Play entertainment, control streaming, turn on the TV and more with Siri, Alexa or Hey Google. Compatible with Amazon Alexa, Google Assistant-enabled, and Apple HomeKit devices.
Cast Your Content & Entertainment – Sync videos, music, or photos from your device to your TV using the free Roku Mobile App or Apple AirPlay2.
Connectivity is King – Packed with 3 x HDMI, 1 x Composite Video, 1 x Optical Digital Audio inputs for maximum flexibility. A full array of inputs to connect your cable box, game console, streaming stick, sound bar, DVD/Blu-ray player or a digital antenna for local channels.
System​
Operating System​
Roku OS​
Internet Applications​
Paramount+, Discovery+, HBO Max, Peacock, Disney +, Apple TV +, Netflix, Prime Video, Google Play, SHOWTIME, PBS, YouTube, CNN, Pandora, Spotify, Peloton, Sling TV, Hulu, Pluto TV, CBS All Access, Bravo, NBC Sports, MLB, NFL, NHL, NBA and more! Access your cable box, use an HDTV antenna, or start streaming with 500,000+ movies and TV episodes available across thousands of free or paid channels.​
Voice Command, Infrared, Bluetooth​
Voice Control​
Setting up the TV is a breeze; users have reported that the entire process takes just a few minutes. After unpacking, attaching the legs, and connecting to Wi-Fi, the TV is ready to go. The Roku interface is intuitive, and users can easily add streaming apps and their TV provider. However, some have noted challenges with navigating the Roku selections and finding specific content, as browsing through movies can be a bit tedious.
Aspect Ratio​
16:9​
Display Technology​
LED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
720p​
Refresh Rate​
60 Hz​
Response Time​
6.5 Milliseconds​
Viewing Angle​
170 Degrees​
Backlight Technology​
LED​
Backlight Setting​
Adjustable​
Backlight Configuration​
Edge-Lit​
Motion Enhancement​
6.5 ms response time​
Viewing Experience
The picture quality is generally praised, with bright and clear visuals that enhance the viewing experience for casual TV watching. However, some users mention that the resolution is not HD, which can be a drawback for those seeking a higher-quality image. Despite this, the clarity and color richness are appreciated, especially for its size. In bright environments, the screen's lack of anti-reflection or anti-glare coating can hinder visibility during the day.
Audio​
Audio Channels​
2.0​
Surround Sound​
Dolby Digital​
Audio Output​
Digital​
Audio Input​
Optical, HDMI​
Speaker Description​
Pair of built-in 5W speakers​
Speaker Output Power​
5 Watts​
Audio Experience
Users have mixed feelings about the sound quality. While many find the audio quality satisfactory for such a small television, some describe it as slightly thin. This has led to suggestions of pairing the TV with a soundbar for a more robust audio experience. Overall, the sound quality is considered adequate for general viewing, but those with higher expectations may want to explore external audio options.
AVC​
Screen Mirroring​
Miracast​
Amazon Alexa, Google Assistant, Apple HomeKit, Mobile Devices, Sound Bar, DVD/Blu-ray player, Digital Antenna, Cable Box, Game Console, Streaming Stick​
Water Resistance​
Not Water Resistant​
Tuner Type​
ATSC​
Voltage​
240 Volts​
Line Voltage​
220 VAC 50 Hz​
Flat​
Mount Standard​
100 x 100 mm​
D x W x H​
6.69"D x 28.8"W x 18.01"H​
Motion & Gaming
The TV is not specifically highlighted for gaming, but its easy setup with HDMI ports makes it compatible with gaming consoles. Users have not specifically mentioned using it for gaming, but the clear picture quality and straightforward connectivity suggest it could serve as a suitable option for casual gaming sessions.
Connectivity​
Wireless​
Wireless Technology​
Wi-Fi​
Usb Ports​
1​
USB2.0 Ports​
1​
USB3.0 Ports​
1​
Audio Out Ports​
1​
HDMI Ports​
3​
Connector Type​
HDMI​
Signal Format​
digital​
Sharing Direction​
Mobile to TV​
Hardware Interface​
Component Video, HDMI, Headphone, USB 2.0​
Compatibility
The Westinghouse Roku TV comes with built-in smart capabilities, allowing access to various streaming platforms via the Roku interface. Users appreciate the voice control feature of the remote, which enhances usability. The TV's ability to connect with cable providers through their respective apps is also a noted advantage, although some users desire more efficient channel browsing options.
User Feedback​
• Easy to set up and use
• Compact and modern design
• Good picture clarity and color richness
• Built-in Roku for streaming options
• Affordable price
• Sound quality may be thin without additional speakers
• Not HD resolution, which may disappoint some users
• Lack of anti-reflection coating affects visibility in bright rooms
• Navigation through Roku selections can be cumbersome
The Westinghouse 32” Roku TV is an excellent choice for those seeking an affordable, compact smart television for smaller spaces. It delivers good picture quality and ease of use, making it suitable for casual viewing. While it may not satisfy users looking for high-definition resolution or superior sound, its overall value, simple setup, and smart features make it a highly recommended option for budget-conscious consumers in need of a secondary TV.
Awesome price and the size is just right for the kitchen! Super easy to set up, and the remote is a breeze for my mom. She’s loving all the free channels and ditching cable TV!
fosterzar
I'm obsessed with my new Edgeless 32" Roku TV! Awesome price, killer picture and sound. Shipping was super fast, and it only took me five minutes to set up. It's perfect for my room! Totally recommend Westinghouse for a Roku TV. Thanks a ton!
Astro51450
Awesome little TV for our horse trailer! Fits just right, connects to our WiFi from the house even through the wall! Good picture and decent sound for its size. Super easy to set up and compact too! Totally worth it!
