Barend Ray
Active member
- 1 First Impressions
- 2 Introduce
- 3 System
- 4 Display
- 5 Audio
- 6 Features
- 7 Connectivity
- 8 User Feedback
First Impressions
The Westinghouse 32" Roku TV presents a sleek and modern design, making it an attractive addition to any room. Its compact size is perfect for smaller spaces, such as kitchens, craft rooms, or RVs, while the edgeless screen enhances the viewing area. The overall aesthetic is pleasing, and it fits well in diverse environments, from living quarters to garages.Introduce
Parameter | Westinghouse 24 Inch TV TV |
Reference Price | $124.99 |
Model Year | 2023 |
Specific Uses | Home Viewing |
Built-In Media | Smart TV, Roku |
Highlight | High Definition Roku TV – your streaming experience has never been easier. Our 24 inch flat screen TV brings you a clearer, more detailed picture, with 720p progressive scan frame rates that deliver less flicker and better fast motion action. Roku TV, America’s #1 Streaming platform – Cord Cutters can stream 350+ free live TV channels, 1,000’s of Streaming Apps, hit Movies & TV, Music, and Premium channels. Access one of the broadest selections of streaming apps like Netflix, Prime Video, MAX, Apple TV+, Disney+, ESPN+, Hulu, Fox Sports, YouTube TV, Pluto TV, Peacock, NFL for entertainment your way. A Perfect Fit for your Smart Home – Pair your Roku LED TV to Find and Play entertainment, control streaming, turn on the TV and more with Siri, Alexa or Hey Google. Compatible with Amazon Alexa, Google Assistant-enabled, and Apple HomeKit devices. Cast Your Content & Entertainment – Sync videos, music, or photos from your device to your TV using the free Roku Mobile App or Apple AirPlay2. Connectivity is King – Packed with 3 x HDMI, 1 x Composite Video, 1 x Optical Digital Audio inputs for maximum flexibility. A full array of inputs to connect your cable box, game console, streaming stick, sound bar, DVD/Blu-ray player or a digital antenna for local channels. |
System
Operating System | Roku OS |
Internet Applications | Paramount+, Discovery+, HBO Max, Peacock, Disney +, Apple TV +, Netflix, Prime Video, Google Play, SHOWTIME, PBS, YouTube, CNN, Pandora, Spotify, Peloton, Sling TV, Hulu, Pluto TV, CBS All Access, Bravo, NBC Sports, MLB, NFL, NHL, NBA and more! Access your cable box, use an HDTV antenna, or start streaming with 500,000+ movies and TV episodes available across thousands of free or paid channels. |
Remote Control | Wi-Fi Direct |
System Experience | Setting up the TV is a breeze. Users report that it takes just a few minutes to unbox, attach the legs, and connect it to Wi-Fi or cable services. The Roku interface is intuitive, making it simple to navigate through channels and apps, and the ease of adding TV providers to the app menu is appreciated. Overall, the setup process is user-friendly, even for those who may not be tech-savvy. |
Aspect Ratio | 16:9 |
Display Technology | LED |
Screen Finish | Flat |
Has Color Screen | Yes |
Resolution | 720p |
Refresh Rate | 60 Hz |
Viewing Angle | 170 Degrees |
HDR Format | HDR10 |
Backlight Technology | LED |
Backlight Setting | LED |
Motion Enhancement | [Basic] |
Viewing Experience | The picture quality is generally described as good, with bright and clear visuals; however, some users note that it doesn't quite reach HD standards without an additional Roku stick. The ability to access local channels and streaming services is a significant advantage, although navigating through content can sometimes be cumbersome due to the limited search options. |
Audio
Audio Channels | 2.0 |
Surround Sound | Dolby Audio |
Audio Output | Digital |
Audio Input | Optical, HDMI |
Speaker Description | A pair of built-in 5W speakers |
Speaker Output Power | 5 Watts |
Audio Experience | The sound quality is considered adequate for the TV's size, providing a satisfactory audio experience for casual viewing. Some users mention that the audio can be a bit thin but suggest that a soundbar could enhance the listening experience. Overall, it delivers decent sound for everyday use, particularly in smaller spaces. |
Video Encoding | AVC |
Screen Mirroring | Miracast |
Tuner Type | ATSC |
Voltage | 120 Volts (DC) |
Power Consumption | 40 Watts |
Other Features | Flat |
Mount Standard | 100 x 100 mm |
D x W x H | 6.3"D x 21.6"W x 14.5"H |
Motion & Gaming | There are no specific comments about gaming capabilities, but the TV's easy setup and streaming options could make it suitable for casual gaming experiences. Its compatibility with HDMI devices allows for connecting gaming consoles, although performance details were not extensively covered in the reviews. |
Connectivity
Connectivity Technology | Wireless |
Bluetooth Version | 4.2 |
Wireless Technology | Wi-Fi |
Usb Ports | 1 |
USB2.0 Ports | 1 |
USB3.0 Ports | 1 |
HDMI Ports | 3 |
Connector Type | HDMI |
Signal Format | digital |
Hardware Interface | Component Video, HDMI, Headphone, USB 2.0 |
Compatibility | This TV is equipped with built-in Roku, providing access to a wide range of streaming apps and channels. The remote control offers both voice and button functionality, enhancing user convenience. However, some users found the Roku selections to be limited and noted that channel surfing could be more efficient with a dedicated cable remote. |
User Feedback
Pros:• Easy setup and installation
• Good picture and sound quality for the size
• Compact design fits well in smaller spaces
• Built-in Roku provides access to numerous streaming options
• Intuitive remote control with voice capabilities
• Picture quality may not reach HD without additional devices
• Limited channel navigation without a cable remote
• Anti-reflection screen issues noted in bright environments
• Customer support experiences reported as frustrating
The Westinghouse 32" Roku TV is a solid choice for those seeking a compact, affordable smart TV that excels in ease of use and functionality. While it may not deliver top-tier picture quality, it meets the needs of users looking for a simple solution for streaming and basic viewing. Despite some minor drawbacks, such as reflections on the screen and customer support challenges, the overall satisfaction from users indicates that it is a worthwhile investment for smaller spaces.
