Hardon Williams
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | ViewSonic PA503W | ViewSonic PA503HD |
Price | $399.99 | $559.99 |
Recommended Uses | Business | Education, Home Cinema, Business |
Highlight | Brightness: 4000 Lumens Resolution: WXGA Optical Zoom: 1.1x Keystone Adjustment: 40 degree vertical Input Latency: 16ms Lamp Life: Up to 15,000 hours (SuperEco Mode) Connectivity: HDMI, VGA, mini USB, compatible with media players, PCs, Macs, and mobile devices | Brightness: 4000 Lumens Resolution: 1080p FHD Optical Zoom: 1.1x Vertical Keystone Adjustment: 40 degrees Contrast Ratio: High native contrast Chip Type: 0.65" DMD Lamp Life: Up to 15,000 hours in SuperEco Mode Connectivity: HDMI, USB Type A, supports media players, PCs, Macs, mobile devices |
Screen Size | 30 Inches - 300 Inches | 30 Inches - 300 Inches |
Throw Distance | 3.28 Feet - 38.02 Feet | 1 Meters - 10 Meters |
Contrast Ratio | 22000:1 | 22000:1 |
Display Resolution | 800 Pixels | 1920 x 1200 Pixels |
Native Resolution | 1280 x 800 | 1920 x 1080 |
Brightness | 4000 Lumen | 4000 Lumen |
Display Type | DLP | LCD |
Picture Quality Enhancement | SuperColor | ViewSonic SuperColor |
Video Encoding | AVC | - |
Lamp Wattage | 200 Watts | 240 Watts |
Light Source Life | 5000 Hours | 4000 Hours |
Controller Type | Remote Control | Remote Control, Button Control |
Mount Type | Ceiling Mount | Ceiling Mount |
Noteworthy Features | Lightweight | High brightness, High native contrast ratio, Large Screen size, Easy multimedia access |
Connectivity
Connectivity Technology | VGA, USB, HDMI | USB, HDMI, 3.5mm Jack |
Hardware Connectivity | USB | HDMI, USB 2.0 Type A, 3.5mm Audio |
Compatible Devices | Personal Computer | Laptop, Television, Speaker |
Measurements
Dimensions L x W x H | 11.6"L x 8.6"W x 4.3"H | 13.3"L x 12.2"W x 4.5"H |
Item Weight | 2.2 Kilograms | 6 Pounds |
Product | PROS AND CONS |
ViewSonic PA503W | Pros • Clear and bright picture quality with accurate colors • Easy setup and mounting process • Quiet operation, making it suitable for home theater use • Flexible video input options, including compatibility with gaming consoles like the Wii • Keystone adjustment is user-friendly • Good build quality and included accessories (power cord, monitor cord, remote with batteries) • Excellent value for money Cons • Only one HDMI port available • Primarily marketed for business and education, which may deter some home users Overall Impression The ViewSonic PA503W projector is an excellent choice for anyone looking to enhance their home theater experience without overspending. With its impressive picture quality, quiet operation, and ease of setup, it stands out as a reliable option. Despite the limitation of a single HDMI port, its versatility and performance make it a recommended product for both casual movie watchers and gamers alike. |
ViewSonic PA503HD | Pros • Brightness: The ViewSonic PA503S is significantly brighter than competitors, allowing for earlier movie start times. • Image Quality: Clear and sharp image with no softness at the edges, providing a 'movie theater' experience. • Easy Setup: Focus adjustments are straightforward, making it user-friendly. • Audio Compatibility: Works with Netflix, eliminating audio issues encountered with other projectors. • Build Quality: Superior construction compared to lower-priced alternatives, enhancing durability and reliability. Cons • Longer Throw Distance: Requires a projection distance of 19 feet, which may not be suitable for all setups. • Price: At $300, it is more expensive than the other tested projectors, which could be a consideration for budget-conscious consumers. Overall Impression The ViewSonic PA503S stands out as a top choice for outdoor movie nights, offering remarkable brightness, excellent image quality, and overall better build quality compared to its cheaper counterparts. While it requires a longer throw distance and comes at a higher price, the benefits it provides in terms of performance and ease of use justify the investment for those seeking an enhanced viewing experience. |
