Bellmeister
Unboxing Experience
- 1.1.1 VOPLLS Mini Projector:
- 1.1.2 Lisowod Mini Projector:
- 1.1.3 ONOAYO AY2Pro Projector:
- 1.2 Display
1.3
Viewing Experience
- 1.3.1 VOPLLS Mini Projector:
- 1.3.2 Lisowod Mini Projector:
- 1.3.3 ONOAYO AY2Pro Projector:
- 1.4 Features
1.5
- 1.5.1 VOPLLS Mini Projector:
- 1.5.2 Lisowod Mini Projector:
- 1.5.3 ONOAYO AY2Pro Projector:
1.1
Unboxing Experience
- 2 Conclusion
Parameter | VOPLLS Mini Projector | Lisowod Mini Projector | ONOAYO AY2Pro Projector |
Picture | |||
Reference Price | $69.99 | $169.99 | $168.99 |
Recommended Uses | Indoor/Outdoor | Projector with Wifi and Bluetooth for Gaming,Mini Projector for Home Cinema,Projector that connects to iphone,projector for camping,outdoor projector,projector with speaker,projector for home,projector for ceiling viewing | Education, Home Cinema, Gaming |
Built-In Media | User Manual, Power Cord, Remote, HDMI Cable, AV Cable | User Manual*1, Remote*1(No battery included), HDMI Cable*1, L02 Mini Projector*1, Adaptor*1 | Power Cord*1, Mini Projector*1,Portable carrying strap*1, User Manual*1, HDMI Cable*1, Remote*1(no battery included) |
Highlight | Resolution: 1080P Full HD Size: 6.69 x 4.9 x 2.64 inches Weight: 1.4 lb Projection Size: 35” to 210” Projection Distance: 3.7 ft to 23.6 ft (Optimal: 6.5 ft - 8.2 ft) Audio: Built-in Hi-Fi stereo speakers, audio output port Noise Reduction: 80% reduction in fan noise Device Compatibility: Laptops, smartphones, tablets, USB drives, X-Box Limitations: Requires extra HDMI adapter for phone, streaming services accessible via TV Stick or Roku only, not compatible with Roku remote, no Bluetooth support. | 360° Adjustable & Detachable Stand: Allows projection from any angle; easy to move and store. Durability: Lifespan over 10,000 hours; suitable for daily use for over five years. Connectivity: WiFi 6 dual-band (5G and 2.4G), Bluetooth 5.2 for stable connections with external devices. Audio: Built-in dual 8W Hi-Fi speakers for immersive sound. Streaming Compatibility: Works with TV Stick for Netflix, Amazon Prime; no built-in app lag. Resolution & Brightness: Native 1080P FHD; 500 ANSI lumens; 20,000:1 contrast ratio; superior brightness with advanced technology. Price: Under $100, plus potential additional cost for TV stick. | Portability: Includes carrying strap for easy transport Packaging: Festive design, no additional wrapping needed Image Adjustment: Automatic correction of distortion and remote fine-tuning Video Quality: 1080P resolution Bluetooth Functionality: Connects to Bluetooth devices and functions as a Bluetooth speaker Customer Support: Available via Amazon or email for troubleshooting and feedback |
Unboxing Experience
The mini-projector has a compact design that makes it highly portable and user-friendly. While it appears slightly larger than expected from promotional images, this does not detract from its overall appeal. The build feels solid, and the inclusion of a handle for easy transport is a thoughtful touch. The aesthetic is simple yet functional, allowing it to fit seamlessly into any room, whether it’s set up in a bedroom for casual viewing or taken outdoors for a movie night.Lisowod Mini Projector:
I was immediately impressed by the sleek and compact design of the projector. Its lightweight build makes it incredibly easy to transport, whether I’m taking it outside for movie nights or moving it around my home. Despite its small size, it feels robust enough for regular use, and the aesthetic blends seamlessly into any room. The overall look is modern and unobtrusive, making it a stylish addition to my home entertainment setup.ONOAYO AY2Pro Projector:
The Onoayo AY2Pro Mini Projector immediately impresses with its sleek and modern design. Holding the projector feels substantial, thanks to premium materials that enhance its aesthetic appeal. The stylish outer shell combines durable plastics and soft fabric, giving it a high-quality look and feel that belies its budget-friendly price. Its compact size makes it portable enough to fit into tight spaces or carry around easily, and the inclusion of a carrying strap adds to its practicality. Overall, this projector not only serves its function well but does so with a design that is visually pleasing and thoughtfully constructed.Display
Screen Size | 35 Inches - 210 Inches | 40 Inches - 300 Inches | - |
Throw Distance | 3.6 Feet - 23.6 | 3.28 Feet - 19.7 Feet | 3.28 Feet - 19.68 Feet |
Contrast Ratio | 10000:1 Pixels | 20000:1 Pixels | High |
Maximum Resolution | 1920x1080 Pixels | 1920 x 1080 Pixels | 1920*1080 Pixels |
Native Resolution | 1920 x 1080 | 1920 x 1080 | 1920 x 1080 |
Brightness | 9500 Lumen | 20000 Lumen | 20000 Lumen |
Display Type | LCD | LCD | LED |
Picture Enhancement | Advanced LED and uniform illumination technology | Quantum HDR | - |
Viewing Experience
The viewing experience offered by this mini-projector is truly impressive, especially considering its price point. The image quality is sharp and bright, even in less-than-ideal lighting conditions. It delivers vibrant colors and a large projection size, making it an excellent alternative to traditional TVs. While the built-in speakers provide decent sound, I found that using external speakers enhances the overall experience. Adjusting the focus and keystone settings is also relatively easy, although I did encounter some focus issues that required careful adjustments to achieve the best clarity.Lisowod Mini Projector:
The viewing experience has been nothing short of transformative. The projector delivers stunning 1080p resolution with vibrant colors and deep blacks that truly bring movies to life, even in well-lit rooms. The image quality remains crisp and clear, whether I’m watching films, playing video games, or streaming shows. The built-in speakers provide decent sound, but pairing the projector with an external sound system elevates the entire experience. I often find myself feeling like I'm in a movie theater, all from the comfort of my couch or bed.ONOAYO AY2Pro Projector:
The viewing experience with the Onoayo projector is outstanding, especially considering its price point. The image quality remains impressive, even in a shaded room or with some ambient light, delivering vivid colors and clear details. The auto keystone adjustment works well, providing a uniformly focused image from center to edges—something I found rare in budget projectors. Whether I was watching movies or playing video games, the clarity and brightness of the projected image were commendable, making it a delightful choice for family movie nights or casual gatherings with friends.Features
Other Features | Mini and Portable, Supports Table, Tripod, Ceiling Installation, Compatible with TV Stick, Phone, PS4/5, Laptop, PC, Hi-Fi Stereo Speakers,Zoom 100%-50%, Equipped with Cooling system, Low Noise | 360 Ajustable Stand, Electric Focus & Auto Keystone, Portable Mini Size, Built In WiFi, Built In Bluetooth, Built In Speaker, 24/7 Customer Support: [email protected] | Adjustable Carrying Strap Giving, Friendly Package, Mini Size 4.56*5.31*4.64inches, 2.42lb, Electric focus & Auto Keystone, Wireless screen mirror, [email protected] |
Video Encoding | H.264, H.265 | - | AVC |
Lamp Wattage | 50 Watts | 50 Watts | 10 Watts |
LightSource Life | 55000 Hours | 29.99 Years | 120000 Hours |
Controller Type | Remote Control, Button Control | Remote Control Button Control | Remote Control, Button Control |
Connectivity Technology | USB | Bluetooth, Wi-Fi, USB, HDMI, 3.5mm Jack | Bluetooth/WiFi/HDMI/USB/3.5mm audi jack |
Compatible Devices | Laptop, USB Drive, Tablet, X-Box, Smartphone | Laptop, Gaming Console, Tablet, Smartphone, Speaker | Laptop, Gaming Console, Tablet, Smartphone, Speaker |
Wattage | 50 watts | 48 watts | 60 watts |
Mount Type | Tripod Mount | Tabletop Mount, Ceiling Mount, Table Mount, Tripod Monut, Wall Mount | Ceiling Mount/Tabletop Mount/Wall Mount/Ceiling Mount |
L x W x H | 6.69"L x 4.9"W x 2.64"H | 6.77"L x 5.65"W x 3.15"H | 5.31"L x 4.64"W x 4.56"H |
Setting up this projector was an incredibly straightforward process. It comes with all necessary accessories, including an HDMI cable, which made connecting my devices a breeze. The projector automatically detected my laptop upon connection, and I was able to start streaming content almost immediately. Although the lack of Bluetooth capabilities requires a wired connection for streaming devices like Roku, this was easily managed with a Velcro strip to secure the device on top of the projector. The overall setup experience was efficient and user-friendly, making it accessible even for those who are not technologically inclined.Lisowod Mini Projector:
Setting up the projector was an absolute breeze. The clear instructions and user-friendly remote made navigating through the menu straightforward. I appreciated the ease with which I could connect various devices, thanks to the multiple HDMI and USB ports, as well as the wireless streaming capabilities. The 360° rotation stand is particularly handy, allowing for easy adjustments whether I’m projecting onto a wall or the ceiling. Overall, the setup process was hassle-free, enabling me to dive straight into my viewing experience.ONOAYO AY2Pro Projector:
Setting up the Onoayo projector is a breeze, taking mere minutes to connect to Wi-Fi and start streaming content from my iPhone. The user-friendly interface and straightforward instructions make it accessible for everyone, even those who may not be tech-savvy. I was particularly impressed with the auto focus feature, which adjusts quickly and accurately, ensuring a crisp image without needing manual adjustments. The inclusion of ports for HDMI and Bluetooth improves its versatility, allowing for various connection options for streaming devices or speakers. However, a minor drawback is the power cable, which does not fit securely and can disconnect easily.Conclusion
Pros:• Excellent picture quality for the price
• Easy setup and connection with devices
• Portable and lightweight design
• Comes with necessary accessories, including an HDMI cable
• Good customer service experience
• Lacks Bluetooth connectivity
• Requires additional adapters for certain devices
• Focus can be uneven, especially when using keystone adjustments
• Built-in speakers may not suffice for larger spaces
Overall, this mini-projector is an exceptional value for anyone looking to explore projection technology without breaking the bank. It is versatile enough for both indoor and outdoor use, making it perfect for movie nights, presentations, or even as a fun alternative to a standard TV. While there are some minor drawbacks, such as the need for external speakers and potential focus issues, the positive aspects far outweigh the negatives. I would highly recommend this projector to anyone seeking a portable and efficient solution for their viewing needs.
Pros:• Impressive picture quality with vibrant colors and deep contrasts
• Easy to set up and transport
• Smart connectivity options (HDMI, USB, Wi-Fi, Bluetooth)
• Compact and stylish design
• Versatile projection options with 360° rotation stand
• Not the brightest projector available
• Built-in speakers, while decent, could be improved for a more cinematic experience
My overall impression of the projector is overwhelmingly positive. It has exceeded my expectations in terms of performance, portability, and image quality. At its affordable price point, this projector offers exceptional value and has truly enhanced my home entertainment experience. Whether for family movie nights, outdoor gatherings, or even business presentations, I find this projector to be an invaluable addition to my tech collection. I highly recommend it to anyone looking to upgrade their viewing experience without breaking the bank.
Pros:- Very compact, can fit in/on places most other projectors won't
- Reasonably bright, appropriate for the price point
- Good contrast ratio, enhancing overall picture quality
- Clear and uniform image
- Built-in speakers are better than expected
- Quiet fan operation
- Responsive customer support
- Bluetooth output has noticeable lag
- Loose power cable connection
- Coarse digital keystone adjustment
- Always defaults to the menu screen on startup
- No lens cap provided despite description
In conclusion, the Onoayo AY2Pro Mini Projector has far exceeded my expectations as a portable and budget-friendly option for home entertainment. Its combination of a sleek design, impressive image quality, and user-friendly setup makes it a standout choice in the crowded market of entry-level projectors. While it does have a few quirks, such as the loose power cable and some Bluetooth limitations, these are minor inconveniences compared to the overall performance and value it provides. With a solid warranty backing it and responsive customer service, I would confidently recommend this projector to anyone in search of a reliable and enjoyable viewing experience.
