- 1 Specs
- 2 Which to get
In the realm of home projectors, the competition is fierce, and choosing the right one often boils down to what matters most to you: visual quality or immersive audio experience. On one side, we have the ViewSonic LS610HDH Projector, boasting a high brightness of 4000 Lumens and the promise of long-lasting performance with up to 30,000 hours of LED life. It's designed for easy setup with features like optical zoom and keystone correction, making it a practical choice for those who prioritize versatility and visual clarity.
On the other hand, the Aurzen Boom 3 Smart Projector takes a different approach by prioritizing sound. With its powerful 36W speakers and advanced smart system, it aims to deliver a cinematic audio experience that few projectors in its price range can match. Plus, its auto-focus and keystone correction technology simplifies the setup, inviting you to dive straight into your favorite streaming apps without the need for additional devices.
So, whether you lean towards the stunning visuals of the ViewSonic or the rich audio experience of the Aurzen, this comparison will help you navigate the nuances of each, ensuring your next movie night is exactly how you envision it. Let's dive in.
The ViewSonic LS610HDH boasts a solid 4000 Lumens brightness with 1080p resolution, which sounds great for clear, vibrant images. Plus, the LED tech gives it an impressive lifespan of 30,000 hours. The setup looks pretty straightforward with features like 1.2x optical zoom and advanced keystone adjustments. But what could be the catch? Is the sound quality decent enough, or will I need to invest in a sound system?
On the flip side, the Aurzen Boom 3 seems to be a game-changer in audio with its 36W speakers and surround sound. It’s got a smart system with pre-loaded streaming apps, which is super convenient. The auto-focus and advanced keystone corrections are also intriguing. But is there a trade-off in picture quality, or does it hold up?
I’d love to hear your experiences or thoughts on which projector seems like the better buy!
Specs
Parameter | ViewSonic LS610HDH Projector | Aurzen Boom 3 Smart Projector |
Reference Price | $769.58 | $230.99 |
Built-In Media | User Manual, Power Cord, Remote | - |
Highlight | VERSATILE PROJECTOR: High brightness 4000 Lumens 1080p LED projector with advanced visual features EXTENDED LIFESPAN: Latest LED technology provides an extended lifespan of up to 30,000 hours EASY SETUP: 1.2x optical zoom, 4 corner adjustment, 40-degree H/V keystone and 360 degree projection | First-class 36W Speakers, Surrounding Sound, Bidirectional Bluetooth 5.2: Aurzen BOOM 3 proyector is the revolutionary new-generation projector that elevates the stereo surround sound to an new level; With 36W powerful speakers to ensure crisp highs, strong midranges, booming bass, it stands out as the best in audio quality within thousand-dollar projectors, really immersing yourself in a cinematic experience Smart System and Officially-Licensed Apps: This smart projector is equipped with advanced smart TV OS which supports 1,000,000 videos; It’s pre-loaded with certified Netflix, Prime Video, and YouTube, which enable you to quickly launch your favorite movies or TV shows with just one click; Besides, the Open Browser and the APP STORE enable you to download your favorite apps; No need to connect external TV sticks Auto Focus, Auto Keystone Correction,50%-100% Zoom: This portable projector adopts the cutting-edge AI focus algorithm with 9 directional gyros, ensuring instant auto focus and ultra clear image at all times; The 6D keystone correction achieves screen auto-adaptions with wide angle of 45° from six directions, whatever wall it is; And the zoom function allows you to easily adjust the image size from 50% to 100%, no need to move the projector |
Screen Size | N/A - 300 Inches | - |
Throw Distance | N/A - 10.59 | - |
Contrast Ratio | 3000000:1 | - |
Maximum Resolution | 1080 Pixels | - |
Native Resolution | 1920 x 1080 | - |
Display Type | LED | - |
Other Features | Built-In Speaker, Instant Power On/Off, Digital Keystone Correction, 3rd generation LED technology, 1080p Full HD resolution | Portable, Auto Focus |
LightSource Life | 30000 Hours | - |
Connectivity Technology | USB, Ethernet, HDMI | - |
Compatible Devices | - | Gaming Console, Laptop, Smartphone, Tablet |
Wattage | 310 watts | - |
Mount Type | Tabletop Mount | Ceiling Mount |
Which to get
So, I'm in the market for a new projector, and I've come across two options that seem pretty awesome – the ViewSonic LS610HDH and the Aurzen Boom 3. I'm wondering which one I should go for based on picture quality, sound quality, system features, and any potential downsides.The ViewSonic LS610HDH boasts a solid 4000 Lumens brightness with 1080p resolution, which sounds great for clear, vibrant images. Plus, the LED tech gives it an impressive lifespan of 30,000 hours. The setup looks pretty straightforward with features like 1.2x optical zoom and advanced keystone adjustments. But what could be the catch? Is the sound quality decent enough, or will I need to invest in a sound system?
