- 1 First Impressions
- 2 Introduce
- 3 Display
- 4 Features
- 5 User Feedback
First Impressions
The Viewsonic PA700W has a sleek and modern design that fits well in various settings, especially when ceiling-mounted in an auditorium. While it feels lightweight, almost to the point of being cheap, its overall appearance is professional and unobtrusive. The projector features a straightforward layout with accessible ports and controls, making it visually appealing without being overly complicated.Introduce
Parameter | ViewSonic PA700W Projector |
Reference Price | $429.99 |
Recommended Uses | Education, Business |
Built-In Media | Projector, Remote Control, Power Cable, Quick Start Guide |
Highlight | VERSATILE PROJECTOR: High brightness 4500 Lumens WXGA (1280x800p) projector with advanced visual features EASY SETUP: 1.1x optical zoom, and 40-degree vertical keystone LONG LAMP LIFE: SuperEco Mode allows the lamp to shine bright for up to 12,000 hours FLEXIBLE CONNECTIVITY: Supports most media players, PCs, Macs, and mobile devices with inputs such as dual HDMI, VGA, and USB inputs |
Throw Distance | 1.18 Meters - 13.17 Meters |
Contrast Ratio | 22000:1 |
Maximum Resolution | 1280 x 800 Pixels |
Brightness | 4500 Lumen |
Display Type | DLP |
Viewing Experience | Utilizing the projector for a conference, I was impressed by its brightness, which allowed clear presentations even in well-lit conditions without needing to dim the room. The projected image size on an 180-inch screen was satisfactory, but I was hoping for a sharper quality throw given my distance from the screen. Unfortunately, it fell short of the expected 200-inch image size at 19 feet, instead delivering closer to 140 inches. This discrepancy was a letdown, as I had anticipated a larger and more impressive display. |
LightSource Life | 4000 Hours |
Lamp Wattage | 300 Watts |
Wattage | 300 watts |
Connectivity Technology | USB, Ethernet, HDMI, 3.5mm Jack |
Hardware Connectivity | VGA, Ethernet, HDMI, USB 2.0 Type A, 3.5mm Audio |
Compatible Devices | Laptop, Tablet, Smartphone |
Other Features | UHP |
L x W x H | 9.2"L x 12.2"W x 4.5"H |
System Experience | Setting up the Viewsonic PA700W is straightforward, with multiple mounting options and easy-to-navigate settings for keystone correction and white balance adjustments. I found it particularly convenient for my needs as a rear projector, allowing for flexible positioning. However, I did encounter some compatibility issues with newer macOS versions, which limited my options unless I resorted to using an old VGA cable. Despite this hiccup, the projector offers a variety of input options, making it versatile for different devices. |
User Feedback
Pros:• Affordable pricing without sacrificing quality.
• Bright projection suitable for well-lit environments.
• User-friendly setup with versatile mounting options.
• Compatibility issues with newer macOS systems.
• Lightweight design can feel a bit flimsy.
• The actual image size did not meet expectations based on advertised specifications.
My experience with the Viewsonic PA700W was mixed. While it excels in brightness and affordability, and I appreciate Viewsonic's reputation for reliability, I was disappointed with the image size and some functionality limitations. The lightweight design is a double-edged sword, offering portability but feeling a bit cheap. For those looking for a budget-friendly projector for presentations in brighter settings, it remains a solid option, though potential buyers should conduct thorough research to ensure it meets their specific needs.
