ViewSonic PS502W Projector Review: A Full-Feature WXGA Short Throw Solution for Your Space?
First Impressions​
Upon first glance, this projector impresses with its compact design and lightweight build, making it suitable for various settings, from home use to events like wedding receptions. It’s small enough to be portable, and the aesthetic is unobtrusive, allowing it to blend seamlessly into any environment. The overall appearance is functional, and its short throw capabilities hint at its versatility, enabling a large display without the need for extensive space.
ViewSonic PS502W Projector​
$549.99​
Education, Home Cinema​
User Manual, Power Cord, projector, Remote​
Highlight
VERSATILE PROJECTOR: High brighness 4000 Lumens WXGA projector with short throw lens and advanced visual features
EASY SETUP: 0.52 throw ratio, and vertical keystone adjustment
LONG LAMP LIFE: SuperEco Mode allows the lamp to shine bright for up to 12,000 hours
AMAZING COLOR ACCURACY: A 6 segment color wheel and dynamic lamp control capabilities provide vivid colors
FLEXIBLE CONNECTIVITY: Supports most media players, PCs, Macs, and mobile devices with inputs such as Dual HDMI, and USB Type A port
60 Inches - 300 Inches​
0.75 Meters - 3.76 Meters​
15000:1​
1280x800 Pixels​
1280 x 800​
4000 Lumen​
DLP​
Viewing Experience
The viewing experience is quite satisfying, especially in darker environments where the picture quality shines. The clarity and focus are impressive, and the brightness holds up in rooms with ambient lighting, albeit it struggles in direct sunlight. The projector offers a wide range of inputs, allowing for versatility in connecting to different video sources. While I initially found it great for casual use, I noticed limitations for gaming, particularly regarding the height and positioning of the projector, which affects image quality if not aligned correctly.
4000 Hours​
240 Watts​
295 watts​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
VGA, HDMI, USB 2.0 Type A, 3.5mm Audio​
Smartphone​
Short Throw​
12.2"L x 9.2"W x 4.5"H​
Setting up the projector took some time, particularly with configuring the language settings, but once I navigated that hurdle, the process of mapping out our environment and incorporating decorations was straightforward. The projector works well in smaller spaces, projecting a 120-inch image from just 5 feet away. However, the menu system can be somewhat complicated, making adjustments a bit cumbersome without the remote control. Despite these challenges, once set up, it performs admirably for various uses, from family movie nights to gaming.
User Feedback​
• Clear and bright image quality in controlled lighting
• Compact and lightweight, making it portable
• Short throw distance allows for large displays in small spaces
• Variety of input options for different video sources
• Difficult menu navigation without remote
• Noisy fan operation can be distracting
• Performance diminishes in direct sunlight
• Issues with bulb longevity and reliability
Overall, I consider this projector a decent value for its price, particularly for home use, presentations, and lectures. While it may not be the best choice for gaming, it does deliver good color and graphics when paired with a suitable screen or wall. However, some reliability concerns, particularly regarding bulb lifespan and performance inconsistencies, leave me with reservations. Despite its shortcomings, I still appreciate the projector for its versatility and quality, and I believe it can serve various needs effectively, provided one is aware of its limitations.
PlayStationPepe
This projector is awesome! I used it at a wedding, and now it's my gaming setup in the living room. It throws a huge 120-inch screen from just 5 feet away—super clear and bright!
