Vizio vs TOSHIBA vs TCL: What’s the Difference Among These Popular 32-Inch Smart TVs?
TCL 32-Inch S3 TV​
TOSHIBA 32-Inch V35 TV​
VIZIO 32-Inch TV​
$138​
$109.99​
$134​
Model Year​
2023​
2021​
2024​
Specific Uses​
Home Viewing​
home entertainment, gaming, streaming content, indoor use​
Chromecast Built-in: Compatible with numerous streaming apps.
Voice Control: Works with Amazon Alexa and Google Assistant.
Resolution: 1080P Full HD.
Design: FullView Metal Bezel-less design.
HDMI Inputs: 2 inputs (one with ARC).
HDR Support: HDR10 and HLG formats.
Home Screen Integration: Live TV, streaming channels, favorite apps
Voice Control: Included Voice Remote with Alexa
Search Capability: Voice search for integrated apps and channels
Entertainment Access: Over 1 million movies and TV episodes, tens of thousands of channels and apps
Audio Technology: DTS Virtual:X for immersive audio experience
Apple AirPlay Support: Share content from Apple devices to TV
VIZIO Account: Required for Smart TV functionality and product updates
Display Resolution: Full HD
Backlight Technology: Full Array LED Backlight
Color Technology: Active Pixel Tuning
HDR Support: HDR10
Auto Low Latency Mode: Automatically enabled for console/PC detection
Built-in Apps: VIZIO Home with access to favorite apps and WatchFree+
Free Content: Hundreds of free channels and thousands of On Demand titles
Design: Modern 3-sided VIZIO ThinFrame
Unboxing Experience​
TCL 32-Inch S3 TV:​
The TCL TV features a sleek design with a lightweight build, making it easy to mount on the wall. The small bezel around the screen enhances its modern aesthetic, while the overall appearance is pleasing for a TV in this price range. However, there are some complaints regarding the bright blue light on the front, which can be distracting in dark rooms.
TOSHIBA 32-Inch V35 TV:​
The Toshiba LED Smart TV boasts a sleek and modern design that fits well in various spaces, particularly in small rooms or entertainment centers. The lightweight structure makes it easy to handle, and the overall aesthetic is pleasing, appealing to those who prefer a compact and stylish look without overwhelming their decor.
VIZIO 32-Inch TV:​
The Vizio Smart TV presents a sleek and modern design, fitting well in various settings, including older entertainment centers. Its lightweight construction makes it easy to handle, although there's a consensus that it feels somewhat flimsy, especially the legs. Measuring 40 inches diagonally, it fits snugly into spaces designed for similar-sized TVs, making it a practical choice for consumers with limited space.
Side-by-Side Comparison​
System​
TCL 32-Inch S3 TV​
VIZIO 32-Inch TV​
Operating System​
Google TV​
FireOS​
Android​
Internet Applications​
Netflix​
Netflix, Amazon Instant Video, YouTube, Browser​
Netflix, HBO Max, Disney Plus, Prime Video, Hulu, Apple TV​
Bluetooth​
Bluetooth​
Bluetooth​
Voice Control​
Voice Control, Touch Control​
Voice Control​
Voice​
Voice​
App, Voice​
TCL 32-Inch S3 TV:​
Setting up the TCL TV is generally straightforward, with options for both using the included legs/stand or mounting it to a VESA. The Google TV interface is user-friendly and snappy compared to other systems like Roku. However, some users found the pre-installed apps to be non-removable, which detracts from the overall experience. Those familiar with Google products may find the setup process particularly seamless.
Setting up the TV was a straightforward process, enhanced by features like QR code scanning via a smartphone for quick WiFi and account connections. The Fire TV interface is familiar and user-friendly, allowing for easy navigation to apps and settings. The initial setup was completed swiftly, with the most time-consuming part being the unboxing due to the excellent packaging.
VIZIO 32-Inch TV:​
Setting up the Vizio Smart TV is often described as incredibly straightforward and hassle-free. Users can easily select their language, connect to Wi-Fi, and choose their input source without complications. The option to use a smartphone app for setup further simplifies the process, though some have encountered issues needing additional devices for activation. The instruction clarity is generally appreciated, although a few users mentioned the setup could be improved with minor adjustments to the initial prompts.
TCL 32-Inch S3 TV​
VIZIO 32-Inch TV​
Aspect Ratio​
16:9​
16:9​
16:9​
Display Technology​
LED​
LED​
LED​
Screen Finish​
Flat​
Flat​
Has Color Screen​
Yes​
Yes​
Yes​
Resolution​
1080p​
1080p​
1080p​
Refresh Rate​
60 Hz​
60​
60 Hz​
Response Time​
9.5 Milliseconds​
HDR Format​
HDR10​
HDR10​
Backlight Technology​
LED​
1080P, HDR 10​
Full Array LED Backlight, Active Pixel Tuning​
Motion Enhancement​
Ultimate Motion (Motion Rate 120)​
TCL 32-Inch S3 TV:​
The picture quality of this 1080p TV is often described as outstanding for its size, with crisp visuals that rival 4K TVs in larger formats. Users appreciate the color settings and the ability to use Google Photos as a screensaver. While the UI can be a bit slow, the overall clarity and detail in the picture quality receive high praise.
The picture quality is commendable, with bright and sharp visuals at 1080p resolution, which some sources debated. Users have found the factory settings to provide an enjoyable viewing experience, although there are limitations regarding aspect ratio adjustments for older content. Overall, the TV performs well for casual viewing, particularly in smaller spaces.
VIZIO 32-Inch TV:​
The picture quality is frequently praised, providing vibrant colors and sharp images at 1080p resolution. Users have noted that the TV self-adjusts to enhance the viewing experience, making it suitable for various content types like movies and gaming. However, some have highlighted that the viewing angle can be less optimal from below, causing the image to appear darker, which may require adjustments to settings for the best experience.
Audio​
TCL 32-Inch S3 TV​
VIZIO 32-Inch TV​
Audio Channels​
2.0​
DTS Virtual:X​
Audio Output​
Surround​
Dolby Digital​
Audio Input​
HDMI
Bluetooth​
HDMI
Speaker Description​
8W (left) + 8W (right)​
2 speakers with DTS Virtual:X technology​
Dolby Digital/Dolby Digital+​
Surround Sound​
DTS Virtual:X​
DTS Virtual:X​
Audio Experience​
TCL 32-Inch S3 TV:​
The built-in speakers are considered adequate for casual viewing but could use improvement, as they tend to sound tinny and lack bass. While some users find the sound acceptable for their needs, others strongly recommend the use of external speakers or a soundbar for a better audio experience.
The sound quality is generally rated as good, with sufficient volume for most viewing situations. However, some users noted that the speakers may not be ideal for larger rooms and suggested the use of external sound systems for a better audio experience. Despite this, many found the sound adequate without needing to crank up the volume excessively.
VIZIO 32-Inch TV:​
While the TV offers decent sound quality for the price, many users recommend pairing it with a soundbar to enhance audio clarity, especially for dialogue. The built-in speakers have received mixed reviews; some find them acceptable, while others describe them as inadequate, prompting the need for external audio solutions. Users appreciate the Bluetooth audio compatibility, allowing for a more personalized listening experience.
TCL 32-Inch S3 TV​
VIZIO 32-Inch TV​
HEVC (H.265)​
H.264, H.265 (HEVC)​
HEVC (H.265) or VP9​
Screen Mirroring​
Google Cast​
AirPlay 2​
Water Resistance​
Not Water Resistant​
Speaker, Smartphone, Tablet, Laptop​
Headphone​
Tuner Type​
ATSC​
ATSC​
ATSC​
Voltage​
1.1E+2 Volts (AC)​
Line Voltage​
Unknown​
110 VAC 60 Hz​
110 VAC 60 Hz​
Flat​
Flat​
Built-in apps with VIZIO Home, Apple AirPlay, Voice Assistance Integration, ThinFrame Design, Hundreds of free channels, Google Chromecast, Bluetooth Headphone compatibility​
D x W x H​
3.1"D x 28.1"W x 16.6"H​
3.3"D x 28.6"W x 16.9"H​
8.72"D x 28.31"W x 18.89"H​
Motion & Gaming​
TCL 32-Inch S3 TV:​
While there aren't many specific comments on gaming, the smooth interface and good picture quality suggest that the TCL TV can handle casual gaming well. Users have not reported any significant issues while using it for gaming purposes, though the sound quality may not be ideal for immersive experiences.
While the TV serves well for regular viewing, some users experienced occasional processor glitches when switching inputs or accessing settings for gaming systems. However, the overall functionality for casual gaming remains positive, especially considering the price point and features offered.
VIZIO 32-Inch TV:​
The TV supports gaming capabilities, with users noting that switching inputs to gaming consoles is seamless. The picture settings can be adjusted specifically for gaming, which enhances the overall experience. However, some users have reported delays when changing channels or navigating menus, which might be a potential drawback for avid gamers looking for instantaneous reactions.
Connectivity​
TCL 32-Inch S3 TV​
VIZIO 32-Inch TV​
Wi-Fi, HDMI
Bluetooth, Wi-Fi​
Wi-Fi​
Bluetooth Version​
5.0​
4.0​
5.0​
Wireless Technology​
Wi-Fi​
Bluetooth, Wi-Fi​
Bluetooth, Wi-Fi​
Usb Ports​
1​
1​
1​
HDMI Ports​
2​
3​
2​
Connector Type​
HDMI
HDMI
Signal Format​
ATSC, NTSC, Clear QAM​
HDMI, ATSC​
HDMI
Compatibility​
TCL 32-Inch S3 TV:​
The Google TV interface offers various smart features and personalized recommendations based on user habits, which is a plus. However, some users found the remote control to be cumbersome, with a lengthy design and an awkward button layout. The lack of physical buttons other than the power button means complete reliance on the remote, which could be troublesome if lost or malfunctioning.
The Toshiba Fire TV comes equipped with various smart features, including access to popular streaming services and compatibility with Alexa for voice commands. Users appreciate the seamless integration of apps and the ability to save personal photos as wallpaper. However, some noted difficulties in side-loading apps and limitations with certain cable service applications.
VIZIO 32-Inch TV:​
The Vizio Smart TV comes packed with various features, including a wide range of pre-installed streaming apps and free content options. Users have also highlighted the versatility of the TV, with multiple input options and customizable picture settings. However, the lack of an additional HDMI port was noted as a limitation for those wanting to connect multiple devices.
TCL 32-Inch S3 TV:​
• Excellent picture quality for the price
• Lightweight and easy to mount
• User-friendly Google TV interface
• Good internet connectivity
• Sound quality is tinny and lacks bass
• Bright blue light can be distracting
• Remote design is awkward and has reliability issues
• Non-removable pre-installed apps
Overall, the TCL TV is a solid choice for those seeking a budget-friendly option without compromising on picture quality. It is especially suited for casual viewing, streaming, and smaller spaces. However, potential buyers should be aware of its sound limitations and the quirks of the remote control. Despite some drawbacks, many users express satisfaction with their purchase, highlighting the value it offers for the price.
• Excellent price point, especially during sales.
• Easy setup and connectivity.
• Good picture quality for the size and price.
• Lightweight and compact design.
• Access to multiple streaming apps and Alexa integration.
• Limited sound quality for larger rooms; external speakers recommended.
• Occasional processor glitches and slow response times.
• Aspect ratio adjustments are not available for older shows.
• Some users experienced issues with Bluetooth connectivity.
Overall, the Toshiba LED Smart TV is a fantastic value for its price, particularly for casual viewers seeking a reliable and functional television for smaller spaces. While there are some minor drawbacks, such as sound quality and occasional glitches, the positive aspects far outweigh the negatives. Users highly recommend this model for its performance, ease of setup, and affordability, making it a solid choice for those looking for a budget-friendly smart TV option.
VIZIO 32-Inch TV:​
• Vibrant picture quality with good color accuracy
• Lightweight and fits well in small spaces
• Good range of features and pre-installed apps
• Bluetooth audio capability
• Built-in speakers may require a soundbar for optimal audio
• Occasional navigation lag and slow app loading times
• Limited HDMI inputs for connecting multiple devices
• Viewing angle issues may affect picture quality from below
• Some apps, like Max, may not function properly on the TV
Overall, the Vizio Smart TV delivers excellent value for its price, especially for consumers transitioning to smart TVs for the first time. Its easy setup, good picture quality, and range of features make it a strong contender in the budget TV market. However, potential buyers should be aware of its audio limitations and some interface quirks that could impact the user experience. Despite these minor drawbacks, many find it to be a reliable and enjoyable choice for home entertainment.
Gizmoitus
Got the TCL 32-Inch S3 TV, and I gotta say, it's decent but the volume is awful—like, I can barely hear it! On the bright side, the picture quality is super clear. Oh, and the pause button on the remote? Yeah, it doesn't work. Maybe I just need a new remote or something!
Elfman72
Got my father-in-law the TOSHIBA 32-Inch V35 TV and he loves it! Now he can watch TV and stream stuff, and he's totally into it. Great buy!
The Toshiba 32-Inch V35 TV is awesome! It's way better than a lot of other brands. Toshiba and Samsung are super reliable, while brands like Insignia can give you issues after a while.
ZacRedact
VIZIO 32-Inch TV is a gem! I ditched cable, kept my internet, and switched to streaming—big money saver! This TV fits my space just right, and the picture and sound are top-notch. This is my second one, so that says it all. Plus, the price is awesome!
