VIZIO SmartCast TVs have built-in Chromecast technology. If you are unable to cast an application to the TV, try the following.
For more information, refer to Vizio TV Forum.
- Check to make sure the app you are using has forced conversion.
- For specific information on whether your device can cast, you may want to check the specifications on the manufacturer's website.
- Reboot both devices.
- Turn off your smartphone, tablet, computer, or any of your projection devices. Then turn the power back on.
- To reboot your TV, press the Menu button on your VIZIO remote control and select System > Reset and Management > Soft Reboot. Your TV will turn off and back on.
- Check to make sure both devices (TV and phone/tablet/PC or other projection device) are on the same network.
- Just unplug the power cord from the router. Wait 10-15 seconds, then reconnect the power cord.
- Wait as your router reboots, then try to cast again.
