Vizio M6 Series Quantum 2022 Review: A Solid Choice for HDR Gaming?
mufcroberts
First Impressions​
The Vizio MQ6 looks a lot like theVizio M6 Series Quantum 2021. It's a simple-looking TV with an all-black body, mainly made of plastic. It looks surprisingly good for a budget model, with thin bezels and a modern design that looks good in most rooms.
The back of the TV is a mix of plastic and metal components. Because the inputs are placed towards the center of the TV, theyre hard to reach, especially if you have it wall-mounted. Unfortunately, there isnt anything forcable management.
The Vizio MQ6 has decent build quality. It feels good for a budget-friendly TV, and even if its materials arent premium, its well-put together, and there arent any noticeable issues. Theres a bit of flex on the back panel, but thats normal and isnt an issue until you press on it.
Vizio M6 Series Quantum 2022​
$648.51​
Model Year​
2022​
Power Cable, Voice Remote, Stand​
Highlight
Display Size: 65 inches
Display Type: QLED
Resolution: 4K (over 8 million pixels)
Color Technology: Quantum Color (over a billion hues)
HDR Support: Dolby Vision Bright Mode, HDR10/+, HLG
Processor: IQ Active Processor
Features: Intelligent 4K upscaling, Full Array Backlight
System​
Operating System​
SmartCast OS​
Internet Applications​
Apple TV+, Crackle, Discovery+, Disney+, Fandango, fuboTV, HBO Max, Hulu, iHeartRadio, Netflix, Pandora, Paramount+, Peacock, Prime Video, Redbox, Sling TV, STARZ, TikTok, Tubi, Vudu, XUMO, YouTube, YouTube TV​
Voice Control​
Voice Control​
App, Remote, Voice​
Overall Impression: The Vizio SmartCast platform offers a unique experience with its web-based app system, making it easy to navigate despite a slower interface and occasional bugs. Users may find the initial setup frustrating due to the need for a reset, but once operational, the selection of available apps is substantial. While the absence of a traditional app store limits options to pre-installed applications, the ability to cast content from mobile devices adds versatility. Ads are present in the interface, but their inconsistency may not be overly intrusive. Overall, the product presents a mixed bag of functionality and ease of use.
Aspect Ratio​
16:9​
Display Technology​
QLED​
Screen Finish​
Flat​
Has Color Screen​
Yes​
Resolution​
4K UHD​
Refresh Rate​
60 Hz​
Viewing Angle​
170 Degrees​
HDR Format​
Dolby Vision, HDR10+​
Backlight Configuration​
Direct-Lit​
Active HDR​
Motion Enhancement​
Dynamic Motion Rate 120​
Viewing Experience
The Vizio MQ6 offers an impressive native contrast ratio, delivering deep and uniform blacks in dim scenes. However, its lack of a local dimming feature results in washed-out blacks in more complex scenes, alongside issues like backlight bleed and a dirty screen effect that can be distracting during content with large areas of uniform color. While the quantum dot technology provides a broad color gamut, tone mapping inaccuracies hinder HDR performance, leading to less accurate color representation. The TV's narrow viewing angle and low peak brightness limit its effectiveness in bright environments, causing color degradation and glare challenges. Additionally, the BGR sub-pixel structure may negatively impact text clarity for PC use, compounded by dithering issues that affect image sharpness during 4K upscaling. Overall, the Vizio MQ6 presents a mixed performance, excelling in deep blacks but facing challenges in color accuracy, viewing angles, and uniformity.
Audio​
Surround Sound​
DTS Virtual:X​
Audio Output​
Digital​
Audio Input​
HDMI​
Speaker Output Power​
18 Watts​
Audio Experience
Overall, this TV delivers a decent audio performance, particularly excelling in dialogue clarity and volume. However, it lacks sufficient bass response, which is common for TVs. While it manages distortion reasonably well at moderate listening levels, it becomes more noticeable at maximum volume.
Television​
Tuner Type​
ATSC​
D x W x H​
11.8"D x 56.84"W x 35.38"H​
Mount Standard​
400 x 200 mm​
Voltage​
110 Volts​
Hundreds of Free Channels with WatchFree+, Quantum Color, Dolby Vision HDR, IQ Active Display Processor, Spatial Scaling Engine​
Motion Smoothing
The overall impression of this TV reflects significant limitations in its processing capabilities, particularly in handling low-quality content, which results in noticeable macro-blocking and pixelization. While it exhibits a decent response time for motion, there are issues with blur trails during fast scenes and slow response times during dark transitions, leading to black smearing. The use of pulse width modulation for dimming the backlight introduces flicker at lower brightness levels, making it advisable to operate at maximum backlight to mitigate this issue. However, this high setting can also lead to image duplication. Additionally, the absence of motion interpolation limits its ability to enhance lower-frame-rate content effectively. Overall, this TV may fall short in delivering a consistently high-quality viewing experience.
Connectivity​
USB, Ethernet, HDMI​
Screen Mirroring​
Miracast​
Wireless Technology​
Wi-Fi​
Usb Ports​
1​
USB2.0 Ports​
4​
Audio Out Ports​
1​
HDMI Ports​
3​
Connector Type​
USB, HDMI​
Signal Format​
Digital​
Sharing Direction​
Mobile to TV​
Hardware Interface​
Connecting TV
The Vizio M6 Series presents itself as a solid choice for gamers and casual users alike, thanks to its low input lag in Game Mode, which facilitates a responsive experience. However, it falls short in fully leveraging next-gen gaming consoles, such as the PS5, due to the limitation of HDMI inputs to HDMI 2.0 bandwidth, capping refresh rates at 60Hz. On the positive side, it offers support for advanced audio formats like Dolby Atmos and DTS:X through eARC, allowing for high-quality sound transmission to compatible receivers. Additionally, the inclusion of Wi-Fi 6E enhances its capabilities for wireless streaming. Overall, while the Vizio M6 Series has some commendable features, its limitations in HDMI bandwidth may hinder its performance for those looking for the latest gaming experiences.
User Feedback​
Pros
• Great picture quality when functioning
• Respected brand in the market
• Good initial performance with no major issues for a significant period
• Appealing design and ergonomics
Cons
• Screen glitches and freezing issues reported
• Blue screen of death experienced after a relatively short timeframe
• Short lifespan leading to failures after warranty expiration
• High price point with concerns about reliability
Overall Impression
The Vizio TV offers an initially appealing experience with good picture quality and design. However, reliability issues such as screen glitches and premature failure significantly detract from its value, leading to disappointment after a short period of use. While it may have a good reputation, personal experiences suggest that potential buyers should consider alternative brands for better longevity and reliability.
