ViewSonic LS740HD vs LS711HD: A Comparison of Features and 4 Corner Adjustment Capabilities
ViewSonic LS740HD​
ViewSonic LS711HD​
Price​
$978.13
$1299.99
Brightness: 5000 Lumens
Resolution: 1080p
Lamp Life: Up to 30,000 hours
Optical Zoom: 1.3x
Projection Features: 360 degree projection, H/V keystone, 4 corner adjustment
Auto Power: Configurable auto on/off
Remote Control: Supports Crestron, AMX, Extron, PJ Link, ATEN, ViewSonic’s vController
Connectivity: HDMI, USB Type A, compatible with most media players, PCs, Macs, mobile devices​
Brightness: 4200 Lumens
Resolution: 1080p
Throw Ratio: 0.49 short throw
Lifespan: Up to 30,000 hours
Setup Features: 4 corner adjustment, 15-degree H/V keystone, 360-degree projection, portrait mode
Auto Power: Yes
Connectivity: HDMI, USB 2.0 Type A, compatible with media players, PCs, Macs, mobile devices​
Side-by-Side Comparison​
ViewSonic LS740HD​
ViewSonic LS711HD​
30 Inches - 300 Inches​
35 Inches - 300 Inches​
1 Meters - 8 Meters​
1.2 Feet - 10.8 Feet​
3000000:1​
3,000,000:1​
Display Resolution​
1920x1080 Pixels​
920 x 1080 Pixels​
920 x 1080​
5000 Lumen​
4,200 Lumen​
DLP​
Laser​
Picture Quality Enhancement​
ViewSonic LS740HD​
ViewSonic LS711HD​
H.264, H.265​
203 Watts​
Light Source Life​
20000 Hours​
30000 Hours​
Mount Type​
Ceiling Mount​
Ceiling Mount​
Noteworthy Features​
Built-In Speaker, Eco-Friendly, ultra-large screen, Long-lasting​
Lightweight, High native contrast ratio, Non-stop 24/7 Operation, Long lamp life, Short Throw​
Connectivity​
ViewSonic LS740HD​
ViewSonic LS711HD​
USB, HDMI, 3.5mm Jack​
Hardware Connectivity​
HDMI, USB 2.0 Type A, 3.5mm Audio​
Laptop, Gaming Console, Smartphone, Speaker​
Laptop, Television, Speaker​
Measurements​
ViewSonic LS740HD​
ViewSonic LS711HD​
Dimensions L x W x H​
11.3"L x 8.5"W x 5"H​
5"L x 11.3"W x 8.5"H​
Item Weight​
6.6 Pounds​
6.95 Pounds​
Product
PROS AND CONS​
ViewSonic LS740HD​
Pros
• Laser technology for longer lifespan
• Quiet operation, especially in Eco mode
• Does not get hot during use
• Exceptionally bright, suitable for daytime viewing
• Flexible settings including manual/digital zoom and keystone correction
• Good color rendering and sharpness
• Compact design due to external power brick
Cons
• No lens shift feature
• Designed to be stationary, requiring careful placement
• Proprietary power cord connection may limit compatibility
• Occasional glitch causing random orange flashes
Overall Impression
This projector is an excellent entry-level option for those seeking a bright, high-quality image under $1,000. Despite some minor drawbacks, such as the lack of lens shift and a glitch that can occur, its performance in terms of brightness, color, and quiet operation makes it a strong choice for home theater enthusiasts. The added benefit of cooler operation and a compact design enhances its appeal. While the issues noted are concerning, they do not seem to significantly detract from the overall satisfaction with the product.
ViewSonic LS711HD​
• Very bright and good quality image
• Good price for the brightness
• Heavier than expected
• Actual brightness significantly lower than advertised (60% of the Optoma)
• Inconsistent performance across multiple units
The projector offers impressive build quality and initial brightness, but it ultimately fails to meet expectations due to its significantly lower actual lumens compared to competitors. The weight may also be a drawback for portability.
