Serena Anderson
- 1 Introduce
2
Side-by-Side Comparison
- 2.1 Display
- 2.2 Features
- 2.3 Connectivity
- 2.4 Measurements
- 3 Conclusion
Parameter | ViewSonic PA503S | ViewSonic PA700W |
Price | $315.99 | $429.99 |
Recommended Uses | Business | Education, Business |
Highlight | Brightness: 4000 Lumens Resolution: SVGA Optical Zoom: 1.1x Keystone Correction: 40 degrees vertical Input Latency: 16ms Lamp Life: Up to 15,000 hours (SuperEco Mode) Connectivity: HDMI, VGA, mini USB, compatible with most media players, PCs, Macs, and mobile devices | Brightness: 4500 Lumens Resolution: WXGA (1280x800p) Zoom: 1.1x optical Keystone Correction: 40-degree vertical Lamp Life: Up to 12,000 hours in SuperEco Mode Connectivity: Dual HDMI, VGA, USB, compatible with most media players, PCs, Macs, and mobile devices |
Screen Size | 30 Inches - 300 Inches | 30 Inches - 300 Inches |
Throw Distance | 3.9 Feet - 43 Feet | 1.18 Meters - 13.17 Meters |
Contrast Ratio | 22000:1 | 22000:1 |
Display Resolution | 600 Pixels | 1280 x 800 Pixels |
Native Resolution | 800 x 600 | 1280 x 800 |
Brightness | 4000 Lumen | 4500 Lumen |
Display Type | DLP | DLP |
Lamp Wattage | 190 Watts | 300 Watts |
Light Source Life | 4500 Hours | 4000 Hours |
Controller Type | Remote Control | Button Control |
Mount Type | Floor Mount | Tabletop Mount |
Other Features | Lightweight | UHP |
Connectivity
Connectivity Technology | VGA, Mini USB Type B, HDMI | USB, Ethernet, HDMI, 3.5mm Jack |
Hardware Connectivity | USB, HDMI | VGA, Ethernet, HDMI, USB 2.0 Type A, 3.5mm Audio |
Compatible Devices | DVD players; Blu-ray players; Amazon FireTV; AppleTV; Google Chromecast; Mac Computers; Windows Computers | Laptop, Tablet, Smartphone |
Measurements
L x W x H | 11.6"L x 8.6"W x 4.3"H | 9.2"L x 12.2"W x 4.5"H |
Item Weight | 5.5 Pounds | 6 Pounds |
Product | PROS AND CONS |
ViewSonic PA503S | Pros • Bright picture quality, suitable for evening use • Simple setup process • Great performance for outdoor events, such as parties • Clean and sharp image output • Compatible with a range of accessories, enhancing versatility Cons • Limited maximum image size (65 to 70 inches) compared to other projectors • Some settings may not function as expected or lack clarity in the manual • Issues with audio connectivity (Bluetooth and Aux) reported by users • Potential inconsistencies in performance, as some units may have defects Overall Impression The projector demonstrates strong capabilities for outdoor use, providing a bright and clear image that can enhance events like birthday parties. However, it does have limitations in terms of maximum image size and may present challenges with audio connectivity and settings adjustments. Overall, it is a solid choice for casual use but may require further improvements in functionality and user guidance. |
ViewSonic PA700W | Pros: • Affordable price point • Very bright projection suitable for presentations in well-lit environments • Sharp optics and good image quality • Versatile mounting options (rightside up or upside down) • Keystone and white balance adjustments available • Lightweight design Cons: • Does not support USB video/photo input • Some users experienced reliability issues (e.g., "Warning Fan Locked" error) • May feel lightweight and less durable than other models • Projection size may not meet expectations at greater distances (actual image size may be smaller than advertised) Overall Impression: The Viewsonic PA700W projector offers excellent value for those seeking an affordable yet bright and capable device for presentations. While it has a range of features and good image quality, potential buyers should be aware of some reliability concerns and limitations regarding image size at longer distances. Overall, it's a solid choice for budget-conscious users looking to make impactful presentations. |
