Barend Ray
Active member
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | ViewSonic PS502X | ViewSonic PA503HD |
Price | $499.99 | $559.99 |
Recommended Uses | Education, Business | Education, Home Cinema, Business |
Highlight | Brightness: 4000 Lumens Resolution: XGA Throw Ratio: 0.62 Projection Size: 100 inches from 4 feet (1.24 meters) Lamp Life: Up to 12,000 hours in Eco mode Connectivity: HDMI, USB, VGA, compatible with media players, PCs, Macs, mobile devices Setup: Plug & play | Brightness: 4000 Lumens Resolution: 1080p FHD Optical Zoom: 1.1x Vertical Keystone Adjustment: 40 degrees Contrast Ratio: High native contrast (0.65" DMD chip) Lamp Life: Up to 15,000 hours (SuperEco Mode) Connectivity: HDMI, USB Type A (supports most media players, PCs, Macs, mobile devices) |
Screen Size | 60 Inches - 300 Inches | 30 Inches - 300 Inches |
Throw Distance | 2.4 Feet - 12.3 Feet | 1 Meters - 10 Meters |
Contrast Ratio | 15000:1 | 22000:1 |
Display Resolution | 1920 x 1080 Pixels | 1920 x 1200 Pixels |
Native Resolution | 1024 x 768 | 1920 x 1080 |
Brightness | 4000 Lumen | 4000 Lumen |
Display Type | DLP | LCD |
Picture Quality Enhancement | SuperColor Technology | ViewSonic SuperColor |
Video Encoding | - | - |
Lamp Wattage | 240 Watts | 240 Watts |
Light Source Life | 4000 Hours | 4000 Hours |
Controller Type | Remote Control | Remote Control, Button Control |
Mount Type | Ceiling Mount | Ceiling Mount |
Noteworthy Features | Short Throw | High brightness, High native contrast ratio, Large Screen size, Easy multimedia access |
Connectivity
Connectivity Technology | USB, HDMI, 3.5mm Jack | USB, HDMI, 3.5mm Jack |
Hardware Connectivity | HDMI, USB 2.0 Type A, 3.5mm Audio | USB 2.0 Type A, HDMI, 3.5mm Audio |
Compatible Devices | Laptop, Gaming Console, Television, Tablet, Smartphone | Laptop, Television, Speaker |
Measurements
Dimensions L x W x H | 9.2"L x 12.2"W x 4.5"H | 13.3"L x 12.2"W x 4.5"H |
Item Weight | 9 Pounds | 6 Pounds |
Product | PROS AND CONS |
ViewSonic PS502X | Pros • Affordable alternative to leading golf simulator projectors • Good brightness for the price • Durable and travel-friendly design • Short throw distance with easy keystone and size adjustments • Versatile usage for various applications, including concerts and home decorations Cons • Menu settings can be confusing initially • Freezing issues may arise, potentially linked to older devices • Some users experienced a malfunction (smoke and damage) • Requires a considerable distance for short throw projection Overall Impression This projector offers great value for money, especially for niche applications like golf simulators and concerts. While it has some minor quirks and potential reliability concerns, its durability and versatility make it a solid choice for budget-conscious consumers looking for a functional and adaptable projector. |
ViewSonic PA503HD | Pros: • Brightness: The View Sonic PA503S is significantly brighter than competitors, allowing for earlier movie starts. • Image Quality: Provides clear, sharp images with no softness at the edges, comparable to a movie theater experience. • Ease of Focus: Easy to adjust focus to perfection without complications. • Audio Compatibility: Successfully supports audio from streaming services like Netflix. • Build Quality: Overall superior construction and reliability compared to the other tested projectors. Cons: • Longer Throw Distance: Requires a longer projection distance (19 feet) which may not suit all setups. • Price: At $300, it's more expensive than other tested projectors, which could be a consideration for budget-conscious consumers. Overall Impression: The View Sonic PA503S stands out as a top choice for outdoor movie nights, delivering superior brightness, image quality, and build quality compared to other budget projectors. While it comes at a higher price and demands a longer throw distance, its performance justifies the investment for a better viewing experience. |
