ViewSonic LS740HD vs LS740W: Which Laser Projector Should You Choose for Your Needs?
mufcroberts
ViewSonic LS740HD​
ViewSonic LS740W​
Price​
$978.13
$899.99
Brightness: 5000 Lumens
Resolution: 1080p
Lamp Life: Up to 30,000 hours
Optical Zoom: 1.3x
Projection Features: 360 degree projection, H/V keystone, 4 corner adjustment
Auto Power: Auto on/off capability
Remote Management: Compatible with Crestron, AMX, Extron, PJ Link, ATEN, vController
Connectivity: HDMI, USB Type A, supports various media players, PCs, Macs, and mobile devices​
Resolution: WXGA
Setup Features: 1.3x optical zoom, 360 degree projection, H/V keystone, 4 corner adjustment
Power Management: Auto power on/off
Remote Control: LAN control compatibility with Crestron, AMX, Extron, PJ Link, ATEN, ViewSonic’s vController​
Side-by-Side Comparison​
ViewSonic LS740HD​
ViewSonic LS740W​
30 Inches - 300 Inches​
1 Meters - 8 Meters​
0.77 Meters - 9.98 Meters​
3000000:1​
3000000:1​
Display Resolution​
1920x1080 Pixels​
1280 x 800 Pixels​
1280 x 800​
5000 Lumen​
5000 Lumen​
DLP​
Laser​
Picture Quality Enhancement​
ViewSonic LS740HD​
ViewSonic LS740W​
203 Watts​
203 Watts​
Light Source Life​
20000 Hours​
20000 Hours​
Mount Type​
Ceiling Mount​
Ceiling Mount​
Noteworthy Features​
Built-In Speaker, Eco-Friendly, ultra-large screen, Long-lasting​
eco-friendly, Digital Keystone Correction, Lightweight, high brightness, 3d-Ready​
Connectivity​
ViewSonic LS740HD​
ViewSonic LS740W​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
HDMI, USB 2.0 Type A, 3.5mm Audio​
Laptop, Gaming Console, Smartphone, Speaker​
Laptop, Television, Tablet, Speaker​
Measurements​
ViewSonic LS740HD​
ViewSonic LS740W​
Dimensions L x W x H​
11.3"L x 8.5"W x 5"H​
11.3"L x 5"W x 8.5"H​
Item Weight​
6.6 Pounds​
6.6 Pounds​
Product
PROS AND CONS​
ViewSonic LS740HD​
• Laser technology for longevity and brightness
• Quiet operation
• Minimal heat generation
• Extremely bright, suitable for daytime viewing
• Quick startup with almost no warmup time
• Easy manual focus adjustment
• Good zoom range with both manual and digital options
• Multiple preset modes: Living Room, Cinema, Presentation, etc.
• Sharp and clear picture quality
• No lens shift capability
• Designed to be stationary once set in place
• Power cord has a "Laptop" style connection with a proprietary power brick
• Manual zoom may not reduce image enough for some screens
This projector is an excellent entry-level option for anyone seeking a bright and versatile device for presentations or casual home viewing. Despite minor shortcomings such as the lack of lens shift and a proprietary power connection, its performance, ease of use, and value for money make it a strong contender in its price range.
ViewSonic LS740W​
Pros
• Bright and clear picture quality
• Good distance performance
• Fast operation with low noise
• Vibrant colors
• Suitable for various uses (streaming, band performances, church)
• Good value for the price
Cons
• May require closer positioning in some settings
Overall Impression
This projector from ViewSonic delivers impressive performance with bright visuals and clarity, making it a strong choice for streaming and live events. Its effective operation and quality make it a worthwhile investment, particularly for those looking for reliable performance at a reasonable price.
