VANKYO LEISURE 3 vs 410: What are the differences and which is better?
Bread Pitt
As the best sellers in portable projectors brand, Vankyo has always dominated the PJ market of models under $200. For many users, VANKYO LEISURE 3 and VANKYO LEISURE 410 projectors are with similar features, so this thread is aiming at the comparison of VANKYO LEISURE 3 and 410 to find out the differences between the 2 models, and which which one is better:
VANKYO LEISURE 3 vs VANKYO LEISURE 410 Comparison
1.Specification
VANKYO LEISURE 3 Specification
  • Technology: LCD LED lamp
  • Resolution: 480p
  • Brightness: 2400 Lux
  • Contrast: 2000: 1
  • Keystone: 15
  • Lamp life: 40,000 hours
  • Speaker: 2X2W
VANKYO LEISURE 410 Specification
  • Resolution: 480p
  • Brightness: 3600 LUX
  • Contrast: 2000: 1 (3000:1 for the 2020 Upgraded model)
  • Keystone: 15
  • Speaker: 2W
2. Features
size:
Vankyo Leisure 3 is quite smaller, by measures only 7.9 inches x 5.9 inches x 3.1 inches, while the VANKYO Leisure 410 is 9.84 x 6.30 x 3.15 inches
input:
Vankyo Leisure 3 and 410 both include the VGA cable, HDMI cable, and 3.5mm AV cable, supports 480p, 720p, and 1080p resolutions, and provide HDMI, VGA, AV, and USB ports, plus an SD card slot.
However, Vankyo Leisure 410 has an addition: a TV input jack. So, you can plug your TV’s cable directly to Vankyo Leisure 410 projector to get a large-sized projection.
3. VANKYO LEISURE 3 vs 410 Perfomance:
Both Vankyo Leisure 3 and 410 projectors work best when in total darkness. But the difference is obvious: That said, Vankyo Leisure 3 still does not look as bright as Vankyo Leisure 410.
Vankyo Leisure 3 is able to throw a picture of 32″ and up to 170″. This is achieved with a distance between 5 ft and 16.5 ft. However, the best distance for this projector is somewhere under 6.5 ft. If you put it any further, the images will start to blur.
One of the most impressive things of Vankyo Leisure 410 is the speedy operating system
Vankyo Leisure 410 is capable of throwing a screen size of 33 inches and up to 170 inches
You can still use it with some environmental light, but the images won’t be as bright and clear.
The images are noticeably brighter. The colors are solid and accurate, with good contrast. Also, Vankyo Leisure 410 seems to have better sharpness. The images are nicely defined.
4. Price: around 100 bucks
For a limited budget, both the two models are affordable for users.
Vankyo Leisure 3 Projector: $ 119.99
Vankyo Leisure 410 Projector: $ 98.9
VANKYO LEISURE 3 vs. VANKYO LEISURE 410 Conclusion
In conclusion, Vankyo Leisure 410 is more recommended for a better image quality. The screen is brighter, with good color quality and contrast. The images also seem to be sharper. The connectivity is great; this projector can accept video input from various sources, including USB thumb drives and SD cards.
