An IMDB tomato
Weapon management is the subject of special care in Red Dead Redemption 2 . Each firearm can be personalized: barrel, sight, quality of metal, ornaments… you can really make your revolvers and rifles a signature. But beyond that you have to keep in mind that the weapons will get dirty. They must therefore be cleaned regularly, if you do not do so they will lose their effectiveness and will eventually deteriorate completely. Maintenance can be done on the fly or at the gunsmith's, it also involves the acquisition of better holstersto protect it from mud and dust. In town remember to systematically sheath your weapon to avoid creating misunderstandings, you do not want a wanted notice on your head when you simply wanted to buy cans.
Weapon management walkthrough in Red Dead Redemption 2
Weapon management in Red Dead Redemption 2
Your guns aren't just for killing bandits in the shootings. You can for example point a trader to steal it but also intimidate a recalcitrant interlocutor. By aiming and then holding the up key on the directional pad, you aim your weapon at the sky. Pulling a vacuum in this way allows animals, such as the horses of your future victims, to flee, or, on the contrary, attract enemies to create a diversion. If you are caught short, know that by pressing the trigger very quickly twice in a row you can make a quick shot at the hip. An imprecise function but which can make the difference in the event of an attack or surprise provocation.If you really want to kill as few people as possible know that it is possible to disarm your enemies by shooting them in the hand. A gesture that requires a lot of precision and also the use of the coolness gauge. In the same order of idea if a hat interests you you can remove it from the head of an NPC by pulling it, you can pick it up once it is on the ground.
If you use the basic semi-assisted aiming of the game it will lock on the chest of the closest targets. To be more effective, try to make headshots : simply orient the crosshair slightly upwards after locking to reach the head. With habit, it almost becomes a rhythm game and you can easily chain headshots. Last thing, by quickly tapping twice on the button to sheath your revolver you will do it but doing acrobatics with your weapon. Useless, yes, but devilishly classy.
