ViewSonic PA503S vs PA503HD: What’s the Difference for Educational Use?
windstri85
ViewSonic PA503S​
ViewSonic PA503HD​
Price​
$149.99
$519.99
Education, Business​
Projection Size: 120 inches from 15-feet 8-inches, image size 30-300 inches
Brightness: 3600 lumens
Noise Level: 27dB
Warranty: 3-year limited parts and labor, 1-year lamp coverage
Lamp Life: Up to 15,000 hours in SuperEco mode
Connectivity: HDMI, VGA, supports various media players and devices
Usage: Ideal for education and small business
Included Accessories: PA503S SVGA Projector, Power Cable, VGA Cable, Remote Control
Brightness: 4000 Lumens
Resolution: 1080p FHD
Optical Zoom: 1.1x
Keystone Adjustment: 40 degree vertical
Contrast Ratio: High native contrast ratio via 0.65" DMD chip
Lamp Life: Up to 15,000 hours in SuperEco Mode
Connectivity: HDMI, USB Type A, compatible with media players, PCs, Macs, mobile devices
Side-by-Side Comparison​
ViewSonic PA503S​
ViewSonic PA503HD​
30 Inches - 300 Inches​
1 Meters - 10 Meters​
22000:1​
Display Resolution​
1920 x 1200​
1920 x 1200 Pixels​
1920 x 1200​
3600 lumen​
4000 Lumen​
ViewSonic SuperColor​
ViewSonic PA503S​
ViewSonic PA503HD​
240 Watts​
Light Source Life​
15000 Hours​
4000 Hours​
Mount Type​
Tabletop Mount​
Ceiling Mount​
HDMI Connectivity, Portable​
High brightness, High native contrast ratio, Large Screen size, Easy multimedia access​
Connectivity​
ViewSonic PA503S​
ViewSonic PA503HD​
VGA, HDMI​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
VGA​
USB 2.0 Type A, HDMI, 3.5mm Audio​
Television, Laptop, Smartphone, Tablet, Gaming Console​
Laptop, Television, Speaker​
Measurements​
ViewSonic PA503S​
ViewSonic PA503HD​
13.3"L x 12.2"W x 4.5"H​
Item Weight​
0.01 Ounces​
6 Pounds​
Product
PROS AND CONS​
ViewSonic PA503S​
• Exceptional brightness, suitable for well-lit rooms
• Clear image quality, even at longer throw distances
• Good value for the price, often rated highly in its category
• Versatile for various uses such as presentations, meetings, and performances
• Sufficient connectivity options, including HDMI and audio jack
• Weak built-in speakers; external speakers are recommended
• Potential issues with the remote control, especially for renewed products
• Some models may lack additional features like 1080p resolution or extra connection ports
This projector stands out for its brightness and clarity, making it an excellent choice for use in bright environments like classrooms and community centers. While the built-in audio may fall short, the projector’s overall performance and value make it a solid investment for anyone needing a reliable multimedia solution.
ViewSonic PA503HD​
• Bright enough for use in daylight conditions
• Excellent picture quality, even in well-lit environments
• Easy setup and installation
• Quick and simple lamp replacement
• Good value for a budget projector
• Compatible with various devices and formats
• Reliable performance for both streaming and gaming
• Limited to SVGA resolution, which may not meet all users' needs
• Original lamp life may require replacement after extensive use
• Requires additional components for optimal audio experience
This projector delivers impressive performance for its price, making it a solid choice for outdoor events, movie nights, and gaming sessions. Its brightness and clarity, paired with an easy setup and reliable functionality, make it a standout option for those seeking a budget-friendly solution. While it may not have the highest resolution, it still provides a satisfying viewing experience, especially for casual use.
